MGB MGB tachometer erratic, engine cutting out....
borjis
It does this when it's cold from a first start.
Tachometer seems to be cutting out (never gets to zero before bouncing back up) and the engine does to.
The same time this began also I noticed it would not start by the first few seconds, some times it takes two or 3 tries before starting.
Once the car is fully warmed up it hardly ever does it again.
I've checked:
coil connections, no wires are touching each other externally.
cap, rotor, points, plugs all look good.
I have a gold lucas sport coil....possible it's going south?
thoughts?
Bob60
Member
One of my previous MGB's displayed almost this exact problem.
In the wiring under the dash on the drivers side is a 4-way connector with 4 white wires. One of these is the tach, one is ignition, one is fuel pump, not sure what the other is, maybe just hot. The rubber 4-way connector had a small split - just enough to not hold good pressure on the little metal connector inside. Occasionally - going over a bump, my knee brushing it, even going downhill sometimes was just enough to allow the wires to momentarily loose good connection. The tach would drop toward 0, the ignition would die, but almost instantly, apparently the wires make connection and everything returned to normal.
Took me forever to figure that out. Replaced the 4-way connector with one from my parts stash - fixed in about 2 minutes for $0.
Might not be your problem, but check it out.
Bob
B
borjis
Thanks for the Suggesion Bob.
Looks like that connector is just fine.
I've also tried swapping out the spark plugs, ignition coil and the distributor rotor.
Still has the problem.
I'm stumped on this one.
Jacmo
Member
Maybe it's time to check all ground connections. Give them a good cleaning. What about the engine ground strap?
Tim_Creger
Member
I had a '59 Sprite that did this until I found and fixed air leaks in the throttle linkage going into the carbs. The easiest way to diagnose air leaks is to get the car started and idling, then carefully spray a little starting fluid or brake cleaner around the surfaces where the carbs bolt onto the intake manifold - any place where air can get in after the gas is introduced to the carbs. In my case, the tachometer was only showing me what the engine was doing, it wasn't a problem with the tach electronics.
Tim
B
borjis
Jacmo, that's what other locals are telling me...investigate those ground points.
Car is in the winter storage now, but I'll try that come spring and report back on this thread.
Thanks for the words Tim. I'm fairly positive it's not that since I'm using a fairly new Weber down draft...that and the erratic tack and cutting out seem electrical.
Platinum
Look to the points again. Some #600 wet-or-dry run thru 'em when closed.
"Schmaze" build-up on the contacts will do what you describe.
B
borjis
OK, so it's been getting warmer these past few days so I decided to get this problem tackled, and tackled I did!
What I've learned from this experience is if the car is having very odd behavior its quite possible multiple issues are causing it and that was the case.
1. my distributor was a little loose. not super loose, but loose enough to make it rotate on a nudge.
2. my points...were also loose. they were not fully opening, just opening a hairline, that was the root of the problem.
as a result of #1 my timing was way off, thats why the car had such a hard time starting.
the car running really bad and tachometer erratic was caused by #2 and just reared itself last august.
so I got out the timing light, re-adjusted the points to a gap of .025 and now the car starts on the first crank and idle's fantastically at 900 rpm. It revs smoothly and no erratic tach now.
thats all folks.
aeronca65t
Good to hear it's running well.
Just FYI:
The points gap on those is 0.015"
The spark plug gap is 0.025"
Platinum
:iagree: The points gap was always a matchbook task in the old days if ya got caught out without your feeler gauges... 0.015" or "close enuff fer gummint work!" :jester:
And be aware not to over-tighten the dizzy clamp. If ya do, the housing will crack and MORE issues will ensue.
B
borjis
ah ok thanks guys.
I'll put the points to .015 then
thanks for the tip on the dizzy clamp.
with a slight force it would turn,(the distributor)
I turned the dizzy clamp nut 3 revolutions to tighten
it. not super tight, but it easily turned.
E MGB Tachometer 65 mgb MG 5
1 MGB Speedometer and tachometer on '66 MGB are not working MG 8
R MGB MGB Tachometer MG 12
T MGB 1973 MGB stuck tachometer MG 4
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 7
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
VeeCee MGB 1974 MGB Roof Installation MG 0
J MGB Just bought a 1966 MGB MG 50
T MGB MGB hoses MG 6
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
DrEntropy MGB Good video on the MGB MG 0
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
J Wanted 1969 MGB Roadster sun visor clip MG Classifieds 4
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
R MGB 1972 MGB Defroster Hose MG 2
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
T MGB-GT cant rails on 1967 MGB GT MG 12
