Oil pressure low
dschuldt
recently rebuilt the cylinder head. Removed the entire engine -- inspected the bearing and cylinders. Had no history on the condition of the engine. Found bottom to be fresh. Valve train worn. rocker busings, shaft, rocker arms all replaced.
After reassembled -- oil pressure is lower than I remember. 50 psi cold 20 psi hot -- little change from idle to 3500 rpm when hot -- Flow to top end is low
Ideas as to the best place to look for the problem?
Removed oil pan to inspect --
Oil pump is good, main bearing clean, no debris found in the oil pan.
well i guess i would ask... how many miles on the clock. and then just how "good" is the oil pump? you might also want to check the pressure relief valve.
just a thought or two
mark
G
I rebuilt mine in 1987 and have a lot of miles on it and mine runs at those same readings.
Bob
JTB
my 69's not rebuilt and has 45-50 at idle and 70-80 at speed.
G
Hmmmmmmmmmm, I wonder how these engines would register on the same guage.
Bob
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by mrbassman:
Bob
<hr></blockquote>
kinda does make ya wonder.....
mine at idle, hot is 20lb's. 60+ at speed. well within "spec" iirc
Bruce Bowker
I always eliminate the simplest things first. Make sure the gauge is Ok. Even though it was when you started does not mean it is now. Then go on from there - pump etc.
I assume all bearings and if you removed the rings went back in exactly the same place?
[ 04-29-2004: Message edited by: Bruce Bowker ]</p>
MDCanaday
If you had the motor out and did NOT replace the bearings, for no more than they cost, I can only ask WHY????? There is no more certain way to get a grimlin than to re-use a componet that is cheap and easy to replace.
I wish you luck, but I think you will be re-doing this beast sooner than later.
MD(mad dog)
dschuldt
Update ---
All bearings checked ok -- no need to replace.
Oil pump gaps all checked ok -- decided to replace with new. Fresh oil change and filter new oil pump and all is good.
60 psi at start up 50 psi hot -- idle pressure is good at 30+ psi
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
T TR6 Low Oil Pressure Light Triumph 3
HighAltitudeTR3 TR2/3/3A Oil Pressure low all of a sudden Triumph 10
2billydavies TR2/3/3A very low oil pressure when TR3a is warmed up Triumph 12
V Low Oil Pressure Triumph 4
H low oil pressure Austin Healey 15
Michael Oritt Low oil pressure kill switch Racing 8
L Low oil pressure in new engine Austin Healey 67
bighealeysource oil pressure in a BN6, too low or okay ? Austin Healey 21
nissanite E-Type V12 very low oil pressure - new rebuild Jaguar 11
CraigLandrum TR2/3/3A TR3 Low oil pressure [again!] Triumph 23
rlandrum TR2/3/3A TR3A Low Oil Pressure Solved Triumph 19
jmwuva05 Low oil pressure after spin on filter Spridgets 13
B oil consumption and low pressure Austin Healey 18
BOBBYR low oil pressure is common at idle Austin Healey 17
BOBBYR Low idle oil pressure Austin Healey 11
VelodromeRacer Low Oil pressure light installation Racing 10
A Hot-low oil pressure / Aux. oil line problem fixed Triumph 6
J low oil pressure MG 18
W jaguar low oil pressure Jaguar 4
D TR6 Re Low Oil Pressure Indicator on my TR 6 Triumph 1
D Low Oil Pressure Indicator Light Triumph 2
G Oil Pressure Too Low - Redux.... Triumph 2
G Oil pressure too low... Triumph 29
mondialo64 TR4/4A Was: tr4 low oil pressure Triumph 7
mondialo64 TR4/4A tr4 low oil pressure Triumph 7
rovernut Low oil pressure MG 11
C Low oil pressure Austin Healey 22
G LOW OIL PRESSURE OR NOT? MG 1
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
G High Oil Pressure Austin Healey 2
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
A MGB Oil pressure MG 9
K TR2/3/3A Oil pressure readings Triumph 10
J Oil Pressure Relief Valve Austin Healey 3
L Oil Pressure Gauge Austin Healey 5
LAW75 Oil Pressure Austin Healey 4
D TR2/3/3A oil pressure line venting? Triumph 4
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
R Bugeye oil pressure line Spridgets 9
K TR2/3/3A Oil pressure readings Triumph 3
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
S TR6 Oil Pressure Light Triumph 2
Kurtis No oil pressure Spridgets 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
