TR6 gas tank sounds
edkap2002
after a good drive....gas tank gurgling or gulping sounds...continues after opening gas cap....any ideas? Thanks as always!
charlie74
If it stops after a bit or varies depending on fill level it could be sloshing. I don’t believe the original design tanks had any baffles…
charleyf
On the TR6 you have a line that runs from the tank to a charcoal canister in the engine compartment. You might locate that canister and the line from the tank and see if removing the tank line makes a difference. Your canister could have a problem. Easy place to start.
Charley
edkap2002
edkap2002
Charley
yes...i omitted that fact...i replaced it with a new canister form Moss...still gurgling after a drive...but runs great
edkap2002
edkap2002
And the answer is: a deposit of sludge...or something else...... was clogging the vent line...as I had no lift to get under and trace it.....I disconnected the line from the charcoal cannister....introduced as much solvent as I could (gas treatment). I didn't take much...I left it for a couple of hours and then, using about 40 PSI...I attempted to blow it clear....was feeling defeated BUT on my 12th attempt...Bingo...a loud pop from the gas tank (gas cap open of course) and the sound of air passing through the line and into the tank without restriction. Now I will add gas treatment into tank in attempt to break up any sludge deposits........as always...im elated when a TR6 problem is behind me......thanks for suggestions!
TomMull GT6 Gas Tank Outlet Triumph 0
MGTF1250Dave T-Series TF Gas Tank MG 6
B General MG 77 MIDGET Gas tank sending unit MG 1
G Wanted gas tank dip stick for mgtf 1555 MG Classifieds 1
T TR2/3/3A TR3 Gas Tank Grounding Triumph 9
P MGB Mgb gas tank cap MG 7
B TR4/4A GAS TANK FELT Triumph 14
B Damaged threads in the gas tank Austin Healey 7
J TR2/3/3A TR3 gas tank mystery Triumph 5
Rob Glasgow New Gas Tank Austin Healey 8
B TR4/4A Gas Tank color? Triumph 4
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
JPSmit Fuel line - gas tank question Restoration & Tools 5
Ripper01 SOLD-TR6 Gas Tank Triumph Classifieds 3
A Wanted Gas tank for TR6 Triumph Classifieds 5
D What's inside the gas tank?? Spridgets 13
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
J TR2/3/3A TR3A gas tank repair Triumph 7
Michael Oritt Gas cap parts now in tank Austin Healey 17
R TR2/3/3A Installing gas tank Triumph 6
FlyingCat Spitfire Gas tank Triumph 2
S TR2/3/3A how to install a gas tank in an early tr3 Triumph 8
R TR2/3/3A Pin Hole in gas tank Triumph 9
D TR2/3/3A Gas tank does not fit! Triumph 4
C MGB Found this spring in my gas tank MG 8
B Stripped Thread in Gas Tank Austin Healey 26
Jim_Gruber What Now, new gas tank filler neck is about 1/2-3/4" too short Spridgets 19
S TR4/4A Worm in gas tank? Triumph 7
PatGalvin TR2/3/3A TR3A Gas Cap Info and uel tank venting Triumph 4
F Throw away BN7 Gas tank Austin Healey 3
F For Sale BN7 gas tank, original. [I think]. Austin Healey Classifieds 0
maxwedge5281 sxplash or overflow when filling healey gas tank Austin Healey 6
AngliaGT MGB Gas Tank Removal - '67 GT MG 2
69MGC MGC New Gas Tank for my C MG 3
D TR4/4A Tr4 Vented gas tank banjo bolt Triumph 7
K TR2/3/3A Cleaning the gas tank...what have I done now? Triumph 19
K TR2/3/3A Gas tank pipe connector? Triumph 6
S TR2/3/3A gas tank hole body work Triumph 7
maxwedge5281 gas tank and grill installation Austin Healey 29
K TR2/3/3A Gas tank to pipe connector.... Triumph 1
K TR2/3/3A Cleaning a gas tank with muriatic acid.... Triumph 7
C TR2/3/3A Gas tank cover in cockpit area Triumph 3
J TR2/3/3A Gas tank fitting and ferrule Triumph 2
S TR2/3/3A with sugar in the gas tank Triumph 13
Tinkerman TR2/3/3A Another Freeby from the past. For a 1960 TR3A Gas Tank Triumph 4
Gliderman8 General Tech Cleaning sludge/varnish from a gas tank Triumph 6
B TR6 76 TR6 gas separation tank - orientation? Triumph 2
C TR2/3/3A TR2 Gas Tank Triumph 6
R_Lyle TR6 Drain the fuel tank - five year old gas? Triumph 4
davidb AH 3000 aluminum gas tank Austin Healey 5
