2002 Accord problem
pdplot
It did it again just as it did last November. Stalled a couple of times while slowing down for a light, but this afternoon, it refused to start. Engine cranked over normally but no joy. Wife and I pushed it out of the way as it was blocking garage. As she could not turn steering wheel, she attempted a start and it came to life. We parked it and I came out of the house with my meter and checked the battery. 12.67 at rest, 14.62 charging. Normal. I had changed the battery in November and that seemed to cure the problem - until now. Oh how lucky we are with our LBCs - easy to diagnose and easy to fix (mostly) with a few simple tools. I'm at a loss with this one and since its intermittent, I won't find it anyway most likely. Known problems are the ignition switch and the fuel pump module. I'm leaning towards the module as it seems to be starving for fuel when it dies. Most ignition problems are sudden. Any ideas?
LarryK
Was it raining? Gone through car wash? We had a run on cars in our shop one time, when they drive through a puddle or a car wash with undercarriage spray, the crank sensor would get wet and kill the car. Upon towing to shop, we found it by spraying sensor with water. Once it dried, either from engine heat or sitting it would start back up. Just an idea.
P
pdplot
It had drizzled overnight with light rain but car was parked in front of garage. It was dry and sunny the last few days when car acted up again. My guess is the main relay under the dashboard. Seems to be a common problem with these cars when they get older. But why intermittent?
LarryK
Intermittent to drive you crazy! And then your mechanic can't find it because it doesn't do it for them.
Gliderman8
Do all of the dash lights flicker when trying to re-start it?
If they do, it could be a bad ignition switch.
The next time it shuts down take note of the warning lights on the dash while attempting to restart it.
Gliderman8
Have a look:
P
pdplot
I guess that test only works when the switch is bad. I don't recall ever seeing flashing lights at any time. There may have been a recall on the switch way back. Can't recall. We've had this car for 19 years, longest we've ever owned a car. Best all-around car I've ever owned. Wife loves it because she sits up high and the steering wheel is adjustable. About 202 hp and very fast. Still on the original shocks and struts at 162,500 miles. Brakes are a little sketchy compared to the Alfa and Subaru and I never use the traction control. Burns no oil and gets about 25 mpg on regular gas, even Sunoco 87. Leather upholstery with no tears, sunroof which we never use and decent sized trunk that holds 3 full golf bags.
Gliderman8
I’m not saying the switch is your problem but may be something to consider. After nineteen years the switch contacts could be worn. Take notice of the dash lights the next time it happens.
P
pdplot
Wife drove the car Monday. Sure enough, it stalled out and then restarted after a few seconds. Cars piled up behind her...I drove it all over yesterday hoping it would stall out but it ran perfectly - like a new car. What would you do?
LarryK
Buy her a reliable car, I don't think she can hint any better. After 18 yrs it's time. My wife drove a 1973 GT6 for 10 yrs, 190K miles, then a 1986 Ford E150 extended van (used as camper and boat hauler) for 14 yrs, 180K miles and then her 1996 Land Rover Discovery for 15 yrs, 190K miles. Then she picked a 2011 MINI Countryman S, now with 55K miles, will have to pry her out of it as I did all of the others.
maynard
I had an older Accord (late 90's). It would stall at a light, and refuse to restart. Also after it was parked. Then a little later, it would start. Turned out it was the igniter.
P
pdplot
Doesn't seem like my problem. It starts right up again. Heat is no factor. I Googled the ignitor problem. Because it dies slowly, I think its fuel related.
LarryK
Have you checked fuel pressure. Put a vacuum gauge on engine and run to driver seat, put on fuel pressure gauge tape so you can see it. I had a Ford van that lost vacuum and slowed down, then I noticed fuel pressure was low. Started tracing it and I thought it was a fuel filter as pressure was goid then bad then good. Replace a lot of stuff dealer said was wrong including cats. I had my tools at my worksite and van wouldn't go over 35. Called a dealer 25 miles away took and hour to get there. Gave them a list of everything I did. Went home for Labor Day weekend. As soon as I got home I got a call that it was done. Went back and they brought out an older man who said with all the things I did it could only have been the back filter. My Fird dealer said leave it as it's only purpose was to be a tank for the high pressure pump. Showed me it was full of wax is the lube for fuel. Probably not your problem but it probably is something easy.
