Diesela won't go down...
Platinum
Driver's window motor has konked out, found a replacement on flea-bay. Got it yesterday but... wrong part. Ad said explicitly it was a 14-tooth left front door motor for the W123 chassis. NOT! What was in the box was an eight tooth one. Called the Miami vendor and had a surprisingly pleasant exchange with the parts manager of the outfit. Proper part is now being shipped. At the end of the conversation I mentioned I had a pal with a shop at the northeast end of the same street he was on the southwest part of. They are known to one another! I hope that may increase my chance of actually getting a working window motor. The Bosch version new is N.L.A.
JPSmit
been dreaming of a diesel W126 - stumbled across this guy:
https://mercedessource.com/
guy has 1000 or so youtube videos and seems to sell a lot of DIY stuff. (his premise is that it is a great car only if you can do most of the work yourself)
Platinum
Well, no replacement yet, got fed up and pulled the original out, spent time disassembling it. Brushes look fine, comm was a bit cruddy. Polished it with #1500 wet-or-dry, reassembled with the case 180° from original. Works FINE now.
The main reason this was done is that this AM I went to meet with my Breakfast Club, pre-dawn, saw the rear window a bit fogged up and hit what I thought was the rear window defroster. Hit the sunroof by mistake. It worked just enough to open the seal and then wouldn't CLOSE the durn'd thing. On returning, decided Diesela and I needed to spend some 'quality time' together.
About a month ago the trunk lock decided to be in the permanently locked mode. Got that opened by going thru the rear shelf by removing the toolkit and not unlike those carnival game crane machines to pick up prizes, spent about half an hour with a piece of 1"x2" and a drywall screw in one end fiddling with pulling the mechanism to a point where I could depress the outside button and get access to the trunk. Disabled the auto-lock gizmoid and now just a matter of using the key. Encouraged, I progressed to the window motor, leaving the sunroof for the last conundrum. Went to some M-B forum answers, most were discouraging, "remove headliner..." etc. I know these mechanisms, most all German cars of the era all used the same one, including Porsce/Audi and I had been trained at Lanham, MD to fix 'em. A real PITA! Sat for a bit, mumblin' to meself, then decided it may be prudent to look in the fusebox first. Spun the designated ceramic fuse a couple times with CRC 2-26 on the fuse tips. YEP!! Sunroof closed!
All-in-all a productive day.
waltesefalcon
Doc,
One of the problems I have found with bullet proof old cars is that it is all the nickel and dime stuff that drives you up the wall. My Cadillac starts every time and will go down the highway all day long without missing a beat, the drivetrain is neigh indestructible. I am, however, currently rebuilding the window regulators and taking apart all the window switches to clean up the contacts inside so that all the windows in my Caddy will go up and down without a little physical assistance. The switches were crimped and not meant to be opened up but new ones cost $65 a piece and they are made out of plastic so I will just clean up the original ones. Once this job is done I will begin working on the heating and air and the octopus of vacuum lines under the hood and dash that accompany the unit. Then I will move one to possibly the six way power seat that has decided no longer to move or the power top pump which needs a helping hand to make it all the way up or down, I'm not going to even worry about the remote trunk release (I just unhooked the vacuum line and use the key).
Platinum
Yeah, Walt, the Benz has had the A/C useless for a few years now. That's the main reason we now have the Camry. Herself actually has a J-O-B where she needs to dress for success... so Diesela is now my transport for work. Much prefer one of the LBC's but all have "issues" just now and the transfusion of cash has been nearly exhausted on the primary drivers. ARGH!
waltesefalcon
The Caddy hasn't had functional air since I've owned it and I can live without it since I only drive it with the top down in the summer. The heat though, that is another issue and it makes the car nearly unbearable to drive in the winter months. I do have a boring Toyota as my daily driver but soon I plan of ridding myself of it and relying on only my old vehicles to get around. Although I may decide I need a Miata or another LBC.
GeeBee1 A Boyfriend for Diesela? Other Cars 5
DrEntropy Diesela does th' Doc... Other Cars 5
DrEntropy Diesela has cold A/C! Other Cars 6
DrEntropy Diesela's Water Pump Other Cars 14
DrEntropy Today's Diesela adventure. Other Cars 19
DrEntropy Poor ol' Diesela! Other Cars 36
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
J MGB 1966 MGB won't start MG 1
B Healey Won't Start - No Spark Austin Healey 38
JPSmit you won't likely see another Spridgets 4
A Wedge Won't fire without jumper from coil to battery Triumph 6
B TR4/4A Head gasket won't lay flat Triumph 13
nichola TR6 GP3 Camshaft won't turn Triumph 8
John_Mc TR6 Front brakes won't release Triumph 20
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
60TR3A Driver's Door Won't Stay Open Austin Healey 1
60BN7 Adjustable Steering Column Won't Lock Austin Healey 9
Gerry M TR6 TR6 Won't Start Just Clicks Triumph 17
warwick-steve Brake shoes won't move back after releasing handbrake Austin Healey 8
KVH General TR TR4A Engine Won't Start Triumph 34
C TR6 Zenith Strombers won't start when warm. Triumph 2
A MGB Clutch won't disengage MG 4
C Strange...can won't start and then magically ressurects Austin Healey 16
P TR6 Car won't start after backing out of garage Triumph 21
Tinkerman TR2/3/3A 1960 TR3A post 60000. WON"T START ???????????????? Triumph 8
HealeyRick Wipers Won't Stop Spridgets 6
simpzimmer Spitfire Won't suck gas when hot. Triumph 7
J TR6 TR6 died/ won't start Triumph 30
2wrench TR6 Horny car just won't quit. On top of that, likes diesel. Go figure. Think mechanics Triumph 9
P TR6 Won't start after 10-mile run Triumph 21
D TR2/3/3A TR3 distributor won't budge Triumph 10
jfarris TR2/3/3A Rebuilt SU Carbs - Car Won't Start Triumph 7
P Doors won't stay open [1959 100-6] Austin Healey 16
P TR6 Heater knob won't come off Triumph 9
gbtr6 TR6 Top Cover On, won't go into first or second Triumph 6
R No, it won't start! Austin Healey 8
K TR2/3/3A Rear brake drum won't go on? Triumph 12
healeydan Windshield Seal Won't Lie Down Austin Healey 3
M '61 BN-7 Progressively Harder Starting . . . Now Won't Start Austin Healey 9
P Car won't start Austin Healey 7
S MGB Ignition Light and Fuel Pump Won't Quite! MG 5
J Engine won't turn off TVR 3
T TR2/3/3A My after market aluminum side curtains won't stay in on front top! Triumph 6
B TR2/3/3A Questions about that rocker cover I "won" on E bay Triumph 6
B TR2/3/3A I just "won" the TR3 grab bag on E Bay Triumph 7
H TR2/3/3A Hub Caps won't fit - TR3A Triumph 7
S 64 BJ8 won't start after 10 min. drive. Austin Healey 12
H TR2/3/3A TR3A Won't Start Triumph 15
doughairfield TR4/4A Fuel pump won't pump Triumph 5
M TR2/3/3A Car won't shut off with generator connected Triumph 6
