Hot Ignition Coil
fmcdonald
My coil is reading 7 ohms. It was so hot I couldn’t touch it. When I put the old coil back on, the 3000 BJ8 started right up. Is the coil bad? What would cause it to heat up like that?
Offhand, I don't know if that's an issue; most coils have 1 or 2 ohms impedance, though some electronic ignitions--like Pertronix--spec a 3 Ohm coil (I think, don't quote me on that ;)). but I've run for years on (what I believe) are original coils in my BN2 and BJ8, both with Ignitors. Coils will heat up at idle, but shouldn't ever get 'pistol hot.' If a points gap is set up seriously too narrow the coil would heat up, but the car likely wouldn't run decently anyway.
Unfortunately, quality on aftermarket electronic parts has suffered for decades; last I checked, it's almost impossible to get quality points (for ignition and fuel pumps). Coils may not be an exception.
First thing I check is the distributor rotor; even easier to swap out. I only carry 3 or 4 spares.
Edit: Oops ... this was meant to be in response to Reid's post below; brain backfire on my part, or?
Editor_Reid
Platinum
A local mechanic says the first things to check when your Healey stops running are the coil and condenser. Replacing them very often solves the problem, and they're easy fixes! The problem now is that, as you say, there are so many issues with recently made electronic parts that the fix may not last.
Lutz Kramer Hot cams and advanced ignition Austin Healey 57
mrsprite Anyone use Hot-Spark ignition? Spridgets 6
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
Overdrive45 Stalling at Traffic Lights in Hot Weather Austin Healey 20
T TR6 Perfectly tuned TR6 wont start when hot. Triumph 11
T General Tech Running hot Triumph 8
KVH TR4/4A Hard Start When Engine Hot Triumph 20
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
D Lumpy Idle When Hot Austin Healey 2
K TR2/3/3A Thermostat for hot summer driving? Triumph 1
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
7 General TR Hot rod Triumph 0
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
R General TR Emergency hot wire - because you never know whats next Triumph 2
K TR2/3/3A Hot day coolant overflow issue.... Triumph 1
F TR6 Pegged out hot while cold Triumph 7
sparkydave Trouble running hot Spridgets 10
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
K TR2/3/3A Front brake rotors hot to the touch...... Triumph 6
T 1993 xj v12 red hot catalytic converter Jaguar 6
M TR2/3/3A TR-3A Compresson check hot vs cold Triumph 5
Bob_Spidell Running hot/Overheating Austin Healey 44
G TR4/4A Flasher Unit...VERY hot Triumph 10
Got_All_4 General TR Anybody Hear or Use This Hot Spark System? Triumph 10
pkmh How hot can it [temperature gauge] get? Austin Healey 4
dougie DD300 Runing Hot Austin Healey 6
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
glemon Hot Shot Other Cars 5
D Been waiting for a hot day run Austin Healey 4
HighAltitudeTR3 TR2/3/3A Running a little hot... Triumph 14
J TR4/4A Too hot to drive a convertible Triumph 14
T Bj7 Overdrive slipping when hot Austin Healey 11
P 100M overdrive disengages on hot engine/transmission Austin Healey 9
F TR2/3/3A Starts Cold, Not Hot Triumph 12
M TR2/3/3A Why is my coil so hot? Triumph 6
D TR4/4A how hot does the timimg chain cover get? Triumph 15
F TR6 sticky valve when hot Triumph 4
HealeyRick Hot Volvo Other Cars 0
simpzimmer Spitfire Won't suck gas when hot. Triumph 7
steveg Healey hot weather driving observations Austin Healey 2
bugedd Hot legs and hood top bow Spridgets 15
Geo Hahn TR4/4A Stumble off Idle with Hot Engine on Hot Days Triumph 4
N Jet Hot??? Spridgets 13
T TR2/3/3A Thermostats in Hot Summers and Moderate Winters Triumph 10
S Hot tip: seal for fuel tank sender Austin Healey 9
aeronca65t General TR Kastner Cup video walkthrough of hot pits Triumph 1
