TR6 Low Oil Pressure Light
TR6Dan
Member
I noticed the last time I drove my car the low oil pressure light took a half mile or so of driving to go off. The oil level is fine and the oil pressure gauge says 75 and the lowest 50. Could it be the oil pressure switch or another item needs replacing? Dumb question; but what is the purpose of both a light and gauge?
Thanks,
Dan
dklawson
The switch is for alerting you with the sudden appearance of the colored light in your line of sight. It might be a while before you notice a low reading gauge.
Switches do go bad. I would replace it with a known good one as it is the least expensive first step. A second step would be to use an aftermarket, cheap pressure gauge to confirm the one in the dash is reading correctly.
Tybalt
This is going to sound odd but IIRC there is tie in with the oil pressure light and the PDWA* electrical circuit. I had a similar problem, faint glow of the oil pressure light that would come on and then go off after a while, when I first bought my TR6 in the 1988. It turned out that the brakes had not been bled properly and the PDWA piston was not well centered. I bled the brakes to center the PDWA piston and the problem went away. Another way to center the piston if it isn't too far off center would be to remove the switch on top of the PDWA and use a small screwdriver or punch to move the piston and center it. There is a pretty good bit on the Buckeye Triumphs website technical articles that discuss rebuilding the brake master and PDWA. You can see what the piston looks like and how the PDWA switch rides in this necked down portion of the the PDWA piston.
https://buckeyetriumphs.org/technical/Brakes/MCPDWA/MC.htm
*PDWA - (Pressure Differential Warning Actuator) just in case you are not familiar with it, it is part of the brake system to warn you of a loss of pressure on either the front or rear hydraulic circuit
poolboy
The PDWA switch when grounded can activate the BRAKE light, but the not the Oil Pressure warning lamp....on the other hand low oil pressure will illuminate BOTH the BRAKE and the Oil Pressure warning lamp. However both lamps will be rather dim due receiving only 6 of the 12 volts
If the OP warning lamp does go out after a half mile or so as Dan described I doubt that the problem is the PDWA itself.
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
HighAltitudeTR3 TR2/3/3A Oil Pressure low all of a sudden Triumph 10
2billydavies TR2/3/3A very low oil pressure when TR3a is warmed up Triumph 12
V Low Oil Pressure Triumph 4
H low oil pressure Austin Healey 15
Michael Oritt Low oil pressure kill switch Racing 8
L Low oil pressure in new engine Austin Healey 67
bighealeysource oil pressure in a BN6, too low or okay ? Austin Healey 21
nissanite E-Type V12 very low oil pressure - new rebuild Jaguar 11
CraigLandrum TR2/3/3A TR3 Low oil pressure [again!] Triumph 23
rlandrum TR2/3/3A TR3A Low Oil Pressure Solved Triumph 19
jmwuva05 Low oil pressure after spin on filter Spridgets 13
B oil consumption and low pressure Austin Healey 18
BOBBYR low oil pressure is common at idle Austin Healey 17
BOBBYR Low idle oil pressure Austin Healey 11
VelodromeRacer Low Oil pressure light installation Racing 10
A Hot-low oil pressure / Aux. oil line problem fixed Triumph 6
J low oil pressure MG 18
W jaguar low oil pressure Jaguar 4
D TR6 Re Low Oil Pressure Indicator on my TR 6 Triumph 1
D Low Oil Pressure Indicator Light Triumph 2
G Oil Pressure Too Low - Redux.... Triumph 2
G Oil pressure too low... Triumph 29
mondialo64 TR4/4A Was: tr4 low oil pressure Triumph 7
mondialo64 TR4/4A tr4 low oil pressure Triumph 7
rovernut Low oil pressure MG 11
C Low oil pressure Austin Healey 22
D Oil pressure low MG 8
G LOW OIL PRESSURE OR NOT? MG 1
vping Results of Low Dashpot oil MG 11
roscoe Low-Budget Luggage Rack Austin Healey 27
Donald1107 TR2/3/3A low cylinder compression Triumph 12
D Lucas Low-Tension Leads Austin Healey 1
CJRams For Sale 1974 Rolls Royce Silver Shadow - low mileage, all original Other British Classifieds 0
rgfrey 1959 Low Beam Headlights Not Working Austin Healey 5
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
Patrick67BJ8 Low-Profile Electric Puller Fans Austin Healey 51
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
F TR6 Sputtering at low rpm Triumph 16
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
Joe Schlosser Spedo reading low Spridgets 8
F TR6 Squeal When Turning Sharply at Low Speed Triumph 6
F TR6 Carburetor issues at low rpms webers Triumph 23
RAC68 Heavy Tapping low in the Engine Austin Healey 58
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
Geo Hahn TR6 Low Miles TR6 on eBay Triumph 4
K TR2/3/3A Volvo low profile space saver spare tire for TR3 ? Triumph 1
TomMull Volvo Low Rider spotted in Vassalboro Me Other Cars 1
RickPA Water temp gauge reads low Austin Healey 6
