simpzimmer
Thanks for all the help through the years. Recently, my Spit has quit on me a few times. Will start beautifully cold every time. I'll drive for a while, then stop and sit for an hour or so. When I start back up, it'll run for a few minutes, then stop completely. Assume it's burning what gas is in or near carb. When I remove the fuel hose at carb, there is no gas coming out when I turn over the engine. I can feel fumes coming out, but no liquid. The only way I've fixed is to siphon it up, resulting in a mouthful of gas, replace line and start. I've replaced the upper fuel lines thinking there might be a pinhole or something keeping it from pumping all the way to carb. Diaphram looks good. Strange that it only happens when it's hot, then cooled. Grabbing at straws, starting with easiest, I figure I'll replace fuel filter, pump, then tank??? Thought maybe carb had an issue inside??? Curious if anyone has any ideas??? Thanks, Greg
