jaguar low oil pressure
wallacedog
HI all i have a problem with my 94 xj40 oil pressure, after about 20 miles the gage drops to near nothing, it is fine till the engine gets hot. Somebody told me that it could be the oil sender unit that has got a fault i hope that is so. I phoned the man that i got the car of he sead it as been like that for a long time and i should not be to concerned, easy for him to say.Any advise whould be appreciated.
Dave Russell
Yoda - R.I.P
Hi & welcome to the forum.
I'm not a Jag expert, but, I would verify the oil pressure by connecting a mechanical gage to the block. If the pressure is below about 40 psi at 2500 rpm, there is cause for worry. Make sure that you have the correct grade of fresh oil & filter. The pressure senders have been known to go bad, but I would verify with a mechanical gage first. I'm sure that someone more knowledgeable than I will join in. Maybe someone can tell you exactly where to connect the gage & what it should read.
shorn
I just replaced the oil pump in my Austin Healey because of low oil pressure (see post "Which Oil pump to buy" under Austin Healey. It raised the pressure somewhat. Good luck. However, if the guage shows pressure when the oil is cold, but drops significantly as the oil heats up, I would suspect the guage is functioning correctly and there is a problem elsewhere.
Webserve
The oil pressure sender on the XJ40 is one of the notoriously bad items that Jag put onto these cars. It is one of many common ailments that these cars suffer from. My '88 XJ40 oil pressure bounces all over the place depending upon time of year, time of day and temperature of the oil as well as the RPMs of the engine. It is a common malady. You can usually find a replacement unit for about $25 on Ebay or from an aftermarket place for about $40. Since this is a well known problem, I would give this a shot before I started to pull oil pans and pumps.
There are two types of senders available. One is the simple on/off type that will put the gauge at dead center every time the engine is started. The other is the gradient type that will go up and down as the engine pressure goes up and down. It is pot luck as to which you will get. The sender is located just above the oil filter on the left side of the engine and it is recommended that you change the oil at the same time as the sender since you have to take the filter off any way.
Since it sounds like you just purchased this car, you need to read the online book written by XJ40 owners. It is located at https://www.jag-lovers.org/ebooks/bookindex.php?Vbook=xj40. It will give you an idea of the problems these cars face as well as how to fix them.
Webserve
maynard
I was alking to the guy from Jag Specialists yesterday. He commented that many of the low oil pressure problems come from using the wrong oil and/or filter. He says to use only Castrol, 20W50 in summer, 10W40 in winter. He also said to use only factory oil filters.
I don't know if this is the case, but an oil change is cheap and can't hurt.
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
O Jaguar rear window trim repair Jaguar 1
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
R For Sale For Sale 1990 Jaguar XJ6 Jaguar Classifieds 0
Bristol401 For Sale Jaguar Mk2 Jaguar Classifieds 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
CJRams For Sale 1969 Jaguar XKE Jaguar Classifieds 0
T Motor Jaguar 4.2 Jaguar 14
D 1992 jaguar xjs abs Jaguar 1
L For Sale 1959 Jaguar Mark 1 Jaguar Classifieds 0
TireKicker847 Wanted 07 Jaguar XK trunk covers Jaguar Classifieds 0
AngliaGT Jaguar XK120 (?) on I581 Spotted 1
J For Sale Jaguar E Type and MK2 spares Jaguar Classifieds 0
Lin Jaguar Distributor Cap for Healey Austin Healey 8
J For Sale For Sale in Seattle, WA: 1989 Jaguar XJ-S Convertible_$11,200 Jaguar Classifieds 1
S SU carbs AUD9124 on a Jaguar ? Jaguar 2
Rut Jaguar 340 Jaguar 8
T For Sale Gear reduction starter fits jaguar 3.8 340 mark series 3.8l 3.4l - $100 Jaguar Classifieds 0
LarryK Jaguar MK1 restorations Jaguar 15
M Jaguar XK Special Equipment Generator Jaguar 1
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
K For Sale Rare Book The Jaguar XK in Australia Jaguar Classifieds 0
Got_All_4 For Sale Triumph Austin Healy Jaguar 15"x5.5" Complete Wire Wheels Set & Hubs Triumph Classifieds 1
J Anybody driving a 2018 Jaguar XJ? Jaguar 3
A For Sale 1986 jaguar xj6 Jaguar Classifieds 0
69MGC Latest Jaguar Digital Illustration Jaguar 0
B For Sale 1969 Jaguar XKE 4.2L Series II Coupe - Indiana Jaguar Classifieds 0
M Planing a Jaguar cylinder head Jaguar 4
David Townsend Limited Edition Jaguar Puzzles Jaguar 0
T Wanted Jaguar MK2 fuel tank and Radiator Jaguar Classifieds 8
M Wanted Jaguar XK140 OTS Battery Door Jaguar Classifieds 0
M What is the finish Jaguar Uses on Veneered Trim Pieces? Jaguar 4
nevets Jaguar reissuing the D type. Austin Healey 9
G original radio 1961 e series jaguar Jaguar 3
Lin Fuse box - new product in my current project, a 1964 jaguar mark tw Austin Healey 10
Q Just Starting Restoration Of 1967 E Type Jaguar OTS Jaguar 13
R Jaguar XK140 mystery part Jaguar 0
K 1980 Jaguar paint colour.... Quartz Blue? Jaguar 2
E Series 1 jaguar boot latch problem Jaguar 2
aeronca65t Jaguar event - Lime Rock Racing 3
aeronca65t Priceless Jaguar and Mercedes crash at Goodwood Racing 11
D 1950 Jaguar Mark V Sunroof Question Jaguar 0
C Will Jaguar build a new plant in US? Jaguar 4
K Jaguar 140 Restoration Link? Jaguar 2
C Jaguar Design Director Ian Callum honored for his hard work Jaguar 0
C The 1956 Jaguar XKSS was one of a kind Jaguar 10
C Jaguar wows the crowds at the CES show in Vegas Jaguar 2
M Jaguar XK140MC Carb Etch #'s Jaguar 0
C How will the 2015 Jaguar XF define you? Jaguar 0
