Fuek Tank Sender - does this seem right to you?
JPSmit
Trying to figure out a sender for the Vauxhall. It has an AC Delco sender (the Vauxhall) - it is complete but will need rebuilding.
On my Vauxhall board they suggested this - but I seem to recall the Midget has a friction slip ring holding everything in place.
https://www.ebay.co.uk/itm/MG-Midge...hash=item2cb6b38f0b:m:mqauFrSUMPTwOQae2DRx1mw
So, do ours have 6 hole flanges? and, does anyone know the ohm range of Spridget senders?
dklawson
Not being a Spridget guy I can only speak in generalities. BMC introduced the bimetallic gauge system in the mid-1960s. Cars from the early 1960s had a "magnetic" gauge system. Those gauges have the skinny tapered needle that jumps up to its reading as soon as you turn the key to the run position. The early sender will have a NOMINAL resistance range from about 90 Ohms = Full to 10 Ohms = Empty. After the mid-1960s the gauge system changed to bimetallic and the voltage stabilizer was added. Those are the gauges which respond slowly and have "wide" rectangular needles. The senders that work with those gauges will have a NOMINAL resistance range of 270 Ohms = Empty to 33 Ohms = Full.
I have no idea what your Vauxhaul will have or need. However, there is a suggestion I can offer. Visit the Spiyda Design website in the U.K. and consider adding their Gauge Wizard to your car's fuel gauge circuit. That will allow you to adapt virtually any sender to your gauge.
Link to Spiyda Design Gauge Wizard
SD Bugeye
I Second the Spiyda solution
i have there tach kit in the bugeye love it
gauge wizard is still on the shelf maybe this winter.
drooartz
I've never seen that Spiyda solution -- very cool. I will need to try that on my cars.
rlandrum Fuek Tank Repair or Replace Triumph 22
G MGB Fuek pump '71 MGB MG 14
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
Patrick67BJ8 Coolant Overflow Tank Austin Healey 21
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
TomMull GT6 Gas Tank Outlet Triumph 0
edkap2002 TR6 gas tank sounds Triumph 8
MGTF1250Dave T-Series TF Gas Tank MG 6
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
B General MG 77 MIDGET Gas tank sending unit MG 1
BoyRacer Fuel Tank Sending Unit Austin Healey 3
G Wanted gas tank dip stick for mgtf 1555 MG Classifieds 1
T TR2/3/3A TR3 Gas Tank Grounding Triumph 9
P MGB Mgb gas tank cap MG 7
B TR6 Fuel tank replacement Triumph 0
B TR4/4A GAS TANK FELT Triumph 14
B Damaged threads in the gas tank Austin Healey 7
R TR6 Questions on emission tank-to-canister pipe Triumph 0
George Zeck Tank's Meter Match ??? Spridgets 12
J TR2/3/3A TR3 gas tank mystery Triumph 5
Rob Glasgow New Gas Tank Austin Healey 8
JPSmit Fuel tank sender - how does it work? Spridgets 4
S Large capacity fuel tank Spridgets 1
B TR4/4A Gas Tank color? Triumph 4
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
JPSmit Fuel line - gas tank question Restoration & Tools 5
Ripper01 SOLD-TR6 Gas Tank Triumph Classifieds 3
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
A Wanted Gas tank for TR6 Triumph Classifieds 5
Ljohns New Midget/Sprite Fuel Tank Austin Healey Classifieds 1
D What's inside the gas tank?? Spridgets 13
nevets Radiator Overflow Tank Austin Healey 23
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
J TR2/3/3A TR3A gas tank repair Triumph 7
Michael Oritt Fuel tank safety Austin Healey 18
Michael Oritt Gas cap parts now in tank Austin Healey 17
M Oil catch tank Austin Healey 32
R TR2/3/3A Installing gas tank Triumph 6
BoyRacer Fuel tank sealing rubber is too thick Austin Healey 3
S Bugeye Radiator Tank Plug Size? Spridgets 24
R Jensen-Healey Fuel Tank Questions Other British Cars 17
Martinld123 Fuel Tank Cap 100 BN2 Austin Healey 7
FlyingCat Spitfire Gas tank Triumph 2
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
aero3113 Radiator overflow catch tank Austin Healey 15
S TR2/3/3A how to install a gas tank in an early tr3 Triumph 8
wkilleffer MGB Classic Gold fuel tank drain plug MG 12
R TR2/3/3A Pin Hole in gas tank Triumph 9
