charleyf
I am installing a new set of bearings in a rebuilt front end. I noticed that the inner bearing is not what I would call snug on the stub axle. As this bearing is usually "locked" in place inside the hub behind the seal one does not usually see how loose or tight the bearing is on the stub axle. I tested some old stub axles sitting on the shelf and found all of them to be about the same as the one currently on the car. So the question is has anybody else noticed what I am talking about? I also never remember having to force the hub off of the stub axle in dismantling a front unit. If the inner bearing was really tight on the stub axle it would require a bunch of force to get the hub off the stub axle. Right??? So is the unit intended to have the bearing NOT SNUG TIGHT on the stub axle??
Charley
Charley
