HI All,
I had to get an used side-shift transmission tunnel covers, I ended up with two covers. And they are slightly different.
The first cover is shown on the left, it's made from 3 pieces of metal and has a substantial flange around the bottom. The second cover appears to be made from one piece of metal, and has a good flange at the from of the cover, but at the rear of the cover the flange is reduced to a very small size.
The rear of the second cover is wider than the first, which means that it doesn't match the parking brake cover very well. (Do these butt together or overlap?)
I would like to use the first tunnel, as it seems to fit better. What do you think?
Joe
Joe
