Hot-low oil pressure / Aux. oil line problem fixed
ALLAN
From a previous post (last week) I was saying my new engine had low oil pressure at idle when hot, it was running at less than 25 psi. I was running a new stainless aux. oil line to the head and just switched back to my own made aux. line (plastic)that has a tube size I.D. about 1/2 of the stainless. My old line has fixed the problem I now have 40 psi. at hot idle. This backs up what alot of you have said that the aux. stainless line robs too much oil pressure, so I have found a way to keep most of the oil pressure and still provide more oil to the top end. The oil pressure is also about 10psi higher above 2000 rpm.-------------Well I got most of the bugs worked out and it is running good except for one thing, I have the dreaded oil weep out of the back distributor side of the head (between the head and block), it is slight though,--- before assembly I did apply sealer to that area and I have already re-torqued the head to 70lb---now what???
Brosky
Oddly Allan, my OP stayed exactly the same, but it was always very good, even with the SS line installed.
Between removing that line and the alloy VC without a baffle, my oil consumption of one quart per 300 miles is now back to one quart about every 1,000 miles.
The head that I had completely rebuilt has new guides and o-ring type valve seals. The only decision now is to whether to save it for a more suitable block to fit it to. The jury is still out on that one.
R
RonMacPherson
Is there a threaded plug on the rear of the head with a sealing washer on it on your head? If so, might try cleaning and spraying with Desenex or other aerosol talcum spray to leave a leak trail to isolate the source of the leak.
I believe that on one of my heads the crush washer was deteriorated.
A
ALLAN
Thats where my Aux. line is hooked into, no leaks there. I can see the seepage on the edge of the block (between head and block).
Brosky
Re: Hot-low oil pressure / Aux. oil line problem f
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] Well I got most of the bugs worked out and it is running good except for one thing, I have the dreaded oil weep out of the back distributor side of the head (between the head and block), it is slight though,--- before assembly I did apply sealer to that area and I have already re-torqued the head to 70lb---now what??? [/QUOTE]
This is what I'm doing for the same problem and probably what you will end up doing at some point.
Oh-Oh!! I just noticed that you said your "new engine". Sorry!!
tomshobby
Paul,
That looks so pretty it is a shame to hide it by bolting it to a block. Your wife might even like to put it in a glass showcase in the living room! /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
Brosky
Tom, it was on my desk in the office for a total of 10 minutes while I took the pictures and the glare started from across the room. Yes, we work together in the family business.
"Car parts belong in the garage or workshop" was written all over her face, so out it went. That's about the only rule that I have to live by.
I just hope I'm there when UPS delivers the brake system from TRF, because there is gonna be a bunch of boxes when that hits.
bobh Low Mileage Originals are Hot Triumph 2
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
Overdrive45 Stalling at Traffic Lights in Hot Weather Austin Healey 20
F Hot Ignition Coil Austin Healey 6
T TR6 Perfectly tuned TR6 wont start when hot. Triumph 11
T General Tech Running hot Triumph 8
KVH TR4/4A Hard Start When Engine Hot Triumph 20
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
D Lumpy Idle When Hot Austin Healey 2
K TR2/3/3A Thermostat for hot summer driving? Triumph 1
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
7 General TR Hot rod Triumph 0
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
R General TR Emergency hot wire - because you never know whats next Triumph 2
K TR2/3/3A Hot day coolant overflow issue.... Triumph 1
F TR6 Pegged out hot while cold Triumph 7
sparkydave Trouble running hot Spridgets 10
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
K TR2/3/3A Front brake rotors hot to the touch...... Triumph 6
T 1993 xj v12 red hot catalytic converter Jaguar 6
M TR2/3/3A TR-3A Compresson check hot vs cold Triumph 5
Bob_Spidell Running hot/Overheating Austin Healey 44
G TR4/4A Flasher Unit...VERY hot Triumph 10
Got_All_4 General TR Anybody Hear or Use This Hot Spark System? Triumph 10
pkmh How hot can it [temperature gauge] get? Austin Healey 4
dougie DD300 Runing Hot Austin Healey 6
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
glemon Hot Shot Other Cars 5
D Been waiting for a hot day run Austin Healey 4
HighAltitudeTR3 TR2/3/3A Running a little hot... Triumph 14
J TR4/4A Too hot to drive a convertible Triumph 14
T Bj7 Overdrive slipping when hot Austin Healey 11
P 100M overdrive disengages on hot engine/transmission Austin Healey 9
F TR2/3/3A Starts Cold, Not Hot Triumph 12
M TR2/3/3A Why is my coil so hot? Triumph 6
D TR4/4A how hot does the timimg chain cover get? Triumph 15
F TR6 sticky valve when hot Triumph 4
Lutz Kramer Hot cams and advanced ignition Austin Healey 57
HealeyRick Hot Volvo Other Cars 0
simpzimmer Spitfire Won't suck gas when hot. Triumph 7
steveg Healey hot weather driving observations Austin Healey 2
bugedd Hot legs and hood top bow Spridgets 15
Geo Hahn TR4/4A Stumble off Idle with Hot Engine on Hot Days Triumph 4
N Jet Hot??? Spridgets 13
T TR2/3/3A Thermostats in Hot Summers and Moderate Winters Triumph 10
S Hot tip: seal for fuel tank sender Austin Healey 9
