TR2/3/3A Leaking SUs. Advice badly needed
PatGalvin
OK Guys. So, I had my SUs rebuilt a couple years ago and they sat in the box until I got ready to install them. They both leaked gas. I purchased Joe Curto's jet kits and installed. The front SU leaked still leaked through the connection between the bottom of the float bowl and the carb body. The rear SU leaked thru the jet. For the front SU, I purchased a new float bowl mounting stud (number 123 in attached graphic) and fiber washer (Number 124) from Moss. The existing stud looked like maybe it was deformed due to overtightening so I thought a new stud might seat better. I installed the stud with a little RectorSeal No. 5 which is fuel-resistant non-hardening pipe thread compound. The rubber seals that sandwich the float bowl mount were about 2 weeks old (Curto kit) so I didn't replace again.
The back carb was fitted with new cork jet locking gasket and two of the Moss O-Rings replacing the cork jet seals. It appears to have sealed up nicely so I'm pretty happy about that.
So, the front carb still leaks badly, at the connection between the carb float bowl and the carb body. I get a one drip per second . It is very difficult to tell where the drip is coming from but it is either the connection of the mounting stud to the carb or the rubber seals that sandwich the float bowl mount.
I really need to get this car leak free before next weekend. Can anyone provide suggestions as to how I can address this leak under the carb body at the float bowl mount? I'm open to any suggestions. Very perplexed...
Pat
sp53
I might suggest checking the thickness of the metal washer that goes on the stud for the bowl. If the washer is too thin, the nut will bottom/run out of threads on stud before it seals on the stud. You probably need a thicker washer on the stud.
PatGalvin
PatGalvin
Would it make sense to double up on the washer (either top or bottom) to increase the squeeze on the viton upper and lower gaskets. I really don't have any way of knowing if the crush on the viton seals is adequate, but I can say that the float bowl will rotate fore and aft a bit, when installed. So perhaps we do indeed need to add another washer or two?
Any other thoughts? Anyone have problems with the stud sealing on the carb body?
tinman58
Hey Pat!
Install a supercharger, problem solved.
Jerry
We bought parts 89 and 102 for Ian's MG TD which have the same carbs. That stopped the leak. The kit 89 includes all new brass parts so there was not too much slop, or , the slightly different pre-soaked seals in the kit worked.
Poor design, my old TR3 leaked all the time. took the paint off the car below the carbs.
Jerry
PAUL161
I'm sure you realize the bowl should not be able to be moved when the bolt is tightened and sealed properly.
PatGalvin
PatGalvin
I called Joe Curto this AM to see if he had any ideas. He recommended a couple things. First, the Viton grommets that hold the float bowl mount should be installed dry - no oil or lube should be used. If slippery, they may deform and not fit as intended. I used a little oil on mine and that is not a good idea. He is sending a little fiber washer that I can add below the steel washer (that sandwich the Viton grommets) to increase tension on the Viton grommets. Finally, he said that a little Permatex Aviation Gasket sealer can't hurt on the mounting stud and fiber washer to carb body connection.
Hoping these changes will make a tight seal. I'll let you know. And, I hope this is helpful to someone out there in LBC land.
Pat
TuffTR250
Pat, on my TR3 I put all new washers, etc, and it still leaked. I cut a washer shaped piece of gasket material from some gasket material I got at CarQuest and added that to the viton rubber seals and that stopped my leaks from the float chambers. Those viton seals are either too soft or not think enough. I tried the fiber washer's you're getting from Joe Curto and they did not help. They are too hard.
Regards,
Bob
PatGalvin
PatGalvin
Regards,
Bob
Thanks Bob. Do you remember approximately what thickness of washer/gasket material you used for the "spacer"?
Thanks for the tips.
pat
TuffTR250
I used Victor Reinz gasket material p/m JV127 from CarQuest. I measured it and it is about .032 inch thick. Using the Moss catalog as a reference, I found that the float bowl mounting bolt #115 did not work well at all. I went to stud #123 since It did not have to turn inside the viton seals in order to tighten it. Here is the sequence I used that was successful in stopping the leaks: from bottom up: 120, 121, 118, bowl flange, 118, 122, 123, 124, home made washer from JV127, bottom of carb.
If you have bolt #115, I'm not sure how to stop the leaks since I was not successful in stopping the leaks with that type mounting.
Good luck with it!
