Seal between transmission tunnel and the forward bulkhead
fishyboy
Hi all,
As part of my re-carpeting of my BT7 (www.britishcarforum.com/bcf/showthread.php?100227-Carpeting-Austin-Healey-3000-1961-BT7) I am looking for some advice on the vertical seal between the transmission tunnel and forward bulkhead. Andrea in one of his excellent photos (below) shows this as a single flap on rubber rived to the bulk head. However, Rick Crylser describes it a " black rubber draught excluder piece is riveted into position on this panel with flat split rivets. This is an inverted "U" shaped piece of rubber, not unlike inner tube rubber, which is so shaped to drape around the gearbox and therefore cut down most of the hot air flow from passing back into the gearbox and drive shaft tunnel area".
Who is correct? is it a flap or inverted "U" piece.
Given I cannot source a new piece I will have to make one. What is the best material (bicycle inner tube perhaps)?
Thanks
Phil
John Turney
Andrea's rubber piece is U shaped. I'm sure split rivets are correct.
Bicycle inner tubes are too small, too thin and will curve. You really should use a flat piece of rubber. It should be one piece, maybe 3/32" thick. You might get away with a truck inner tube.
TimK
This is my original BN7 seal. It is U-shaped and split rivited. I got an exact replacement from British Car Specialists
F
fishyboy
Tim
Thanks for the photo. The replacement does not appear to be available on this side of the pond. Ill try to fins some suitable rubber. Is the piece of rubber just fixed along in inner edge of the firewall? or are both free-ends of the U fixed. I assume the carpet is then glued ontop of the riveted rubber.
Phil
TimK
The carpet is glued to the other side of the small bulkhead over the rivet heads, not the rubber. The rubber is on the "inside" of the small bulkhead. The rivet heads are on the "outside". I don't understand your questions about the fixing of the rubber. I believe there are 6 rivets which fix the whole length of the rubber. But just do what makes sense to hold it in place. When the trans is installed, re-fit the small bulkhead with the rubber riveted in place and it will seal it. The carpeting will complete the job.
I can't resist adding that no one but you will know what materials or fastening you have used. Do what works for you.
F
fishyboy
Tim and Jedi
Many thanks. All now sorted.I was assuming the "U" shape was referring to the profile rather than the shape of the rubber sheet.
Phil
P Is there a seal between the drain channel and drain box? Austin Healey 8
GTP1960 TR2/3/3A Weather seal between apron & wings? Triumph 4
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
B TR6 Crankshaft long seal surface Triumph 5
Michael Oritt Rear Crank Seal Kit Austin Healey 7
Got_All_4 TR6 Seal To Body Mounting Bracket Welded? Triumph 7
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
D Top Door rubber and fuzzy seal Spridgets 5
J Rear Main Seal Kit Austin Healey 1
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
D MG Midget 1275 rear oil seal. Spridgets 0
A Rear Axle Oil Seal Austin Healey 4
Bayless Door seal question Spridgets 3
B BJ8 Hood Bow and Seal Austin Healey 5
D Door Seal Fit Austin Healey 18
W Rear Axle Hub Seal Austin Healey 8
W Crankshaft Oil Seal Austin Healey 3
edkap2002 TR6 TR6 rear pinion seal Triumph 3
Patrick67BJ8 Weatherstripping Seal & Caps for BJ8 Austin Healey 6
DrEntropy Shift rod seal in an automatic? Jaguar 7
TR6Canuck TR6 TR6 waist seal clips - which side goes on which part? Triumph 6
Joel Lester TR2/3/3A What size speedi-sleeve needed for pinion seal on a TR3? Triumph 6
S TR2/3/3A rear main seal is leaking Triumph 13
Csarneson Head Gasket Seal Austin Healey 6
Michael Oritt 100 Windshield seal Austin Healey 0
chicken BJ7 Door Seal Austin Healey 5
K TR2/3/3A Front Hub and Felt Seal Triumph 1
Basil Spitfire Hard Top Seal Triumph 5
B Fitting the Boot Lid Seal Austin Healey 8
chicken Inner Door Seal Trim Position Austin Healey 6
S Bugeye Windshield Seal Austin Healey 1
T Early BJ7 Vent Window Seal Austin Healey 2
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Healey Nut Hardtop-to-Shroud Seal Austin Healey 12
71TR6 TR2/3/3A TR3A Drive shaft cork seal Triumph 10
EWD TR6 Rear Transmission Seal 74 TR6 Triumph 4
EWD TR6 Transmission Oil Seal Triumph 13
nichola TR6 Transmission front seal replacement question Triumph 8
T Windscreen wiper wheelbox rubber shaft seal Austin Healey 4
B BT7 Door Seal Installation Austin Healey 13
J Gearbox front cover seal Spridgets 2
S TR2/3/3A door seal windlace Triumph 8
S TR4/4A door seal channels Triumph 3
Jim_Stevens TR2/3/3A Marx Viton rear engine seal Triumph 4
Rut Windshield rubber seal Spridgets 6
luke44 TR2/3/3A TR3 pinion seal - leaked from sitting will it reseal? Triumph 12
S TR2/3/3A rubber seal go towards the inside of the trunk Triumph 3
JFS TR6 Rear Oil Seal? Triumph 1
