TR2/3/3A 1960 TR3A oil leak issue [imagine that!]
TFR
I am having an issue with excessive oil leaking from the back of the Atype tranny drive shaft mounting bracket and also the differential bracket. They leak through the splines past the nut and washer. Is there a trick to seal these connections?
I understand Triumphs leak, but this is excessive.
Any ideas would be appreciated.
TR4nut
Larry-
Think I have the same problem on the differential if I understand you correctly - when I pulled the driveshaft to change out the u joints, I was really surprised to get a large puddle of oil when I separated the flanges. Didn't fix it (yet), but I'm wondering if a little judicious use of something like a Permatex nonhardening sealer on the splines would help. I don't think there is a pressure differential to contend with so in theory it shouldn't be hard to stop. In theory anyway!
Randy
T
TFR
Randy,
It is exactly what I'm asking about. It is terrible to see so much oil leak on the ground. I've started putting a remnant carpet to catch it.
I just installed the new style rear main seal to help reduce the engine oil leak. Now to the parts that not supposed to leak.
Thanks for your post and if you figure out something post back again.
I also see you have a TR3A project. If you need any parts or information let me know
TR4nut
Larry-
I'm search challenged on the forum, otherwise I'd point to a post where I mentioned the oil puddle about 6 months or so ago. Might be worth a search. There was discussion confirming it happens, but I can't remember if there was a solution - might have been the one I suggested already if it was stuck in my subconscious toolbox.
Randy
Geo Hahn
If I understand your description then your diff leak sounds like the pinion seal -- a pretty common leak on TRs I think. Well at least common on mine.
A search of the archives will yield some of the creative ways (seal pullers, slide hammers, etc) that have been used to yank out that seal. I'll be looking there myself real soon.
prb51
Geo,
Don't forget your flange speedi sleeve, not a drop since it's use on pretty good looking flange surface (dif pinion).
On the other issue you need to put a thin sealant coating behind the washer around the splines where they mate the flange, a non hardening oil resistant material. I did that and no leaks from the splines (but the new rear seal leaked like it wasn't there).
Better yet, try a Toyota 5 speed, no leaks at all.
Tinkerman TR2/3/3A Major oil leak from original oil filter system 1960 TR3A post 600000 series Triumph 3
W For Sale 1960 TR3A for sale Triumph Classifieds 0
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
A TR2/3/3A 1960 TR3A front brake dust covers Triumph 5
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
Tinkerman TR2/3/3A Hood stick assembly 1960 tr3a Triumph 7
Tinkerman TR2/3/3A 1960 TR3A engine compression question. Triumph 7
Tinkerman TR2/3/3A Rebuilding SU carbs 1960 TR3A Triumph 3
Tinkerman TR2/3/3A 1960 TR3A post 60000. WON"T START ???????????????? Triumph 8
Tinkerman TR2/3/3A 1960 TR3A Boot rubber seal installation? Triumph 7
Tinkerman TR2/3/3A 1960 tr3a sheet metal fitment Triumph 6
Tinkerman TR2/3/3A 1960 TR3A carpet installation Triumph 5
Tinkerman TR2/3/3A 1960 TR3A Tonneau Capping Installation Triumph 1
Tinkerman TR2/3/3A 1960 TR3A Tonneau Trim Mill board Triumph 10
M_Pied_Lourd TR2/3/3A 1960 Triumph TR3A Trunk Seal Orientation Triumph 6
Tinkerman TR2/3/3A Prepping the grill for installation for my 1960 TR3A Triumph 1
Tinkerman TR2/3/3A Sealing fender to body 1960 TR3A Triumph 15
Tinkerman TR2/3/3A Windscreen mounting tips 1960 TR3A Triumph 2
Tinkerman TR2/3/3A 1960 TR3A Bottom Rubber Seal on the Windscreen Triumph 3
Tinkerman TR2/3/3A Tunnel installation question 1960 TR3A Triumph 11
Tinkerman TR2/3/3A Another Freeby from the past. For a 1960 TR3A Gas Tank Triumph 4
Tinkerman TR2/3/3A 1960 TR3A Holes in the tranny tunnel Triumph 11
Tinkerman TR2/3/3A Carpet underlayment, TR3A 1960 Triumph 10
D TR2/3/3A 1960 TR3a front suspension Triumph 2
Tinkerman TR2/3/3A Front windscreen help needed. TR3A 1960 Triumph 9
D TR2/3/3A fitting windshield/frame to 1960 Tr3a & Brooklands screen removal Triumph 2
Tinkerman TR2/3/3A TR3A 1960 Gas on three out of four plugs ? Triumph 6
Tinkerman TR2/3/3A 1960 TR3A post 60,000 series seat pan covering Triumph 3
Tinkerman TR2/3/3A 1960 TR3A seat tack strips Triumph 1
Got_All_4 TR2/3/3A Finish on a 1960 TR3A Fluid reservoir? Triumph 6
60TR3A TR2/3/3A 1960 TR3A Small Mouth [Huh?] on eBay Triumph 63
M_Pied_Lourd TR2/3/3A 1960 TR3A Mystery G Triumph 24
Tinkerman TR2/3/3A 1960 TR3A Instrument Cluster Ground Post Screw Triumph 9
M_Pied_Lourd TR2/3/3A Restoration of TS 69891LO 1960 TR3A Triumph 36
T TR2/3/3A 1960 TR3A engine compartment color Triumph 8
PAUL161 TR2/3/3A Colonal Tom Parkers 1960 TR3a For Sale! Triumph 3
T TR2/3/3A 1960 TR3A now with rack and pinion Triumph 22
Tinkerman TR2/3/3A Bulkhead Sealer Plate TR3A 1960 Triumph 3
D TR2/3/3A 1960 TR3A Paint Question Triumph 24
gubba TR4/4A 1960 TR3A with tr4 motor and tranny? Triumph 22
D TR2/3/3A 1960 TR3A Flasher Triumph 7
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
