Got_All_4
I guess this is asking a question and a discussion. Just got back on my frame and getting ready to install the tranny and while assembling the fork for the throw out bearing the pin would not screw in. I was planning on reusing the parts I took out. So I went and purchased a new fork and pin but once installed the bearing carrier binds up and only goes 2/3 of way back. I tried another carrier and it only went 1/2 way back. To get it fully back I have to pound it back. Now I decided to reinstall the old fork for a test and the new pin screws right in and everything works perfectly and smooth. Did a lot of inspection and measuring between the two forks and can't find any major differences/problems. What I did find was the two pins were 11k closer then the old one. So I carefully ground off 5k on each side and beveled the pins. The casting between the forks was high so I ground those down. Nothing I've done made a difference. The one thing I can't change is the pin height. Seems to be 21k higher then the old one and that measurement is from the bottom of the shaft to the top of the pin.
I purchased the new fork from my local Triumph parts store and he mostly sells Moss stuff. If you look closely at the last pic the fork has a part number on it and starts with TRF. Is that The Roadster Factory? I know they have a lot of the LBC parts remanufactured to their specks and I like how more robust the new fork is. Since I bought a new one I would like to use it and there is a small issue on the old fork too. Now is there anyone out there that has had the same problem or thinks they can offer a solution. I started this on Tuesday and it is now Saturday so it's getting very frustrating.