P
pdplot
I ain't got no got vacuum gauge and if I did have it, I wouldn't know where to hook it up to. My knowledge of cars ends about 1976. I take one look at these modern engines and slam the hood down. I can check the oil, add washer fluid & brake fluid - maybe even power steering fluid, but beyond that lies a mystery.
NutmegCT
Paul - I'm thinking the PGM-FI relay (electronic fuel injection board main relay) is failing.
https://youtu.be/6CMZ4g8n0FQ
If you're not a whiz in computerized electronic fuel injection (and what mere mortal is ???), take it to a reliable Honda shop for scan test and probable relay replacement.
Tom M.
P
pdplot
That's what we'll have to do. They may just start throwing new parts at it hoping for a bullseye hit. This is one time that you're hoping the thing just dies for good - then you'll know. When it runs 99% of the time, it runs perfectly. Baffling. If the Alfa develops a similar problem, I'll be just as stumped - Bosch fuel injection, many warning lights - the works. So far, so good.
Our 2003 Pilot had an intermittent, seemingly random stalling problem too. It was the control module under the dash $50+/-, take about an hour to replace. Found the solution on YouTube. The dealer we've gone to for years wanted to know if we wanted it towed to the scrap yard.
P
pdplot
I took the Accord out today on an important run - to get 2 bottles of wine to go with pizza tonight and another couple coming over. It ran like a top.
LarryK
How long did it spin? :encouragement:
P
pdplot
About 10 minutes driving time. Left turn out of driveway, right at light, down hill to caution light, left at caution light and turn into driveway of liquor store. Going back home, reverse direction. Pizza was good too - real thin crust.
G FOR SALE - 2002 XJ8 Vanden Plas Jaguar Classifieds 0
Michael Oritt Post- Open Roads 2002: Tahoe to MD the long way Austin Healey 19
Michael Oritt Open Roads International 2002: A Journal Austin Healey 37
M Looking for a Vendor to Repair 98 - 2002 XJ8 ECM Jaguar 2
JPSmit 2002 Beetle question Other Cars 7
Marvin Gruber 2002 XKR Jaguar 6
T BMW 2002 race car Other Cars 20
S POWER WINDOW PROBLEM ON A 2002 XK8 Jaguar 6
BritCarFan 1998-2002 Land Rover Discovery Rover / Land Rover 1
PeterK TR2/3/3A BMW 2002 fan on my TR3A Triumph 17
W 1995 4.0 SE/2002 Discovery II Trailer Hitch Rover / Land Rover 1
C 2002 2003 vandenplas Jaguar 2
Sherlock Neat BMW 2002 prototype Other Cars 7
Bret MGB MGB Driver Vol 12, No. 6 Nov/Dec 2002 MG 0
AngliaGT .1980 Honda Accord Spotted 4
AngliaGT t hadHonda 600, Accord Spotted 0
jackq 2000 Honda Accord Other Cars 3
eejay56 Honda Accord shift slop Other Cars 3
T TR4/4A TR4 seat buffer problem Triumph 5
Carlbanan56 MGB High rpm problem MG 27
Sarastro TR4/4A Convertible top installation problem Triumph 12
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
B TR2/3/3A Possible differential problem Triumph 3
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
E Gearbox problem Other Cars 0
A Rivergate slave problem Spridgets 3
Govtslug TR6 Clutch Problem Triumph 21
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
M 1977 MG Midget 1500 Problem Spridgets 8
KVH General TR Transmission Problem Triumph 3
DrEntropy W123 Benz recurring problem Other Cars 16
J MGB Idle problem MG 4
tr6nitjulius TR6 TR6 No 1st/2nd problem/solution Triumph 4
Got_All_4 TR6 Throw Out Bearing Fork Problem Triumph 7
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
E MGB MGB heater motor problem MG 3
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
T TR2/3/3A Help - Cooling system problem Triumph 7
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
ROARRR Is there any problem swopping in a 3.0 in place of the 2.5 L engine in my Jag X Type? Jaguar 0
T General TR Cluthch problem / challenge Triumph 4
M Europa turn signal problem Lotus 7
T TR2/3/3A TR3A clutch problem Triumph 15
E TR2/3/3A Tr3 a clutch hydraulics problem, again. Triumph 16
S Engine or Tachometer Odd Problem Austin Healey 7
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
