Low oil pressure
rovernut
Have Dads 74 1/2 Mgb GT up and running now with the new motor but the oil pressure is dangerously low i feel.......It starts up at 50-55 lbs and as it warms gets down to say 15........I know it is a new relief pressure spring in it and the oil pump is from his old motor which never gave him oil pressure trouble........Any other things i should be looking for.........I tried putting the pump in a pail of oil and hooking it up to a drill to see if it pumped good but it never did pump what i thought it should..........Only gurgled up a little /ubbthreads/images/graemlins/nopity.gif /ubbthreads/images/graemlins/canpatriot.GIF /ubbthreads/images/graemlins/confused.gif
Bruce74B
It sounds like to me that you know what the problem is...the pump...but are looking for an easy out??? /ubbthreads/images/graemlins/nopity.gif
Sorry, I have to agree here...it sounds like a bad pump. Replace it and you will have some peace of mind anyhow. /ubbthreads/images/graemlins/driving.gif
G
You say this was a rebuilt engine. Did you rebuild it? What about rod bearing and main bearing clearances. Did you check those with plastiguage?
Also I read somewhere that the stronger the spring on the relief valve, the lower the oil pressure will be. Some have made the mistake of stretching the spring and that makes the pressure lower. You can try finding a washer to fit the end of it so it won't go in as far and see if that raises the pressure.
G
I just looked in my Bently manual and it says the correct oil pressure is not below 50lbs at normal road speed and not below 15lbs at idle.
rovernut
rovernut
According to the book it says if the oil pressure is low the pressure relief spring is weak so putting a new one in should raise the pressure i would say......The engine has all new bearings, thrust washers, etc but no i did not check with plastigage........Why would that alter the oil pressure..........I,m assuming the pump is at fault but it worked right in the other motor.......I don,t recall him saying it ever dropped below 50 when running or idle but i,m not sure..........This car is more trouble than my Rover's have ever been but i've learned a lot /ubbthreads/images/graemlins/canpatriot.GIF /ubbthreads/images/graemlins/driving.gif
Mickey Richaud
Hi, RN -
Shot in the dark: Maybe your oil pressure gauge is off. You might want to hook another up to it, just to be sure.
Also, the plastigauge would tell if the clearance between the journals and the bearing surfaces are correct. Too much "air" between them will lower the pressure. Here's the way I relate it (though proper engineers may call me on this!): Think of a water hose, as you restrict the channel the water goes through, the pressure builds up. When the surfaces of the journals and bearing surfaces wear, pressure drops.
Mickey
aeronca65t
rn:
Low oil pressure can come from a worn pump but it can also come from loose internal engine clearances. If your car has new bearings but a worn crank, the excess clearance will allow low oil pressure, no matter how good the pump is.
By all means, check the gauge. If pressure is truly low, then you may want to replace the pump. But while you have the engine oil pan removed, you should check rod bearing and main bearing clearances. Using Plastigage is fairly easy and reasonably accurate for this purpose.
Salyers890
with risking sounding like an idiot - what kind of oil did you use? my car had the same prob and i put some heavier oil in and it solved the prob. . . . since you only have low pressure when it's hot, that could be it, as oil loses it's viscosity with heat.
V
vagt6
Rovernut, I like Mickey's advice about the gauge. I had the same problem, it was the gauge. Seen it in other LBCs as well. The gauges in these cars weren't up to today's standards, and they're pretty old, too.
Maybe you'll get lucky and it IS only the gauge. It's always a thrill to encounter an easy (and cheap) fix!
good luck!
Mickey Richaud
Hmmm...got me to thinking, Mark. My fresh rebuild shows well over 60 lbs. of pressure on the old gauge. Wonder if I ought to cross-check it?
Human nature being what it is, I suspect we would trust a gauge that shows us what we want to see more so than one which disappoints us!
Mickey
milomind
Your oil pressure should be just fine. Mine runs at exacty the same thing, 50-55 at acceleration, and 15-20 at idle. I drive mine every day.
rovernut
rovernut
Alot have said they're oil pressure is like this but it was higher with the old motor..........He's ordered a new pump and we'll see what we get .......Thanks
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
T TR6 Low Oil Pressure Light Triumph 3
HighAltitudeTR3 TR2/3/3A Oil Pressure low all of a sudden Triumph 10
2billydavies TR2/3/3A very low oil pressure when TR3a is warmed up Triumph 12
V Low Oil Pressure Triumph 4
H low oil pressure Austin Healey 15
Michael Oritt Low oil pressure kill switch Racing 8
L Low oil pressure in new engine Austin Healey 67
bighealeysource oil pressure in a BN6, too low or okay ? Austin Healey 21
nissanite E-Type V12 very low oil pressure - new rebuild Jaguar 11
CraigLandrum TR2/3/3A TR3 Low oil pressure [again!] Triumph 23
rlandrum TR2/3/3A TR3A Low Oil Pressure Solved Triumph 19
jmwuva05 Low oil pressure after spin on filter Spridgets 13
B oil consumption and low pressure Austin Healey 18
BOBBYR low oil pressure is common at idle Austin Healey 17
BOBBYR Low idle oil pressure Austin Healey 11
VelodromeRacer Low Oil pressure light installation Racing 10
A Hot-low oil pressure / Aux. oil line problem fixed Triumph 6
J low oil pressure MG 18
W jaguar low oil pressure Jaguar 4
D TR6 Re Low Oil Pressure Indicator on my TR 6 Triumph 1
D Low Oil Pressure Indicator Light Triumph 2
G Oil Pressure Too Low - Redux.... Triumph 2
G Oil pressure too low... Triumph 29
mondialo64 TR4/4A Was: tr4 low oil pressure Triumph 7
mondialo64 TR4/4A tr4 low oil pressure Triumph 7
C Low oil pressure Austin Healey 22
D Oil pressure low MG 8
G LOW OIL PRESSURE OR NOT? MG 1
vping Results of Low Dashpot oil MG 11
roscoe Low-Budget Luggage Rack Austin Healey 27
Donald1107 TR2/3/3A low cylinder compression Triumph 12
D Lucas Low-Tension Leads Austin Healey 1
CJRams For Sale 1974 Rolls Royce Silver Shadow - low mileage, all original Other British Classifieds 0
rgfrey 1959 Low Beam Headlights Not Working Austin Healey 5
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
Patrick67BJ8 Low-Profile Electric Puller Fans Austin Healey 51
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
F TR6 Sputtering at low rpm Triumph 16
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
Joe Schlosser Spedo reading low Spridgets 8
F TR6 Squeal When Turning Sharply at Low Speed Triumph 6
F TR6 Carburetor issues at low rpms webers Triumph 23
RAC68 Heavy Tapping low in the Engine Austin Healey 58
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
Geo Hahn TR6 Low Miles TR6 on eBay Triumph 4
K TR2/3/3A Volvo low profile space saver spare tire for TR3 ? Triumph 1
TomMull Volvo Low Rider spotted in Vassalboro Me Other Cars 1
RickPA Water temp gauge reads low Austin Healey 6
