Spitfire rear wheel bearing
chris4
are all spitfire herald gt6 rear wheel bearings the same size ? as replacing the bearings on my 1980 spitfire and the hub wont go all the way onto the shaft and locks up the outer bearing i forced on ?
bobhustead
I no longer have any recall of spitfires. However, the Moss catalog shows only one part number for the outer bearing from 1962 to 1980.
Bob
C
chris4
okay thanks will investigate the driveshaft, i think the car is a bit of a bitsa sold to me as a 1500 only to find its a 1300 engine and the rear hubs are of a different design one has three lugs and one doesn't
C Rear wheel bearing or other cause? Austin Healey 18
B Rear Wheel Bearing Oil Seal Spridgets 7
G XKE rear wheel bearing replacment Jaguar 4
M Rear wheel bearing Spridgets 4
GBRandy Wedge TR8 rear wheel bearing noise / replacement Triumph 5
I TR6 Rear wheel bearing help TR6 Triumph 6
M Rear wheel bearing packed with grease? Austin Healey 5
Luke_Healey Question about rear wheel bearing seals Spridgets 11
jmwuva05 Rear wheel bearing removal Spridgets 3
N TR6 TR6 Rear wheel bearing Part #'s for timken Triumph 5
RobSelina Rear wheel bearing discussion Spridgets 30
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
R TR6 Rear brake wheel cylinder fitment Triumph 5
Healey Nut Rear Wheel Cylinder Mounting Austin Healey 4
Martinld123 My left rear wheel is locking up Austin Healey 16
Kurtis TR4/4A Rear wheel brake cylinder replacement Triumph 1
R TR2/3/3A Rear wheel cylinders for 54 TR-2 Triumph 3
S TR2/3/3A Upholstering the rear wheel arc Triumph 3
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
AUSMHLY BJ8 Rear Wheel Cylinder leaking Austin Healey 30
K TR2/3/3A Rear brake wheel cylinder attachment again Triumph 1
D BT7 rear wheel leaking Austin Healey 25
S Locknut - rear wire wheel - torque spec? Austin Healey 15
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
T TR6 grinding right rear wheel Triumph 22
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
Jim_Gruber Reinstalling Brake Hubs and Wheel Hubs in Rear. Spridgets 5
G rear wheel studs on my 1967 BJ8 Austin Healey 5
drooartz Rear wheel hub oil seal Spridgets 6
A TR2/3/3A Newbie wrestling with TR3 rear wheel studs Triumph 3
J TR4/4A TR4A rear wheel cylinder source Triumph 3
RickPA BJ8 rear wheel cylinder install Austin Healey 1
trotti Pulling off the rear wheel cylinder Austin Healey 11
J TR2/3/3A Interior rear wheel arch covers question. Triumph 2
R Bugeye rear wheel advice needed Spridgets 20
Mickey Richaud MGB Leak at Rt. Rear Wheel MG 6
G TR4/4A tr4a irs left rear wheel Triumph 14
steveg Shimmed rear wheel bearings Austin Healey 13
Crankshaft TR2/3/3A Noise from rear wheel. Triumph 1
J TR6 Inverted righ rear wheel [need help] Triumph 10
T Spitfire 1979 Triumph Spitfire 1500 rear wheel alignment Triumph 4
T TR2/3/3A TR3 Rear wheel cylinder attachment clips Triumph 6
TulsaFred What holds the rear wheel and axle on? Spridgets 6
J Rear wheel cylinders over extending ??WHY?? Making a mess fluid everywhere!!! Austin Healey 54
TulsaFred Bugeye rear wheel cylinder replacement tips Spridgets 10
hondo402000 TR6 New rear wheel cylinder leaking, TR6 Triumph 0
JohnnyMead TR2/3/3A TR3A Rear Wheel Cyl Assembly Question Triumph 5
