TR6 Re Low Oil Pressure Indicator on my TR 6
DonaldA
Last week I posted a question concerning the low oil pressure indicator light (it was on, I had good oil pressure and the oil in the engine was good). I received two very good replies - one suggested it may a defective oil presssure switch the other suggested the PDWA switch). I replaced the the oil pressure and that took care of the problem - thanks.
AltaKnight
Donald, thanks for letting us know.
Make sure you keep that TR6 dry out in Richmond there.
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
T TR6 Low Oil Pressure Light Triumph 3
HighAltitudeTR3 TR2/3/3A Oil Pressure low all of a sudden Triumph 10
2billydavies TR2/3/3A very low oil pressure when TR3a is warmed up Triumph 12
V Low Oil Pressure Triumph 4
H low oil pressure Austin Healey 15
Michael Oritt Low oil pressure kill switch Racing 8
L Low oil pressure in new engine Austin Healey 67
bighealeysource oil pressure in a BN6, too low or okay ? Austin Healey 21
nissanite E-Type V12 very low oil pressure - new rebuild Jaguar 11
CraigLandrum TR2/3/3A TR3 Low oil pressure [again!] Triumph 23
rlandrum TR2/3/3A TR3A Low Oil Pressure Solved Triumph 19
jmwuva05 Low oil pressure after spin on filter Spridgets 13
B oil consumption and low pressure Austin Healey 18
BOBBYR low oil pressure is common at idle Austin Healey 17
BOBBYR Low idle oil pressure Austin Healey 11
VelodromeRacer Low Oil pressure light installation Racing 10
A Hot-low oil pressure / Aux. oil line problem fixed Triumph 6
J low oil pressure MG 18
W jaguar low oil pressure Jaguar 4
D Low Oil Pressure Indicator Light Triumph 2
G Oil Pressure Too Low - Redux.... Triumph 2
G Oil pressure too low... Triumph 29
mondialo64 TR4/4A Was: tr4 low oil pressure Triumph 7
mondialo64 TR4/4A tr4 low oil pressure Triumph 7
rovernut Low oil pressure MG 11
C Low oil pressure Austin Healey 22
D Oil pressure low MG 8
G LOW OIL PRESSURE OR NOT? MG 1
vping Results of Low Dashpot oil MG 11
roscoe Low-Budget Luggage Rack Austin Healey 27
Donald1107 TR2/3/3A low cylinder compression Triumph 12
D Lucas Low-Tension Leads Austin Healey 1
CJRams For Sale 1974 Rolls Royce Silver Shadow - low mileage, all original Other British Classifieds 0
rgfrey 1959 Low Beam Headlights Not Working Austin Healey 5
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
Patrick67BJ8 Low-Profile Electric Puller Fans Austin Healey 51
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
F TR6 Sputtering at low rpm Triumph 16
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
Joe Schlosser Spedo reading low Spridgets 8
F TR6 Squeal When Turning Sharply at Low Speed Triumph 6
F TR6 Carburetor issues at low rpms webers Triumph 23
RAC68 Heavy Tapping low in the Engine Austin Healey 58
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
Geo Hahn TR6 Low Miles TR6 on eBay Triumph 4
K TR2/3/3A Volvo low profile space saver spare tire for TR3 ? Triumph 1
TomMull Volvo Low Rider spotted in Vassalboro Me Other Cars 1
RickPA Water temp gauge reads low Austin Healey 6
