low oil pressure
johnjoan6203
just finished with major rebuild on 1973 MGB, new pistons 020, main and rod .010, new oil pump and strainer ,new oil pressure relief valve, new cam and bearings,double row timing gears and chain, now for the head all new valves, guides, springs, seats, new push rods , new lifters , new pressure plate, clutch, release bearing, only have about 50 miles on this rebuild ,oil pressure is low at idle between 15-25 psi.when warm going down the road its about 65-75psi at 3000 rpms,Is this normal /ubbthreads/images/graemlins/confused.gif
jlaird
What does your manual say?
Platinum
Sounds good to me. That's where it should be. You're "good to go." /ubbthreads/images/graemlins/wink.gif
AlanT
That idle oil pressure is much too low for a fresh engine. Did you check the rod and main clearances? One common mistake is to mount the oil pump with the wrong gasket. Two gaskets typically come in the gasket set but I don't know why. The larger one is correct for the 5-main engine. And of all the engines I've seen with this problem , they all seem to act differently. Some will not pump oil at all and others have good running pressure and lousy idle pressure. The giveaway was the air bubbles coming from the rocker shaft.
Alan T
tony barnhill
Great Pumpkin - R.I.P
/ubbthreads/images/graemlins/iagree.gif Oil pump gasket is the first thing I'd check - that idling oil pressure should be higher...also, there's a tiny hole in the edge of your rods down by where the caps attach - its used for wetting down the cylinder walls by oil squirting out it - which direction did you point it when you reattached them to the crank, towards the oil pump side of engine or away?
Lee_Miller
I remember from discussions on other forums if a 3main gasket is used on a 5main the oil pressure would be zero because the 3main gasket covers a hole used by 5main pump. A lighter than recommended oil 20w/50 in new rebuild when running warn/hot will produce lower idle pressure.
Platinum
<runs out to warm up the MG> Now I'm compelled to check mine at idle when it's at operating temp...
AlanT
The 3-main gasket does not cover an orifice . It leaves an air gap the gasket thickness in the pickup side. I've seen this over the years about five times. Sometimes they will not pick up oil at all. The best foul up by a novice engine builder in this department is the one that made a gasket for the machine fit oil pump body to pick up casting and wondered why it would not pump oil.
Alan T
J
johnjoan6203
checked the owners manual& hayes book and they both say 10-25psi is normalat idle.well I'm going to change to a heavier oil 20w 50 thanks again!
jlaird
There ya go, spot on. Nice.
Steve_S
Before doing anything, make sure your oil pressure gauge is accurate. Get a handheld oil pressure kit and attach it directly to the engine block. If you are running a thinner oil than 20W-50, I'd recommend changing. Castrol GTX is the most common type for these cars.
Platinum
Well, with GTX 20-50 and at normal operating temp, my idle pressure is 25~30, and upon revving it up to 3K the pressure goes to around 70~75 PSI (80 when cold). I assembled this one "tight" (close end of the tolerances) and expect a ~slight~ decrease as it goes through its life.
jlaird
What the heck is a handheld oil pressure kit?
Steve_S
An oil pressure gauge on a rubber hose with a threaded attachment at the end. You unscrew the oil pressure unit form the block and thread the oil pressure gauge into it. Start the engine and see what the gauge reads.
jlaird
Ha, ok, I asked for that I guess.
jlaird
Ahh, okies, understand that link for sure.
Guinn
If you are idling at 400 you will have low pressure, of course.
the first question should be: At what idle RPM are you getting what pressure?
Guinn
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
T TR6 Low Oil Pressure Light Triumph 3
HighAltitudeTR3 TR2/3/3A Oil Pressure low all of a sudden Triumph 10
2billydavies TR2/3/3A very low oil pressure when TR3a is warmed up Triumph 12
V Low Oil Pressure Triumph 4
H low oil pressure Austin Healey 15
Michael Oritt Low oil pressure kill switch Racing 8
L Low oil pressure in new engine Austin Healey 67
bighealeysource oil pressure in a BN6, too low or okay ? Austin Healey 21
nissanite E-Type V12 very low oil pressure - new rebuild Jaguar 11
CraigLandrum TR2/3/3A TR3 Low oil pressure [again!] Triumph 23
rlandrum TR2/3/3A TR3A Low Oil Pressure Solved Triumph 19
jmwuva05 Low oil pressure after spin on filter Spridgets 13
B oil consumption and low pressure Austin Healey 18
BOBBYR low oil pressure is common at idle Austin Healey 17
BOBBYR Low idle oil pressure Austin Healey 11
VelodromeRacer Low Oil pressure light installation Racing 10
A Hot-low oil pressure / Aux. oil line problem fixed Triumph 6
W jaguar low oil pressure Jaguar 4
D TR6 Re Low Oil Pressure Indicator on my TR 6 Triumph 1
D Low Oil Pressure Indicator Light Triumph 2
G Oil Pressure Too Low - Redux.... Triumph 2
G Oil pressure too low... Triumph 29
mondialo64 TR4/4A Was: tr4 low oil pressure Triumph 7
mondialo64 TR4/4A tr4 low oil pressure Triumph 7
rovernut Low oil pressure MG 11
C Low oil pressure Austin Healey 22
D Oil pressure low MG 8
G LOW OIL PRESSURE OR NOT? MG 1
vping Results of Low Dashpot oil MG 11
roscoe Low-Budget Luggage Rack Austin Healey 27
Donald1107 TR2/3/3A low cylinder compression Triumph 12
D Lucas Low-Tension Leads Austin Healey 1
CJRams For Sale 1974 Rolls Royce Silver Shadow - low mileage, all original Other British Classifieds 0
rgfrey 1959 Low Beam Headlights Not Working Austin Healey 5
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
Patrick67BJ8 Low-Profile Electric Puller Fans Austin Healey 51
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
F TR6 Sputtering at low rpm Triumph 16
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
Joe Schlosser Spedo reading low Spridgets 8
F TR6 Squeal When Turning Sharply at Low Speed Triumph 6
F TR6 Carburetor issues at low rpms webers Triumph 23
RAC68 Heavy Tapping low in the Engine Austin Healey 58
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
Geo Hahn TR6 Low Miles TR6 on eBay Triumph 4
K TR2/3/3A Volvo low profile space saver spare tire for TR3 ? Triumph 1
TomMull Volvo Low Rider spotted in Vassalboro Me Other Cars 1
RickPA Water temp gauge reads low Austin Healey 6
