TR4/4A Cutting an access panel into transmission tunnel cover for solenoid adjustment
tdskip
Hi guys - anyone ever cut an access panel into their AS plastic transmission tunnel on their TR4a? Ideas is to make getting to the solenoid for adjustment much easier rather than having to remove the whole tunnel.
poolboy
A TR6....I did make access holes for the speedometer cable replacement and that upper fastener for the starter.
poolboy
I'm trying to remember if it's "Rattle Trap" or some self adhesive heat shield material that I got from Jegs, Tom, one or the other.
KVH
I have an alternative based on some advice here, as usual.
OK, everyone has their favorite ways and means. For me, I did not want to carve up my vintage tunnel. Don't forget, fitting that 3/16 "bit" into the adjusting arm on the passenger side also requires room. What I did was drill a small hole in the tunnel on that side so that I could move the carpet aside and slide a bit in there for the adjustment. Then, on the driver's side I took some advice from Randall (anyone done that?) and replaced the bolt on the pinch fitting on the operating shaft (solenoid side) with an Allen head screw so that I could tighten and adjust from underneath. So far, all has been great, and I adjusted lying on my back and with the tunnel left on.
TR3driver
Great Pumpkin - R.I.P
Here's a couple of photos of my setup (shown on a spare OD)
On my TR3, I found that I could maneuver a short length of 3/16" rod into the hole with needle nose pliers, so no need to cut a hole there either. The length was important, just barely short enough to fit between the lever and the cover; plus I had to be careful not to push it all the way in (so there was still enough sticking out to grab for removal).
TRMark
Bronze
I sliced the cover and riveted a piece of aluminum flat stock to the main cover sealed with automotive silicon. I let the silicon dry on the exposed side of the flange to form a gasket of sorts and fit the rear piece on the flange. Seems to seal well enough. Other side shown in my photo page on the BCF
attachment.php
T
tdskip
Interesting guys, thanks. I'm debating sectioning the tunnel similar to Mark, would seem to provide good access. Anything you'd do differently Mark? Anyone else with pro/con ideas to that?
Thanks!
TRMark
Bronze
Thanks!
No, it seems to work fine, not exactly elegant but the carpet covers it. If you look on my photo page on the BCF you will see the photo of the other side where I used a sheet metal screw to secure the bottom near the cut.
Geo Hahn
On the drivers side I cut a hole for serving the solenoid and another for accessing the fill plug.
On the passenger side I did one for the angle drive and adjustment (don't seem to have a photo.
The fill plug hole is covered with the usual TR rubber plug, the other two with plates formed from sheet aluminum.
B Any issue with cutting this weld on the spring base plates? Spridgets 4
S TR2/3/3A Cutting the finish end on the windshield top rubber Triumph 4
Jim_Gruber Bugsy IV - Painting, Cutting, Buffing is done Spridgets 20
RAC68 Cost of Cutting Down an American Rear Austin Healey 12
55modified Wanted Wanted rough BN1/2 hood for cutting up Austin Healey Classifieds 0
Rut Cutting disc caution Spridgets 8
Got_All_4 Wedge 1980 TR7 PI cutting out Triumph 4
T TR4/4A New switch plinth - cutting holes Triumph 8
B MGB MGB tachometer erratic, engine cutting out.... MG 11
B TR6 'Cutting-down' a TR6 distributor ? Triumph 26
Willie_P Triumph cutting coil springs?? Triumph 36
RickB Midget w Datsun running gear cutting out suddenly Spridgets 19
TR_JOE250 TR6 Cutting up TR6 for body panels Help! Triumph 5
Tabcon Cutting out eyebrows on the cylinder liners? Racing 1
S Metal Cutting Restoration & Tools 9
ronzet So, OK, Cutting corners.... MG 17
C 1500 electrical cutting out Triumph 18
Bruce_B Cutting the car for a dual MC setup hints/tricks? Spridgets 23
T need a cutting oil Triumph 16
spiny Tips needed on cutting out and replacing sills Spridgets 32
G Cutting out floorboards with a RotoZip tool..... Triumph 34
David_DuBois Cutting back on coffee MG 7
D Engine cutting out Spridgets 17
Michael Oritt Fuel pump circuit cutting out on start up Austin Healey 40
mondialo64 TR4/4A TR4 Body cutting oversize mags Ideas? Triumph 9
A Cutting S.S. Braided Hoses Triumph 4
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
F TR4/4A Speedometer cable replacement access Triumph 0
R difficult bolt access Spridgets 8
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
A Timing cover access Spridgets 6
HealeyPassion AH Carb Access panel Austin Healey 24
jfarris TR2/3/3A Access to trafficator Triumph 5
Michael Oritt Brake Master Cylinder access Austin Healey 0
X BE jacking tube access holes and top bows. Spridgets 1
4tecdog Access to remove Ariel Austin Healey 15
R TR2/3/3A TR2/TR3 transmission dip stick access Triumph 10
RAC68 Dash Lighting [cost and access of incandescent Bulbs] Austin Healey 37
nevets Access to overdrive solenoid and switch Austin Healey 5
trotti Access to the clutch slave cylinder bleed screw Austin Healey 41
T TR4/4A Access to a professional sandblasting set up - why the heck did I wait so long... Triumph 4
T Hold Down Straps for BN-1 Battery Access Door Austin Healey 4
PSJ '53 100 - lifter access Austin Healey 8
S Transmission Bolt Access Austin Healey 26
3798j MGA Side Curtain Access MG 1
KVH How do I Access All the Albums and Member Pics FORUM Navigation Questions 1
G TR2/3/3A Tr3 Access Needed to Replace Speedometer to Overdrive Triumph 2
Nelson Vacuum reading access Spridgets 3
This14u Spitfire Clutch Slave Access on Late Spit Triumph 0
D T-Series Access to ignition switch '68 MGB MG 9
