TR2/3/3A TR3 Gas Tank Grounding
T
TR3-Stu
On installing my refurbished TR3A gas tank, I put a thin rubber layer between the bottom of the tank and the tub body, as well as a thin strip between the tank hold-down straps and the tank. Now thinking back on it, I've isolated the tank from the body and therefore a ground. Should the fuel tank be grounded to the body?
My fuel sender is grounded to the body, but the tank is not.
Any thoughts would be appreciated.
Stu
Frank Canale
Hi Stu, If your sending unit is grounded to the chassis then I believe the tank is grounded via the sending unit mounting screws. I just tested the TR3A sending unit that I am going to use and the circular mounting plate is common to the grounding stud. I would do a continuity test on the tank as well as the sending unit and see if both are grounded. The sending unit gasket will isolate the tank and the sending unit but the mounting screws should still be a path for the tank to be grounded. Frank
T
TR3-Stu
Thanks Frank - that makes perfect sense. I'll double check with a continuity tester as well.
Stu
T
TR3-Stu
Hi Stu - Isn't the fuel tank grounded to your chassis by the metal fuel filler pipe?
On the TR3A, there is a rubber hose piece between the tank filler opening and the outside tank flip-up filler lid. I think I have my answer however in that the fuel sender unit is grounded to the chassis and the screws on the sending unit make contact with the tank.
Thanks, Stu
equiprx
Add a braided ground strap.
It's cheap and easy and you can never be too grounded.
T
TR3-Stu
As my friends would say - because you own an old British sports car "you certainly aren't well grounded'. Just kidding - thanks for the tip, and based on my previous experiences with British cars (MGA, TR3, MGBGT) I know grounding is critical.
Stu
J TR2/3/3A TR3 gas tank mystery Triumph 5
S TR2/3/3A how to install a gas tank in an early tr3 Triumph 8
tinman58 TR2/3/3A TR3 gas tank? Triumph 2
T TR2/3/3A TR3 aluminum gas tank on eBay Triumph 4
T TR2/3/3A remove a tr3 gas tank Triumph 7
K TR2/3/3A TR3 gas tank inlet size? Triumph 2
R TR2/3/3A TR3 gas tank Triumph 13
T TR2/3/3A TR3 gas tank vent Triumph 12
af3683 TR2/3/3A TR3 Trunk Plugs Near Gas Tank Triumph 3
af3683 TR2/3/3A Installing TR3 Millboard Gas Tank Cover Panel Triumph 5
K TR2/3/3A 57 TR3 gas tank hold down strap mistery? Triumph 5
S TR2/3/3A One more tr3 gas tank? Triumph 1
S TR2/3/3A tr3 gas tank vent Triumph 3
S TR2/3/3A gas tank in a 1961 tr3 Triumph 12
S TR2/3/3A Tr3 gas tank again Triumph 3
tinman58 TR2/3/3A Another TR3 gas tank ? Triumph 3
mountainman TR2/3/3A TR3 Gas Tank Question Triumph 7
H TR2/3/3A TR3- installing gas tank = nightmare Triumph 18
martx-5 TR2/3/3A TR3 Gas Tank Installation Triumph 5
S TR2/3/3A Tr3 gas tank repair Triumph 9
martx-5 TR2/3/3A TR3 Gas Tank Triumph 3
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
S TR2/3/3A TR3 gas filler cap Triumph 1
K For Sale TR3 Gas Cap Assembly Triumph Classifieds 0
M TR2/3/3A TR3 gas cap question Triumph 4
J TR2/3/3A Help!! Gas smell from Tr3! Triumph 21
S TR2/3/3A Tr3 Gas pedal height from floor Triumph 15
S TR2/3/3A tr3 gas gauge calibration resisters Triumph 12
S TR2/3/3A tr3 gas gauge Triumph 5
T TR2/3/3A TR3 gas tanks Triumph 9
mountainman TR2/3/3A Tr3 Gas Additives Triumph 23
S TR2/3/3A late tr3 gas cap? Triumph 5
S TR4/4A late tr3 and tr4 gas caps Triumph 4
S TR2/3/3A Tr3 gas cap vent Triumph 0
K TR2/3/3A TR3...Gas cap rubber gasket/seal in cap lid? Triumph 1
S TR2/3/3A Tr3 gas tanks Triumph 7
Tinkerman TR2/3/3A TR3 Gas Stop Tap Needed ! Triumph 6
K TR2/3/3A TR3 Gas Line Shut-off Valve Triumph 12
S TR2/3/3A gas gauge TR3 Triumph 7
J TR2/3/3A gas leak on a TR3 Triumph 4
RedTR3 TR2/3/3A TR3 - Gas odor and poor mileage Triumph 5
S TR2/3/3A Tr3 gas pedal Triumph 3
J TR2/3/3A tr3 and unleaded gas Triumph 9
S TR2/3/3A TR3 Gas Mileage Triumph 9
D TR2/3/3A TR3 gas gage Triumph 2
S TR2/3/3A Tr3 gas pedal shaft socket Triumph 7
