TR2/3/3A 1960 TR3 A Hood stick mounting point?
Tinkerman
EveningI have my hood sticks all painted and ready to mount and have no idea where they mount. The hood sticks were not on the car when I bought it. (A basket case). I have looked at the parts book but that gave me no clue, so any help you can give me will be greatly appreciated!
Thanks, Tinkerman
tinman58
Dick
do you mean the hood stick for the hood (bonnet)? Or the hood sticks on the convertible top?
Dick
If you are talking about the hood prop, do you have the plate with the safety catch. Prop rod attach to the side and plate goes to the front of the hood, safety latch catches on the hood lift pin in front.
Marv
Jerry
not meaning to hijack, but does the safety catch have a spring? Seems like it should, mine does not.
Jerry
On the convertible top , there are two cage nuts about 6 inches behind the door jam, behind the side panel. There will be soft round holes that you can feel through the fabric to find these cage nuts.
Tinkerman
Tinkerman
"On the convertible top , there are two cage nuts about 6 inches behind the door jam, behind the side panel. There will be soft round holes that you can feel through the fabric to find these cage nuts."
Sorry I meant the hood sticks for the top. Is this where the hood sticks mount? Do they fasten to the body at this point? I am getting ready to put in the dog leg upholstery panels (pre made) that came with the upholstery kit. They came with pre-punched holes for the trim screws. However at the top there are two fairly large pre-punched holes for two larger screws.
I hope that all this makes sense.
Thanks, Tinkerman
Dick
Look at your top frame. You should have a small plate with two countersunk holes on each side of the top frame. This is where the top frame mounts to the body and pivots on a large common screw. These plates mount at the top the body where you see the two holes in your side panel.Your need to use countersunk common head screws, I use 1.5 long one to help find the holes thru the panel and ease of mounting. If you use a hex head the frame can hang up on the heads when you try to fold the frame down.
Marv
CJD
Dick, you are correct. There are 2 caged nuts in the quarter panel to mount the sticks. If you are lucky, they will line up with your new trim panel. Mine were not perfect, though.
croz
Hello Tinkerman,
In the image below, the mount is part number number 2.
Geo Hahn
This pic shows that plate on mine:
...Your need to use countersunk common head screws, I use 1.5 long one to help find the holes thru the panel and ease of mounting...
I believe the original bolts had a pointy tip to help them 'find' the captive plate though, as Marv notes, a longer bolt may help.
Tinkerman
Tinkerman
Thank y'all for the info and the pictures. Much of my info problems stem from the fact that I bought a basket case car and a 100,000 mile car at that. PLUS my step son was living with us during the disassembly. So I did'nt get to see much of it before it was taken apart. On top of all of that the car was bought in 1989!
I may have more questions as we continue with the addembly.
Finally got the screws odered from the local Fastenal store. I bought SS screws just cause.
Cheers, Dick
TexasKnucklehead
Dick,
On my 59, I'm pretty sure there is a plate with two threaded holes to mount the bows triangle (each side). They allow some alignment of the bows triangle. I used allen head counter sunk fine thread screws, because they are black and can be tightened (tight) without marking the paint. Also I installed the forward screw first, and tightened it to keep the plate properly positioned (with the covered fiber board in place) before installing the rear screw through the bows. That way, it's possible to find the threaded hole when installing the bows (rear screw only). Then I removed the front screw, and used the rear to rotate the plate into position for the front one to go through the bows. When they are both installed, you can position/center both sides before tightening.
Also, it is important to have the bows positioned properly, as well as the triangle positioned properly before attempting to install the top. You want to be sure the bows will go up and down.
Tinkerman TR2/3/3A 1960 TR3 A hood stick color? Triumph 2
Pool Dad 1960 TR3 engine serial number Triumph 14
O For Sale New Member from NJ 1960 TR3 Triumph Classifieds 1
R TR3 1960 refurbish Triumph 14
B Wanted Wanted: Trailer hitch for 1960 TR3-A Triumph Classifieds 7
T TR2/3/3A Accelerator Say 1960 TR3 Triumph 11
B 1960 TR3 With rust in cylinders Triumph 7
Tinkerman TR2/3/3A 1960 TR3 A More body panel assembly questions. Triumph 5
Tinkerman TR2/3/3A TR3 A 1960 adjusting apron Triumph 4
pbraun TR2/3/3A 1960 TR3 photos Triumph 17
Tinkerman TR2/3/3A Bonnet stay rod 1960 tr3 a Triumph 11
Tinkerman TR2/3/3A Original wind screen 1960 TR3 A [free to a good home] Triumph 2
Tinkerman TR2/3/3A 1960 TR3 A Door Check Assembly Triumph 13
Tinkerman TR2/3/3A 1960 tr3 a to gasket or not to gasket Triumph 35
Tinkerman TR2/3/3A 1960 tr3 a petrol tank front millboard question Triumph 6
Tinkerman TR2/3/3A 1960 tr3 a upholstery question Triumph 2
Tinkerman TR2/3/3A DOOR PANEL HELP NEEDED 1960 TR3 A post 60000 car Triumph 5
Tinkerman TR2/3/3A Apron installation 1960 tr3 a Triumph 11
Tinkerman TR2/3/3A 1960 tr3 a carpeting the floor Triumph 8
Tinkerman TR2/3/3A Windshield glazing TR3 A 1960 Triumph 7
Tinkerman TR2/3/3A Wind scereen support bracket tr3 a 1960 Triumph 3
Tinkerman TR2/3/3A 1960 TR3 A Additional steering question Triumph 4
Tinkerman TR2/3/3A 1960 TR3 A Steering wheel play or Lash Triumph 2
Tinkerman TR2/3/3A Parts help needed 1960 tr3 a Triumph 5
Tinkerman TR2/3/3A 1960 tr3 a seat tack strips Triumph 19
R TR2/3/3A 1960 TR3 Restoration Triumph 8
O TR2/3/3A 1960 TR3 Front Brakes Triumph 2
Tinkerman TR2/3/3A 1960 TR3 Post 60000 elec equipment Triumph 12
boxofparts TR2/3/3A Dads TR3 way back in 1960 Triumph 16
J TR2/3/3A New Member 1960 TR3 Triumph 11
L TR2/3/3A 1960 TR3 cooling???? problem Triumph 9
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
W For Sale 1960 TR3A for sale Triumph Classifieds 0
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
5 Sold My 1960 Bugeye Spridgets 10
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
KellyRob BMC GEARBOX 1960 British Motor Corp 2
Fanch00 My 1960 BT7 History Search Austin Healey 1
poolboy General TR LeMans 1960 Triumph 8
jlaird 1960 AH Sprite Spridgets 96
C 1960 BT7 Thoughts Austin Healey 14
L For Sale 1960 Austin Healey steel oem wheels Austin Healey Classifieds 0
F Installing AC in my 1960 Healey Austin Healey 14
