TR2/3/3A Windscreen mounting tips 1960 TR3A
Tinkerman
I'm going to be installing the windscreen on my '60 TR 3A this weekend. Any tips and or danger points I need to know about? I will hav3 an extra set of hands for the job, but I have never installed one prior to now so any info, hints and look out fors would be greatly appreciated!
I do know about the short/long screw danger.
Thanks, Tinkerman
CJD
It's not difficult, just go slow with one person on each side. I used a vinyl tape on the inside of the frames to prevent scratching, and chafing after the installation.
sp53
Depending on the car they can be a real pain. I like doing the dzus much better. Like John suggest put some protective tape around the danger areas. I have experienced very tight fits. Once I put a thin gasket between the paint and the bracket and that push the bracket out too far and the frame would not go on. Moreover make sure you have chased the screws in and out of the body tub a few times to have a clear path for the screw and some tapered guide pins/shafts will let you pry around some and hold it will you get the 4 screws started.
T TR2/3/3A Windscreen Mounting Question Triumph 11
Tinkerman TR2/3/3A Windscreen stanchion mounting question Triumph 3
B Windscreen Motor Repair Restoration & Tools 6
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
RCarr Windscreen Glass Options Austin Healey 2
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
B Windscreen Pillar/Quarter Light Relationship Austin Healey 2
W Tudor windscreen washer bottles Spridgets 0
Popeye TR4/4A Tonneau snaps by windscreen Triumph 2
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
K TR2/3/3A I saw a 59 TR3 today with an aluminium windscreen! Triumph 5
A MGB MGB 1974 windscreen centre rod replacement MG 5
71TR6 TR2/3/3A New Windscreen Glass quality Triumph 6
Csarneson BN4 Windscreen Washer Jet Austin Healey 3
71TR6 TR2/3/3A TR3 windscreen frame corner bracket screw thread Triumph 9
LAW75 Repairing Windscreen Scratches Austin Healey 10
Healey Nut BT7 Windscreen Pillars Austin Healey 4
MGTF1250Dave T-Series TF Windscreen Wiper wiring MG 4
G windscreen problem Spridgets 1
T Windscreen wiper wheelbox rubber shaft seal Austin Healey 4
M Windscreen Wipers Parking Spridgets 4
M General MG Magnette windscreen washers MG 1
B TR2/3/3A Windscreen galss replacement Triumph 5
R Windscreen Glass Austin Healey 6
hondo402000 TR6 TR6 Windscreen remove and now windows dont fit Triumph 3
J Wanted TR3 Windscreen guide plates Triumph Classifieds 7
R BJ8 Windscreen Change Austin Healey 2
C Folding Windscreen Austin Healey 20
P For Sale tr6 windscreen Triumph Classifieds 0
4tecdog Windscreen rail to hood seal Austin Healey 11
bugedd Measurement of windscreen glass Spridgets 7
K TR2/3/3A Windscreen seal Triumph 16
4tecdog Frogeye Windscreen Spridgets 3
Jim_Gruber Free Spridget Windscreen available - Dayton OH Spridgets 3
K Windscreen Washer Question Austin Healey 26
M TR4/4A Windscreen capping Triumph 0
G TR4/4A Inside Windscreen Capping Triumph 6
B Windscreen washer pump upgrade Austin Healey 10
P TR2/3/3A TR3A Scuttle/Windscreen Stanchion questions Triumph 12
CJD TR2/3/3A Windscreen Tenax Triumph 22
B TR6 Windscreen removal advice Triumph 10
NutmegCT T-Series windscreen glass? MG 8
TRMark TR4/4A Installing a new windscreen Triumph 9
Bugeyze BN4 Windscreen Shims? Austin Healey 13
bugedd Windscreen glass question Spridgets 0
TRMark TR4/4A Top Tint Windscreen Triumph 0
bugedd Windscreen and top fitment issue Spridgets 16
B Mini Windscreen Wiper Parking British Motor Corp 3
O TR2/3/3A Windscreen Triumph 8
