TR2/3/3A 1960 TR3 A Steering wheel play or Lash
Tinkerman
I have about 3" of steering wheel free play before the peg and worm engage. Front end completly rebuilt. New peg and worm. Never been on the road. Engine is now running as advertised. So now it is time to take care of other, hopefully, minor issues. I want to get the steering/ front end working correctly. Suggestions?
All thoughts, instrutions and tips greatly appreciated.
Tinkerman
pdplot
Did you tighten the adjustment screw in the steering box? It's been many a year since I've had a TR3 but I remember the steering free play as being a problem, in fact my friend rolled my TR-3 on the back stretch at Lime Rock because of the narrow track and the slack steering. He was lucky - the car had no rollbar but he only flipped it over on the side and except for losing most of the skin on his left arm, he was unhurt. We rebuilt the left side of the car. Of course you could possibly switch to a Tr6 rack & pinion which would solve your problem. The experts on here could help you.
TR3driver
Great Pumpkin - R.I.P
Are you checking on-center, or off to the side? There is deliberately some clearance built into the worm off to the side.
Also check for any looseness in the column, and where the worm is installed on the column. I seem to have problems with the steering wheel getting loose (although not that loose).
Otherwise, it comes down to proper, careful adjustment of the steering box. Whatever you do, DON'T just reef down on the adjusting screw trying to take out the play! I've tried that route several times, and the results have not been pretty.
You need to at least have the Pitman arm (aka drop arm) disconnected from the center link. IMO it's better to have the box out of the car, but it can be done in the car. First step is to back off the adjustment screw (or just remove the top cover) and measure the worm end float. Although in theory you should be able to just take out all the shims, install the cover with the bolts finger tight and measure the gap; I have not had very good luck with that method either. What works best for me is to assemble the box with an extra shim, then use a dial indicator to measure the actual resulting end float. Then remove shims to equal that amount or slightly more. As the books says, a slight amount of pre-load is acceptable, but there must be NO end float.
Only after you make sure the shims are right, you can check the adjusting screw. With it properly adjusted, you should be able to just barely feel a tight spot near the center of travel. It's a lot easier to feel with your fingers turning the shaft directly, rather than with the wheel.
FWIW, my most recent go-round with the box on TS13571L turned out to be that the new peg was working back and forth in the arm. You might want to check to be sure the peg is solid with no movement whatsoever. I just replaced the arm rather than try to deal with the waddled-out hole.
Tinkerman TR2/3/3A 1960 TR3 A Additional steering question Triumph 4
Pool Dad 1960 TR3 engine serial number Triumph 14
O For Sale New Member from NJ 1960 TR3 Triumph Classifieds 1
R TR3 1960 refurbish Triumph 14
B Wanted Wanted: Trailer hitch for 1960 TR3-A Triumph Classifieds 7
T TR2/3/3A Accelerator Say 1960 TR3 Triumph 11
B 1960 TR3 With rust in cylinders Triumph 7
Tinkerman TR2/3/3A 1960 TR3 A More body panel assembly questions. Triumph 5
Tinkerman TR2/3/3A TR3 A 1960 adjusting apron Triumph 4
pbraun TR2/3/3A 1960 TR3 photos Triumph 17
Tinkerman TR2/3/3A Bonnet stay rod 1960 tr3 a Triumph 11
Tinkerman TR2/3/3A Original wind screen 1960 TR3 A [free to a good home] Triumph 2
Tinkerman TR2/3/3A 1960 TR3 A Door Check Assembly Triumph 13
Tinkerman TR2/3/3A 1960 tr3 a to gasket or not to gasket Triumph 35
Tinkerman TR2/3/3A 1960 tr3 a petrol tank front millboard question Triumph 6
Tinkerman TR2/3/3A 1960 tr3 a upholstery question Triumph 2
Tinkerman TR2/3/3A DOOR PANEL HELP NEEDED 1960 TR3 A post 60000 car Triumph 5
Tinkerman TR2/3/3A 1960 TR3 A Hood stick mounting point? Triumph 11
Tinkerman TR2/3/3A Apron installation 1960 tr3 a Triumph 11
Tinkerman TR2/3/3A 1960 tr3 a carpeting the floor Triumph 8
Tinkerman TR2/3/3A 1960 TR3 A hood stick color? Triumph 2
Tinkerman TR2/3/3A Windshield glazing TR3 A 1960 Triumph 7
Tinkerman TR2/3/3A Wind scereen support bracket tr3 a 1960 Triumph 3
Tinkerman TR2/3/3A Parts help needed 1960 tr3 a Triumph 5
Tinkerman TR2/3/3A 1960 tr3 a seat tack strips Triumph 19
R TR2/3/3A 1960 TR3 Restoration Triumph 8
O TR2/3/3A 1960 TR3 Front Brakes Triumph 2
Tinkerman TR2/3/3A 1960 TR3 Post 60000 elec equipment Triumph 12
boxofparts TR2/3/3A Dads TR3 way back in 1960 Triumph 16
J TR2/3/3A New Member 1960 TR3 Triumph 11
L TR2/3/3A 1960 TR3 cooling???? problem Triumph 9
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
W For Sale 1960 TR3A for sale Triumph Classifieds 0
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
5 Sold My 1960 Bugeye Spridgets 10
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
KellyRob BMC GEARBOX 1960 British Motor Corp 2
Fanch00 My 1960 BT7 History Search Austin Healey 1
poolboy General TR LeMans 1960 Triumph 8
jlaird 1960 AH Sprite Spridgets 96
C 1960 BT7 Thoughts Austin Healey 14
L For Sale 1960 Austin Healey steel oem wheels Austin Healey Classifieds 0
F Installing AC in my 1960 Healey Austin Healey 14
