oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi
sim
so is this a bad gauge or engine rebuild? I do not hear any knocking and engine runs just fine. opinions please
drooartz
You could certainly try a new gauge in there, but 10psi warm is, as you know, an issue. At just over 20psi my MGB didn't knock and seemed to run fine, but it was sure tired.
If you don't try a new gauge, I'd want to get into that engine and give things a real look over.
sim
sim
it been a long time since I had the oil pan off. what should i look at first. ? Can the cam shaft be pulled out with out pulling the engine?
bobhustead
Wild guess, but easier than a tear-down - could the oil pressure relief valve be sticking open when temps in the block get high? What happens if you let it come to operating temp at or just above idle so the oprv never pops open?
Bob
sim
sim
Where is this valve located? When I start it up cold , I get 60PSI but when it warms up while driving it drops off to 10 PSI.
You are suggesting I just start it up and let it idle to warm up
bobhustead
To see what and where to oprv is, look at the Moss catalog diagram. Yes on running it at or just above idle until it reaches operating temp to see if pressure continues at satisfactory levels when you have not opened the oprv.
Bob
bobhustead
An oprv is in a main pressure gallery coming off the oil pump. When oil pressure gets excessive, the valve opens from the pressure and lets oil drop back into the pan instead of continuing to add pressure to the lubricating system. Opening pressures are typically 65 or 70 pounds, but tinkering with the spring or replacing it can affect the pop off pressure.
Bob
JPSmit
I drove a lot of miles in my Midget (1500) with 10lbs of pressure at warm idle. That with a refreshed engine. Obviously 10 lbs at speed is a problem but, the pressure drops a lot on these puppies when warm. I finally replaced the oil pump (should have done it with the refresh - doh!) The best intermediate decision was that I run a quart of Lucas engine oil stabilizer with every oil change - made probably a 10 lb pressure difference.
JPSmit
PAUL161
How old is you engine? Would this be too thick on new parts?
My TF 1500 has had 20/50 Valvoline VR-1 ever since it was rebuilt, it runs 50lbs hot or cold. The relief valve is set at 50lbs. PJ
JPSmit
I re-did the engine around 2010. I don't know that it would be too thick but probably Doc or someone with a bit more experience could chime in.
Bayless
Our local MG/Healey guru says they all need 20W50 and he has a lot of experience.
sim
sim
up date I changed to oil relief system. change oil using 20 50 new oil filter . I now have 100 psi at idle . I think I need to go back to 10 30 . Opinions please
bobhustead
100, even at high rpm, would be too much. There is no way such pressure is actually possible at idle. The relief valve is irrelevant at idle because the pump could not generate the pressure to open it at idle.Try another gauge to ensure that the gauge is not the problem. I would run 10w30, although if you have a workshop manual that says otherwise follow the manual. What was the oil pressure condition before the low pressure cropped up? Have you changed any other components?
Bob
fpstude TR2/3/3A Flex Oil Line to Oil Pressure Gage Triumph 5
Lynn Kirkpatrick Oil pressure gage or sending unit? MG 1
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
G High Oil Pressure Austin Healey 2
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
A MGB Oil pressure MG 9
K TR2/3/3A Oil pressure readings Triumph 10
J Oil Pressure Relief Valve Austin Healey 3
L Oil Pressure Gauge Austin Healey 5
LAW75 Oil Pressure Austin Healey 4
D TR2/3/3A oil pressure line venting? Triumph 4
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
R Bugeye oil pressure line Spridgets 9
K TR2/3/3A Oil pressure readings Triumph 3
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
S TR6 Oil Pressure Light Triumph 2
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
Kurtis No oil pressure Spridgets 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
V Braking Oil Pressure Austin Healey 16
N Suspected disaster - but it went well. Oil pressure restored. Austin Healey 1
S TR2/3/3A Oil pressure gauge removal Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Oil? Oil Pressure? Triumph 8
JFS TR6 No oil pressure Triumph 2
Simmo TR2/3/3A High Oil pressure Triumph 11
D TR5/TR250 High oil pressure Triumph 5
T TR6 Low Oil Pressure Light Triumph 3
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
K Time to build oil pressure Austin Healey 23
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
D BT7 oil pressure relief valve Austin Healey 19
D BT7 oil pressure relief valve Austin Healey 2
J Zero oil pressure at 4000 RPM Austin Healey 24
D TR2/3/3A oil pressure Triumph 6
HighAltitudeTR3 TR2/3/3A Oil Pressure low all of a sudden Triumph 10
S An oil volume question and an oil pressure question Austin Healey 5
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
K TR2/3/3A Oil pressure gauge needle sticking? Triumph 4
K TR4/4A Oil pressure gauge Line? Triumph 5
B TR2/3/3A normal oil pressure in TR3 Triumph 6
Gliderman8 TR6 Stainless oil pressure line install HELP! Triumph 8
L 100 spin on oil filter part number, no oil pressure after replacement Austin Healey 8
G Need Help: Oil leak/crankcase pressure Spridgets 18
2billydavies TR2/3/3A very low oil pressure when TR3a is warmed up Triumph 12
T 1275 engine oil pressure warning light? oil filter warning light?? Spridgets 4
