Value of rebuilt 1275 Engine, new clutch & rib trn
Rep007
Any guess as to the value of a newly professionally rebuilt 1275 Midget 1972 engine with new clutch mated to to the ribcase trans. Have one which I have invested $ to have rebuilt, now find myself no longer in need and need to sell. Any insights as to value appreciated.
Re: Value of rebuilt 1275 Engine, new clutch & rib
I doubt you would get your money back out of it, unless someone buys it locally because they know and trust the person that rebuilt the engine. If trying to sell it locally, then it would certainly help if it was in a car. I'm very hesitant to buy a motor without seeing it run, unless it is from a local scrappy that I trust and offers some type of warranty.
screenprinter
Rep,
1275 cc engines are pretty desirable especially to racers - you may try looking around or googling SCCA boards for wanted ads. There are things to consider tho - like trevor said it's hard to determine level of craftsmanship in engine building by looking at a unit - The buyer really doesn't know if the mechanic doing the work was Little Lord Fauntleroy or Jack the Ripper -
A couple of rough guidelines from my experience:
A rib case transmission, not rebuilt, as-is out of a junker should go from $150.00 to whatever the seler can get. Certified rebuilt with new synchs, bearings, gaskets and layshaft by a competent mechanic who knows? $500 and up - The Victoria British hole-in-my-wallet sells them rebuilt for around $1,100 + shipping (Ouch...)
The engine is hard to peg - it depends on a lot of things such as:
New pistons?
new cam? reground? cleaned up and re-installed?
New Valves, springs, guides, etc.?
New Timing chain?
Oil pump?
Again, Trevors spot-on - you'll probably never get out of it what you've put into it but a decent 1275 cc would bring $500.00 and up depending on mods and upgrades.
Last one I shed my self of was just the block and crank, not rebuilt and I swapped it even to a SCCA racer-type for whatever I wanted off his parts cars which amounted to:
2 decent front fenders
1 valence assembly
1 steering rack
2 front spindle assemblies ( With the hubs )
1 half-way decent convertible top frame.
I think I got the best of the deal, but he , no doubt thinks he took me - Personally I think all of us lbc owners are about half nuts!
So, check around, post it in a bunch of places - Try EBAY and put a reasonable reserve on it. Don't be in a rush to dump it - Like PT BArnum said "There's one born every minute"
Bugeye58
About the only thing an SCCA racer would be interested in is the block. All the internals get changed to racing parts rather than performance parts. Quite a difference in quality and price.
Around here, (southern Michigan) a used rib case tranny goes for $25.00 to no more than $125.00, and the last 1275 I bought had a trans attached for $250.00 complete.
You will never get back the cost of the rebuild, just as you will never get a return on the cost of a vehicle restoration.
Sad, I know, but true.
Jeff
screenprinter
Oh Man....$25.00 for a rib case tranny - I'm living in the wrong state - There must be a lot of them in your area, but down here they're like dragon scales - Everybody's seen em' but nobody's got em'
btw some SCCA guys down here in redneck land also use the crankshaft (after refinishing and balancing) and sometime the heads (after a thousand or so bucks worth of machine work) We're just country boys and cain't afford no 'Luminum Haids!
Bugeye58
Yes, the cranks sometimes do get used, depending on the crank, but a lot of the gang has gone to nothing but billets.
The heads are good for a core, and you won't get much out of them. I have my head work done on the west coast, and it's cheaper for me to have them supply the head than it is for me to ship it cross-country as a core.
The aluminum heads aren't legal for SCCA road racing, and we're limited to stock valve sizes, as well.
Rib cases should be easy to find, as they fit every Spridget from '62 to '74.
Didn't mean to hijack this thread!
Jeff
screenprinter
That's okay - I like reading
Banything that I can learn from - I'm not so hardheaded as to think I know it all - My dad used to tell me " It's what you learn after you know it all that really counts"
G TR6 Fair value for a rebuilt TR6 engine Triumph 6
C TR2/3/3A Frame repair and value Triumph 2
D I have doubled the value of my MG Midget. Spridgets 2
AngliaGT 1275 Engine Value? Spridgets 5
AngliaGT TR2/3/3A Value of a One Owner,Excellent Condition TR3B ? Triumph 12
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
Lin Oil sump torque value? Spridgets 3
Lin Water Pump torque value for nuts on studs Austin Healey 1
HealeyRick Gold Level Concours Value Austin Healey 20
M Original Bugeye steering wheel value Spridgets 3
Kleykamp Rubber bumper Midget value? Spridgets 5
K TR2/3/3A Value of a Complete Motor disassembled? Triumph 8
J 1963 Austin Healy "Sprite" Value Austin Healey 7
J MGB 1973 MGB Value MG 8
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
K TR2/3/3A Steering box drop arm Nut torque value? Triumph 0
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
TR4nut TR6 Ballpark hardtop value? Anyone? Triumph 3
D 68 Sprite value - need help Austin Healey 9
TomMull GT6 More on value trends Triumph 12
Brinkerhoff TR6 value of a TR6 factory hardtop Triumph 5
GTP1960 TR2/3/3A the value of experience when setting timing on a modified engine Triumph 33
M The value in 5 speed conversion Spridgets 18
7 TR6 help with tr6 hardtop value Triumph 5
B Original Hardtop - Identification and Value Austin Healey 8
C Value of 100-4 heater box?? Austin Healey 2
J TR2/3/3A Dynamic timing value Triumph 5
C Value of BN1 Original Front Drum Brakes? Austin Healey 4
Gliderman8 TR6 Opinions on value of this '76 TR6 Triumph 18
C Color change...impact on Value? Austin Healey 24
Mink TR4/4A Your thoughts/value of this TR4 Triumph 357
Jim_Stevens TR2/3/3A OD Transmission value Triumph 3
AngliaGT MGB '67 B - Value? MG 5
T 100-6 Longbridge value Austin Healey 5
2 GT6 69 GT6+ suggested value? Triumph 4
J Value on an original BJ7 these days. ?? 38,000 miles Austin Healey 4
RickB MK1 Midge radiator value? Spridgets 2
apbos Works hardtop. The value of or cars is climbing! Spridgets 11
K TR2/3/3A Torque value for TR3 clutch cover to flywheel bolts....... Triumph 2
Brinkerhoff Market value for an unrestored BJ7 ? Austin Healey 17
K Value of an early Commission Number Triumph 5
N BT7 Restoration value advice Austin Healey 32
6 any value to this?? MG 2
TR4A_IRS TR4/4A TR4A long block value? Triumph 11
C BJ8 Smoothline top value Austin Healey 9
Marvin Gruber Looking at another 100 6- value? Austin Healey 16
R Fair Market Value Triumph 15
J Things that influence the value of a Spridget? Spridgets 18
K TR2/3/3A TR3 starter dog bolt torque value? Triumph 1
