SteveHall64Healey
I'm having difficulty removing the bearing retaining nut from the right-front hub. Normally these castelated nuts are only on with 5-7 ft.lbs., but this one seems immovable. I have removed the cotter pin cleanly and, through the hole in the hub, I was able to insert a rod completely through the nut - showing that there is no debris in the hole which might be holding the nut in place. Before I apply King Kong force to this, has anyone ever encountered this before or have any idea as to why the nut might be stuck on so firmly?
thanks,
steve
BJ8p1
thanks,
steve
BJ8p1
