Oil Pressure Too Low - Redux....
G
I finally got everything back together. I ended up placing new thrust washers (that was my original project) as there was about .013 play in the crank. Obtained several sets, not knowing what I would need. Actually only had to place stock-sized washers, with the bare minumum amount of allowable play in the crank. Checked it with a dial gauge.
The hardest part was retorqueing the bolts on the back crank bearing. Got it up to 64lb and quit. The oil pump was shot so I dropped in a new one. Repainted the oil pan and used new lock washers. Some gorilla had stripped a front bolt for the pan in the aluminum plate. I had no desire to take everything back down and Helicoil the darn thing so I searched in my vast collection of old bolts and found a metric bolt a hair larger than the sae bolt and just threaded that one in place with Loctite.
Bottom line, my oil pressure is now 50+ lbs at idle and 70 lbs at speed. Had to be the oil pump. Installed a new rebuilt dizzy all at the same time and she cranked instantly at first try. Satisfying. Spun the timing over to 8 degrees BTDC and she sounds sooooo good. Now my tach is not working. (intermittantly working) Might have to pull the cable and slide in a new one. I'll call the guy tht did the distributor for my and run that by him. (Mark at British Auto in NY). I am a tired puppy right now as I have worked all day and then came home to finish the car. The music to my ears when she cranked with good oil pressure was worth it. Now I have to soak the grease out form under my nails before I fix some teeth tomorrow.
Bill
V
vagt6
Sounds like good work to me, Bill. Congrats!
Did you use a standard oil pump for the replacement, or a fancy, aftermarket one?
trrdster2000
TR6Bill, good job and a hint about the dirty nails, use some Goop or some hand cleaner before you start and get lots on your nails only wipe off your hands leaving a little bit under your nails and around them, cleans up like a charm. You can get the gloves now, but I have trouble getting at small nuts and bolts with them. Wayne
6 too much oil pressure??? Triumph 25
bighealeysource oil pressure in a BN6, too low or okay ? Austin Healey 21
J Oil Pressure Too High Spridgets 3
Ed_K Can oil pressure too high damage something ? Austin Healey 4
M BJ8 oil pressure too high? Austin Healey 1
Andy Blackley High Oil Pressure: Too much of a good thing? Triumph 11
G Oil pressure too low... Triumph 29
J Oil Pressure Too High? Austin Healey 2
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
G High Oil Pressure Austin Healey 2
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
A MGB Oil pressure MG 9
K TR2/3/3A Oil pressure readings Triumph 10
J Oil Pressure Relief Valve Austin Healey 3
L Oil Pressure Gauge Austin Healey 5
LAW75 Oil Pressure Austin Healey 4
D TR2/3/3A oil pressure line venting? Triumph 4
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
R Bugeye oil pressure line Spridgets 9
K TR2/3/3A Oil pressure readings Triumph 3
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
S TR6 Oil Pressure Light Triumph 2
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
Kurtis No oil pressure Spridgets 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
V Braking Oil Pressure Austin Healey 16
N Suspected disaster - but it went well. Oil pressure restored. Austin Healey 1
S TR2/3/3A Oil pressure gauge removal Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Oil? Oil Pressure? Triumph 8
JFS TR6 No oil pressure Triumph 2
Simmo TR2/3/3A High Oil pressure Triumph 11
D TR5/TR250 High oil pressure Triumph 5
T TR6 Low Oil Pressure Light Triumph 3
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
K Time to build oil pressure Austin Healey 23
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
D BT7 oil pressure relief valve Austin Healey 19
D BT7 oil pressure relief valve Austin Healey 2
J Zero oil pressure at 4000 RPM Austin Healey 24
D TR2/3/3A oil pressure Triumph 6
HighAltitudeTR3 TR2/3/3A Oil Pressure low all of a sudden Triumph 10
S An oil volume question and an oil pressure question Austin Healey 5
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
K TR2/3/3A Oil pressure gauge needle sticking? Triumph 4
