TR2/3/3A 1960 TR3A Flasher
Dave Sutherland
This is my first post to this board. I have read many threads that have helped me with my current project - 1960 TR3A. I normally restore Corvettes but a sportscar collection would not be complete without a few classic British cars. Well, here is my problem I hope someone can help me out with. I am in the process of reassembling the TR3A (Frame on restoration) and cannot get the turn signal to work properly. The wiring harness and control head is new. When I activate the turn signal, the flasher unit basically vibrates with the turn signal lights pulsating. The flasher unit is from Moss and is new. I thought it maybe defective so I purchased another one and it does the same thing. I installed the flasher unit on a friends TR and it worked fine. I am puzzled. I tried a bussman 550 flasher and it works but does not light up the dashboard signal indicator.
Any suggestions would greatly appreciated.
[ 04-23-2004: Message edited by: Dave Sutherland ]</p>
piman
Hello Dave,
if I understand you correctly, pulsating equals a very high flash rate? Is it the same on both sides?
If it is an original type flasher relay the speed of flash is proportional to the current through it. If there is some leakage or direct short to earth (ground) then the unit could flash very quickly. If it is both sides then it must be between the column switch and the flasher relay.
Alec
sammyb
Curiously, I'm a Corvette/Triumph guy too, and I've had problems with my TR3's flasher, as well.
In my case, the lights are fine, but the dash indicator doesn't work. (The signal relay is bad -- no power to the dash indicator prong.)
In your case, I'd also check for a bad ground...maybe you have paint covering a ground wire-to-body connection?
What Corvettes do you own?
Dave Sutherland
All grounds are good and the dash indicator light is in working order. As to the Corvettes, I have a 1969 427 Tripower convertible and a 1971 350 coupe.
martx-5
I looked over the wiring diagram, and everything is pretty straight forward. The three prong flasher unit has the middle prong going to the dash indicator light, make sure that's where it's going. If that's OK, then I would try switching the other two wires and see if this changes anything.
[ 04-23-2004: Message edited by: martx-5 ]</p>
sammyb
Dave,
It's good to see there's another person keeping both a '69 tripower convertible and a TR3 in their stable. While my TR3 is totally stock, my '69 Vette no longer has the solid lifter 427 and tripower(drat!!!) It now has a 498hp 454 bored-out to who knows what. It's faster than an original 435, but I'd trade that engine (and my left you-know-what) for that original engine back. The tripower just looks so cool!
MDCanaday
A while back I needed a new flasher in my tr4. I purchased a new OTC and it did not work in that the lamp on the dash was lit at all times and only flashed when activated.I tried to get a different brand but they were all made by the same outfit and all behaved alike. finally found a good old lucas unit(off a 61 Jag), put it in and was back to good order. Needless to say, since modern cars no longer use this type of flasher, there is very little quality controll on what is now made.
Go back to the Lucas unit.
MD(mad dog)
W For Sale 1960 TR3A for sale Triumph Classifieds 0
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
A TR2/3/3A 1960 TR3A front brake dust covers Triumph 5
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
Tinkerman TR2/3/3A Hood stick assembly 1960 tr3a Triumph 7
Tinkerman TR2/3/3A 1960 TR3A engine compression question. Triumph 7
Tinkerman TR2/3/3A Rebuilding SU carbs 1960 TR3A Triumph 3
Tinkerman TR2/3/3A 1960 TR3A post 60000. WON"T START ???????????????? Triumph 8
Tinkerman TR2/3/3A 1960 TR3A Boot rubber seal installation? Triumph 7
Tinkerman TR2/3/3A 1960 tr3a sheet metal fitment Triumph 6
Tinkerman TR2/3/3A 1960 TR3A carpet installation Triumph 5
Tinkerman TR2/3/3A 1960 TR3A Tonneau Capping Installation Triumph 1
Tinkerman TR2/3/3A 1960 TR3A Tonneau Trim Mill board Triumph 10
M_Pied_Lourd TR2/3/3A 1960 Triumph TR3A Trunk Seal Orientation Triumph 6
Tinkerman TR2/3/3A Prepping the grill for installation for my 1960 TR3A Triumph 1
Tinkerman TR2/3/3A Sealing fender to body 1960 TR3A Triumph 15
Tinkerman TR2/3/3A Windscreen mounting tips 1960 TR3A Triumph 2
Tinkerman TR2/3/3A 1960 TR3A Bottom Rubber Seal on the Windscreen Triumph 3
Tinkerman TR2/3/3A Tunnel installation question 1960 TR3A Triumph 11
Tinkerman TR2/3/3A Another Freeby from the past. For a 1960 TR3A Gas Tank Triumph 4
Tinkerman TR2/3/3A 1960 TR3A Holes in the tranny tunnel Triumph 11
Tinkerman TR2/3/3A Carpet underlayment, TR3A 1960 Triumph 10
Tinkerman TR2/3/3A Major oil leak from original oil filter system 1960 TR3A post 600000 series Triumph 3
D TR2/3/3A 1960 TR3a front suspension Triumph 2
Tinkerman TR2/3/3A Front windscreen help needed. TR3A 1960 Triumph 9
D TR2/3/3A fitting windshield/frame to 1960 Tr3a & Brooklands screen removal Triumph 2
Tinkerman TR2/3/3A TR3A 1960 Gas on three out of four plugs ? Triumph 6
Tinkerman TR2/3/3A 1960 TR3A post 60,000 series seat pan covering Triumph 3
Tinkerman TR2/3/3A 1960 TR3A seat tack strips Triumph 1
Got_All_4 TR2/3/3A Finish on a 1960 TR3A Fluid reservoir? Triumph 6
60TR3A TR2/3/3A 1960 TR3A Small Mouth [Huh?] on eBay Triumph 63
M_Pied_Lourd TR2/3/3A 1960 TR3A Mystery G Triumph 24
Tinkerman TR2/3/3A 1960 TR3A Instrument Cluster Ground Post Screw Triumph 9
M_Pied_Lourd TR2/3/3A Restoration of TS 69891LO 1960 TR3A Triumph 36
T TR2/3/3A 1960 TR3A oil leak issue [imagine that!] Triumph 5
T TR2/3/3A 1960 TR3A engine compartment color Triumph 8
PAUL161 TR2/3/3A Colonal Tom Parkers 1960 TR3a For Sale! Triumph 3
T TR2/3/3A 1960 TR3A now with rack and pinion Triumph 22
Tinkerman TR2/3/3A Bulkhead Sealer Plate TR3A 1960 Triumph 3
D TR2/3/3A 1960 TR3A Paint Question Triumph 24
gubba TR4/4A 1960 TR3A with tr4 motor and tranny? Triumph 22
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