Regards,
Bob
PatGalvin
PatGalvin
Thanks very much for all the info Bob. I pulled the offending leaker last night and cleaned all the parts carefully with brake cleaner. I used a permatex Permashieldl product (similar to Hylomar) to seal the stud and fiber washer to the underbody of the carb. I reassembled the viton grommets dry, with no oil. I reinstalled and manually pumped the fuel pump to fill the bowl. No leaks yet. Was dry this morning when I was leaving for work. Let's see if it will stay dry....
The Permashield product seems just like Hylomar. And you can obtain it at FLAPS. Around ten bucks.
I'll report back after I run the car this weekend and see if it is leak free.
Pat
TuffTR250
Sounds good! The Permashield is sealing in the same place mine was leaking. I used the gasket material instead of a sealant at that spot.
Regards,
Bob
PatGalvin
PatGalvin
Hi Guys
Very old post, but update that I thought some of you may find useful. I was again having leakage from the float bowl mounting to the bottom of the carb body. Leaking at the two viton seals that crush around the float bowl mounting arm (that's what I'm calling it...).
I did two things to make this not leak any more. First, I bought new Viton seals and they are different than the ones I was using previously. The replacement Moss Viton seals are solid and don't have a groove cut into them. See attached photos. Solid seals crush a lot better and don't deform as much, holding the bowl much tighter. Second, I added a couple small shims (like very thin washers) to the top of the mounting stud, increasing the crush on the two washers. The combination of these two things made this very tight and leak free. I just added two 0.010 shims from McMaster Carr - Cost me $10 for the shims but I figured I'd keep adding them till I got the viton gasket crush I needed.
Hope this helps others that may be struggling with fuel leaks from this location.
Pat
007 (Medium).jpgthis viton bushing has a groove cut in it (from Joe Curto, I think).
006 (Medium).jpg This Viton Bushing is solid, like a garden hose washer.
008 (Medium).jpgMcMaster Carr Shim Set.
Brinkerhoff
Have you checked the aluminum sealing faces for scoring? Either side of the float bowl and the bottom of the carb body.. I don't remember having any leaking with mine at all.
PatGalvin
PatGalvin
Yep, sealing faces were clean and smooth. I just wasn't getting the compression I needed on the Viton bushings, especially with the grooved bushings. Hope this helps others, at some point.
pat
ronzet Fuel pumps, generators, and leaking SUs MG 10
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
S Leaking HD6 Rear Carb Austin Healey 10
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
G Twin HS4 Su's leaking fuel Spridgets 18
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
S TR2/3/3A rear main seal is leaking Triumph 13
R TR2/3/3A Leaking O.D. section of Transmission Triumph 43
E Oil leaking from the Tachometer cable Austin Healey 5
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
Jim_Gruber BE Steering Rack-Leaking 90w Spridgets 5
AUSMHLY BJ8 Rear Wheel Cylinder leaking Austin Healey 30
jfarris TR2/3/3A Leaking Fuel Pump Triumph 11
drooartz Leaking 5-speed drain plug Spridgets 26
S TR2/3/3A and the radiator was leaking. Triumph 7
H TR4/4A Leaking ft hub seals Triumph 5
D BT7 rear wheel leaking Austin Healey 25
N Leaking Carburettor Austin Healey 11
B MGB Hif’s Rear leaking gas MG 11
J TR4/4A Head leaking water Triumph 14
T TR4/4A Tr4A oil leaking from timing cover Triumph 13
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
C TR6 Brake servo leaking Triumph 3
RJS TR4/4A Head Leaking Coolant after Coolant Flush Triumph 15
R soft plug leaking Austin Healey 45
George Zeck Master Cyl Leaking .... Spridgets 5
M TR2/3/3A O/D brass cap leaking Triumph 5
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
rjc157 Leaking steering box Austin Healey 4
B mysterious leaking of SU HD8 Jaguar 9
F Leaking rocker/bable cover gasket BT7 Austin Healey 6
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
B Rear Engine Side Cover Leaking Austin Healey 9
D Overdrive Leaking Oil Austin Healey 4
KVH TR4/4A Oil Pressure Banjo Nut is Leaking Triumph 6
H TR2/3/3A Leaking Fuel Pump Sediment Bowl Triumph 5
J T-Series Leaking carburetor, old cork seal and new o ring seal MG 1
Michael Oritt Leaking oil pan Racing 8
T TR6 leaking carb TR6 Triumph 17
TRMark TR4/4A Leaking Drain Tap before I could even get the radiator full Triumph 1
Rob Glasgow Leaking tapered plug on head Austin Healey 8
Scotsman TR2/3/3A leaking front engine plate Triumph 4
bigbadbluetr6 TR6 Carb leaking Triumph 12
M TR2/3/3A Head gasket leaking in two places Triumph 13
