TR2/3/3A Leaking Fuel Pump Sediment Bowl
hit_n_miss
Member
Folks, My fuel pump is leaking at the top of the sediment bowl. I've installed a new cork gasket and gauze filter. I think the problem is insufficient pressure being applied by the star nut on the support bail.
The bail that supports the fuel pump sediment bowl (Part 23) appears to have a spacer that fits between the star nut and the bottom of the sediment bowl. It looks like it might be ~5/8” diameter with a through hole for the screw that the star nut runs up.
https://www.revingtontr.com/CatalogueImages/TR2/E.jpg
My bail is missing this piece (see attached). The result is that the star nut doesn’t apply enough pressure to the sediment bowl to seat it against the cork gasket (Part 25).
Can anyone confirm my suspicion regarding a missing spacer and supply the diameter, height, and material for that spacer? Thanks.
Arnie
Darrell_Walker
You are definitely missing a part. It is basically a pressed sheet metal cup. If no one posts dimensions before I get home, I think I have one on the shelf I can photograph/measure.
Crankshaft
Darrell will probably send some sizes for you. But if it were my garage I would look under the car. You might just find the missing cup there.
H
hit_n_miss
Member
Phil, I had the same thought and found a beat-up flat fiber disc ~1/8" thick that the PO had apparently used. It just balanced on the star nut when it was at the end of its travel. I'm going to make a better replacement. Thanks for the suggestion.
Geo Hahn
In addition to the missing bit, I have known bowls to leak because someone over-tightened the bale and caused the cast top to bow a bit. I was able to hammer it back to level and it sealed okay. It does not require a lot of force to seal the top of the bowl, especially if you are using a thick 'rubber' washer.
If you can't find the missing part on the floor... pmail me with your address and I'll send you one.
H
hit_n_miss
Member
Geo, Thanks so much for sending me that spare spacer. It arrived yesterday and will be fitted shortly. Arnie
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
jfarris TR2/3/3A Leaking Fuel Pump Triumph 11
D Leaking fuel pump connections Triumph 32
D Leaking fuel pump Spridgets 7
J New SU Fuel Pump - Gas leaking out of carb vents Austin Healey 24
N Fuel Pump Leaking MG 32
floyd leaking fuel pump Triumph 6
drooartz Leaking fuel pump Spridgets 36
G Twin HS4 Su's leaking fuel Spridgets 18
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
D Fuel leaking from carbon canister Triumph 6
T Fuel sediment bowl leaking madness Triumph 12
A Stromberg Leaking Fuel Triumph 9
B Flex Fuel Line Leaking Austin Healey 7
Q SU Carb Leaking fuel at top Spridgets 8
ronzet Fuel pumps, generators, and leaking SUs MG 10
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
S Leaking HD6 Rear Carb Austin Healey 10
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
S TR2/3/3A rear main seal is leaking Triumph 13
R TR2/3/3A Leaking O.D. section of Transmission Triumph 43
E Oil leaking from the Tachometer cable Austin Healey 5
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
Jim_Gruber BE Steering Rack-Leaking 90w Spridgets 5
AUSMHLY BJ8 Rear Wheel Cylinder leaking Austin Healey 30
drooartz Leaking 5-speed drain plug Spridgets 26
S TR2/3/3A and the radiator was leaking. Triumph 7
H TR4/4A Leaking ft hub seals Triumph 5
D BT7 rear wheel leaking Austin Healey 25
N Leaking Carburettor Austin Healey 11
B MGB Hif’s Rear leaking gas MG 11
J TR4/4A Head leaking water Triumph 14
T TR4/4A Tr4A oil leaking from timing cover Triumph 13
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
C TR6 Brake servo leaking Triumph 3
RJS TR4/4A Head Leaking Coolant after Coolant Flush Triumph 15
R soft plug leaking Austin Healey 45
George Zeck Master Cyl Leaking .... Spridgets 5
M TR2/3/3A O/D brass cap leaking Triumph 5
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
rjc157 Leaking steering box Austin Healey 4
B mysterious leaking of SU HD8 Jaguar 9
F Leaking rocker/bable cover gasket BT7 Austin Healey 6
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
B Rear Engine Side Cover Leaking Austin Healey 9
