Tinkerman
I have three holes in the top of the tranny tunnel.
one is for the gear shift and one is an is a rubber plugged hole but gives me access to the universal joint.
The third hole is right at the front and is 1/2" in diameter too small for a grommet . I'm guessing it is the battery box drain tube exit. If so then how do I get my OD wiring into the OD?
Thanks, Tinkerman
Thanks, Tinkerman
