Engine or Tachometer Odd Problem
stefano rosati
Good morning everyone. My 1959 100-Six has always exhibited this problem: The rev counter slowly rises and when it reaches 3000 the car seems to go over-rev. In fact, out of fear, I never exceeded this limit. Can anyone tell me what it could be? Thanks.
Michael Oritt
Stefano--
You must give more facts:
1. What model car do you have, which will tell us whether or not you have an electronic tach.
2. Exactly what does "Go over-rev" mean? Is it simply the tach needle going higher or does the sound of the engine change or both?
3. Assuming you have a later car with an electronic tach, do your other instruments react in any way at 3K rpms?
Please give us as many facts as possible.
BN6_L1232
Member
Stefano-Assuming you have a 100-6 with mechanical tack and the engine RPM is erratic past 3000 RPM, I would replace the cable as the first step. Sometimes the cable will "wind up" and result in a pulsing condition.
For suppliers of cable I would go to Healey Surgeons in Md. or West Valley Instruments in LA. Peter.
John Turney
Your spring on your mechanical tach may be weak. You may be able to borrow a good one from someone for comparison, or if you have a drill that you know the speed of. I don't know any instrument repair companies in Europe.
Michael Oritt
Hre said thre engine goes on "over-rev". I guess I read too much into his post thinking that the engine rpm's were actually varying.
S
stefano rosati
Stefano--
Devi dare più fatti:
1. Che modello di auto hai, che ci dirà se hai o meno un tachimetro elettronico.
2. Cosa significa esattamente "Vai fuori giri"? È semplicemente l'ago del tach che va più in alto o il suono del motore cambia o entrambi?
3. Supponendo che tu abbia un'auto successiva con un tachimetro elettronico, gli altri tuoi strumenti reagiscono in qualche modo a 3K giri/min?
Per favore, forniscici più fatti possibili.
Stefano--
Stefano--
This is an Austin Healey 100/6 BN4 from February 1959 with a 6-cylinder 2639cc engine. Above 3000 rpm the engine starts to howl and gives the feeling that it is at the limit. The other instruments are not altered .The engine runs round and has no hesitation whatsoever, it does not consume oil, but I repeat beyond 3K rpm it seems at the maximum allowed rpm also for the noise it emits. I don't think the tachometer is elettronic,indeed i think not. Thank you
S
stefano rosati
Grazie mille !!!
W Tachometer reads high when engine compartment heats up Austin Healey 3
B MGB MGB tachometer erratic, engine cutting out.... MG 11
mctriumph For Sale Tr7 engine Triumph Classifieds 0
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
M Engine ID Austin Healey 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
