TR6 grinding right rear wheel
Terry_M
Help
my 1974 TR6 while driving i could feel a vibration in the seat. Lifting the car the right rear has a grinding sound . Removing the wheel the hub turn quietly and freely . Changing wheels no difference .changing Hubs no difference. The tires and rims have no marks for rubbing or scrapping If anyone can help i would appreciate giving me some direction
regards
terry
Gliderman8
is there any play by grabbing the wheel and pulling in/out when it's off the ground?
TomMull
Vibration and noise are classic symptoms of a bad u-joint. These often don't look obviously bad so spend some time trying to get them to move. There should be absolutely no play at all. If not, I'd pull the drum and look at the rear brakes but I doubt that a brake noise would cause a vibration.
Tom
T
Terry_M
Tom-thanks for the reply The play i have in the right side is <sixteenth maybe a 32nd. I have never had a great deal of success changing u-joints. There is nothing else it can be --thanks again
regards
terry
rjc157
If your talking about the u-joints in the axles it's easier said than done there are some vids on YouTube that make it look easy if you don't have a big ass vice it's a PITA if it's the driveshaft one your going to have to drop the diff you can't get it out good luck have fun.
T
Terry_M
Yes--as i said me and u-joints have never got along I will pull the axel and give it the old college try The u-tube guys always make it look easy
thanks
terry
rjc157
Terry I did mine that way and was successful bought a 6 in bench vice from HF and it fit ok just take it slow it will work .
TomMull
Here is a good but expensive solution.
https://www.goodparts.com/shop/index.php?categoryID=20
If you replace the originals, take the axles out and use a vice for a press, or a press of course if you have one. I use a couple of old sockets to fir the bearings. It's not too bad a job.
Tom
T
Terry_M
Ok-i pulled the axel right side all the u-joints are perfect--i forgot to mention i do have the Good axels I installed a couple maybe three winters ago When i was wrestling with the axel i noticed the drive shaft u-joint is showing movement It will have to be changed If my main issue is the driveshaft u , shouldn't it grind on both sides . Why is it grinding just with the weight of the wheel only on the right side--- My neighbour thinks it may be the shaft coming out of the diff as it has more play than the left side
terry
Deleted member 8987
well.....grinding is one issue, vibration is another...sometimes part of the same problem, sometimes not.
But the one common symptom, reading all this, is when the WEIGHT of the WHEEL is on, it grinds.
When the wheel is removed, it is quiet.
Sure looks like an axle bearing to me.
Now, for a "proof". It looks like you have the axle shafts out. If so, put the wheel back on and spin. If the noise is there, there is but one part to look at..the axle bearing.
T
Terry_M
TDC-not sure what you mean -i have the axel out disconnected from the diff everything is on the parts trolly , there is nothing to hang the tire on The axel bearing ? ,i assume the differential needs to be dropped ?
TomMull
I think he means to mount this and put on the wheel without the axle. Good suggestion. Diff stays put. And you might want to put the backing plate and brakes on too or examine them closely to see if anything is rubbing. I doubt that the brakes would cause a vibration but could certainly cause the noise. (I think you said you get get movement in the u-joint, if so "d replace replace it, both at this point, even if it looks good
https://bullfire.net/TR6/TR6-36/SDC11685a.JPG
Sarastro
I also was thinking it might be a wheel bearing. Bearings often feel smooth when you spin them without a load, especially if they are well greased.
T
Terry_M
yes ,tried the better part of the afternoon trying pull the seal without dropping the differential --no go So I start tomorrow with dropping the exhaust
regards
terry
Deleted member 8987
sorry....I was thinking IRS and removeable axles with u-joints.
But, if the outer race is damaged, it will be the top (weight of car down, force of wheel up). If the inner race is damaged, you will get noise with axle up, wheel weight on.
T
Terry_M
i am into it now! The rear drive u-joint looks sketchy from a distance I plan on changing both front and rear-Also the right axel bearing All this means dropping the differential which means the exhaust needs to be dropped I have the nuts loosened on the diff & driveshaft I don't believe they have been touched in 44 years Tomorrow the left axel and the exhaust I was hopping i could wrestle the diff out without touching the exhaust Almost certain that is wishful thinking
Gliderman8
Make sure you support the diff.... it's a heavy sob. Be careful.
T
Terry_M
Well-dropping the diff was not a fun job for this old guy- it's down, no damage to me or the car or the diff This bearing runs smooth,i'am here now might well change it The question now is how do i remove the flange assembly . The book says there is a keyway i can't get it to budge or should i just remove the bearing housing
terry
J Clutch and Grinding Gear Austin Healey 12
M Grinding when shifting into first Spridgets 10
KVH General Tech Grinding Gears in Shift From 1st to 2nd Triumph 13
C TR2/3/3A Gears grinding on first startup..... Triumph 14
M TR2/3/3A Grinding noise when trying to start sometimes? Triumph 10
JPSmit What is that strange grinding sound in the distance? Spridgets 3
bighealeysource Mysterious grinding [ouch] noise on BN2 Austin Healey 7
longbridgehealey gears grinding when shifting Spridgets 11
J Transmission grinding! Austin Healey 15
Jim_Stevens Grinding wheel removal Triumph 15
zimmy grinding noise.... Spridgets 50
martx-5 Cam Grinding Triumph 4
S Grinding into first Spridgets 20
R Gears are grinding Spridgets 7
NutmegCT Starter grinding noise caused by a broken housing. Triumph 28
NutmegCT starter grinding Triumph 17
D grinding noise on 91 xjs v12 Jaguar 5
K Second gear grinding Triumph 17
S Gear Grinding in my BJ8 Austin Healey 2
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 5
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
G Right-Side Shock Weeping Oil Austin Healey 1
C MGB Which Weber DGV is the right one. MG 14
P Jag XJ8 starts but then dies right away. Jaguar 4
Popeye General Tech O/D right angle drive choices Triumph 10
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
BritBite Speedometer Right Angle Drive Austin Healey 5
drooartz General MG Surprisingly enough, I was right! MG 7
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
C TR2/3/3A Right oil Triumph 8
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
TRclassic3 TR2/3/3A Body leans to right side Triumph 10
red57 Steering not right Austin Healey 66
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
dougie Big Healey Six - Used the Right Way Austin Healey 5
John Turney The Panhard Rod is Supposed to be Straight, Right? Austin Healey 7
Bayless What are symptoms of steering rack not shimmed right? Spridgets 14
T For Sale GT6 Mark II Right Front Fender - NOS Triumph Classifieds 0
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
C Left to right hand drive Austin Healey 2
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 1
Rut TR4/4A Nice project for the right person Triumph 0
JPSmit Fuek Tank Sender - does this seem right to you? Spridgets 3
D BJ8 pulls right on hard braking? Austin Healey 4
Simmo TR6 Right Hand Drive Conversion Help Triumph 3
Jim_Gruber 13" Tires - What's out there right now Spridgets 21
Popeye TR4/4A Seats - left/right Triumph 8
