General TR Cluthch problem / challenge
Trevor Triumph
I can not shift into first gear or reverse from stop. Once the car is in gear and rolling shifts are smooth and no gnashing of teeth. I don't remember when I replaced the master / slave cylinder washers, but I'm sure it has been awhile. It seems there is little in the way of adjustment, at least I have never had to do anything but replace the hydraulic washers and reinstall the master and slave cylinders. Opinions / suggestions?
T.T.
Graham H
Most likely the clutch fork taper bolt has sheared which requires the box to come out
Graham
CJD
To check the pin, remove the slave cylinder return spring and pump the pedal a couple times. If the clutch starts working, then the pin is sheared. If it makes no difference, then you could have air in the system or a bad cylinder.
sp53
Sounds like a clutch problem. Does the clutch slip in 4th gear trying to go up a big hill, at like 30mph?
One of my first problems in the British car World was a complete hydraulic failure of the clutch. What struck me was having the car in direct drive and still moving with no clutch and not being able to shift. If you have a problem going into first or reverse, try pumping the pedal a couple of times to see if the clutch works better going into first.
I have also had a broken pin move the pedal up so high the clutch would not work in the lower gears without grinding
Later I had a problem with a different car that would not go into first or reverse without grinding. It turned out to be a bent shaft on the reverse gear idler.
steve
Sarastro
Is the master cylinder losing fluid? Do you see any leakage? If not, bad seals in either are unlikely. Only possibility is leakage back into the reservoir from a bad valve seal (see the shop manual, p. 2-104). Frankly, I also think that a broken pin is likely.
T TR4/4A TR4 seat buffer problem Triumph 5
Carlbanan56 MGB High rpm problem MG 27
Sarastro TR4/4A Convertible top installation problem Triumph 12
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
B TR2/3/3A Possible differential problem Triumph 3
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
E Gearbox problem Other Cars 0
A Rivergate slave problem Spridgets 3
Govtslug TR6 Clutch Problem Triumph 21
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
M 1977 MG Midget 1500 Problem Spridgets 8
KVH General TR Transmission Problem Triumph 3
DrEntropy W123 Benz recurring problem Other Cars 16
J MGB Idle problem MG 4
tr6nitjulius TR6 TR6 No 1st/2nd problem/solution Triumph 4
Got_All_4 TR6 Throw Out Bearing Fork Problem Triumph 7
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
E MGB MGB heater motor problem MG 3
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
T TR2/3/3A Help - Cooling system problem Triumph 7
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
ROARRR Is there any problem swopping in a 3.0 in place of the 2.5 L engine in my Jag X Type? Jaguar 0
M Europa turn signal problem Lotus 7
T TR2/3/3A TR3A clutch problem Triumph 15
E TR2/3/3A Tr3 a clutch hydraulics problem, again. Triumph 16
S Engine or Tachometer Odd Problem Austin Healey 7
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
G windscreen problem Spridgets 1
Hamish Racing TR2/3/3A Gearbox - can you spot the problem ? Triumph 17
T TR4/4A Why are distributor base plates different, is this a problem? Triumph 7
J TR6 72 TR6 starter problem Triumph 10
nichola TR6 New harness installed but have a purple problem Triumph 12
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
Simmo General Tech Electric Cooling Fans. Are they a problem? Triumph 19
C TR2/3/3A TR3 Gearbox Problem Triumph 10
Healey Nut Clutch problem Austin Healey 5
R TR2/3/3A Tr-2 Clutch Problem Triumph 46
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
R TR2/3/3A Grounding problem Triumph 21
P TR6 Wiring problem Triumph 50
P TR6 Clutch problem not solved Triumph 6
D Acceleration Problem Austin Healey 4
M XK120 fuse problem? Jaguar 5
P 2002 Accord problem Other Cars 31
P TR6 Electrical Problem Triumph 26
M A problem solved Austin Healey 0
