Well it finally happened to me too. After a flawless 10-mile run - my first in about 3 weeks - I parked in my driveway, checked the oil and under the hood and tried to start to put back in the garage. Cranked over and over but no joy. Nothing. No spark. Points were almost closed so I adjusted to .014, replaced (almost new) condenser. Tried to test coil but Radio Shack multi-meter was apparently malfunctioning and readings were all over the lot and finally read 0L. 12V Battery in multimeter tested ok. I tried a spare coil (old) but still no luck. Fuel pump is working ok- when I squirted some starting fluid in the carbs, nothing happened. Now what? Another coil from Auto Zone? Another multimeter?Anything else I should check? I need help.
