PaulLongBl
Member
As I understand from the www the tr3 had a few different changes to its windscreen mounting. My TR3A (TS66256) windscreen was bolted directly to the body scuttle and did not have any of the stanchion guides (I'm assuming this is original). However, the two sides of the mount area are not identical. The passenger side is rounded where as the drivers side seems to have been pressed. As I understand all the TR3s body scuttles were rounded and not pressed in. Would like to tap everyone's expertise on the difference as well as if it's not supposed to be what would be their best approach in removing pressed in area, using a dent puller, cutting out the area and beating it out and rewelding (limited welding expertise)? As you will see in the pictures both sides are different and you will also not the nutplate that fell out on the pressed in side.
Thanks
Thanks
