TR2/3/3A TR3 Gas Tank Question
mountainman
I am missing the banjo bolt that goes on the air vent tube. I checked the big Three and can not find one. I have only seen one on Ebay, but missed bidding on it. Does anyone know where I might find one?
Thanks again
Greg
Moseso
If you strike out, you can make one easily enough.
I don't really remember the size (7/16 UNF, I think?) it's easy enough to check x about 1-1/4" long...
Drill through it at the height of the center of the banjo fitting and then drill down from the end til you hit the cross drill. It will function just like the real thing! 1/8" holes will pass more than enough air to vent your tank.
Don Elliott
Check with the guys who repair or sell parts for SU carbs. That top brass fitting seems to me to be similar to the banjo fittings used on all SU carbs on sidescreen TRs up to about TS 43000. I bought some of these banjo fittings easily from the local shop where they sell parts for all kinds of British Cars here in Montreal two years ago.
The banjo fitting for the front carb has two fittings - one for the inlet for Carb #1 and the other which then feeds towards Carb #2.
The banjo fitting for the inlet to Carb #2 only has the single fitting. That's the one you need.
TR3driver
Great Pumpkin - R.I.P
There is also something to be said for just blocking off the banjo, and drilling a small vent hole through the inner cap. Otherwise, it can dump raw fuel out the vent even with just a moderately full tank and a moderate left turn.
Not absolutely certain, but I kind of think the tank banjo bolt is different than the early carb banjo. They at least have different part numbers, and ISTR the threads are different.
Jim_Stevens
I second the dumping fuel piece-- everytime I fill it up, I have to be careful on LH turns lest I spill that precious premium petrol!
Small vent hole thru the inner cap you say?
tinman58
I also had to make my own banjo bolt . It was very simple to do just a pain to install.
TR3driver
Yup. Both my original cap and the used replacement I got some years ago already had a roughly 1/16" hole but apparently not all do. With the chrome lid open, you can see the inner cap (which isn't chromed but does the actual sealing); the hole is near the center post (where the inner cap is spring-loaded to the outer chrome cap). Since my original vent tube was already in place when I discovered the problem, I just plugged it and went on for some 20 years with no problem.
Probably best to remove from the car for drilling; but if you are careful and cover the tank opening (maybe a sheet of cardboard), it could probably be done on the car.
T TR2/3/3A TR3 Gas Tank Grounding Triumph 9
J TR2/3/3A TR3 gas tank mystery Triumph 5
S TR2/3/3A how to install a gas tank in an early tr3 Triumph 8
tinman58 TR2/3/3A TR3 gas tank? Triumph 2
T TR2/3/3A TR3 aluminum gas tank on eBay Triumph 4
T TR2/3/3A remove a tr3 gas tank Triumph 7
K TR2/3/3A TR3 gas tank inlet size? Triumph 2
R TR2/3/3A TR3 gas tank Triumph 13
T TR2/3/3A TR3 gas tank vent Triumph 12
af3683 TR2/3/3A TR3 Trunk Plugs Near Gas Tank Triumph 3
af3683 TR2/3/3A Installing TR3 Millboard Gas Tank Cover Panel Triumph 5
K TR2/3/3A 57 TR3 gas tank hold down strap mistery? Triumph 5
S TR2/3/3A One more tr3 gas tank? Triumph 1
S TR2/3/3A tr3 gas tank vent Triumph 3
S TR2/3/3A gas tank in a 1961 tr3 Triumph 12
S TR2/3/3A Tr3 gas tank again Triumph 3
tinman58 TR2/3/3A Another TR3 gas tank ? Triumph 3
H TR2/3/3A TR3- installing gas tank = nightmare Triumph 18
martx-5 TR2/3/3A TR3 Gas Tank Installation Triumph 5
S TR2/3/3A Tr3 gas tank repair Triumph 9
martx-5 TR2/3/3A TR3 Gas Tank Triumph 3
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
S TR2/3/3A TR3 gas filler cap Triumph 1
K For Sale TR3 Gas Cap Assembly Triumph Classifieds 0
M TR2/3/3A TR3 gas cap question Triumph 4
J TR2/3/3A Help!! Gas smell from Tr3! Triumph 21
S TR2/3/3A Tr3 Gas pedal height from floor Triumph 15
S TR2/3/3A tr3 gas gauge calibration resisters Triumph 12
S TR2/3/3A tr3 gas gauge Triumph 5
T TR2/3/3A TR3 gas tanks Triumph 9
mountainman TR2/3/3A Tr3 Gas Additives Triumph 23
S TR2/3/3A late tr3 gas cap? Triumph 5
S TR4/4A late tr3 and tr4 gas caps Triumph 4
S TR2/3/3A Tr3 gas cap vent Triumph 0
K TR2/3/3A TR3...Gas cap rubber gasket/seal in cap lid? Triumph 1
S TR2/3/3A Tr3 gas tanks Triumph 7
Tinkerman TR2/3/3A TR3 Gas Stop Tap Needed ! Triumph 6
K TR2/3/3A TR3 Gas Line Shut-off Valve Triumph 12
S TR2/3/3A gas gauge TR3 Triumph 7
J TR2/3/3A gas leak on a TR3 Triumph 4
RedTR3 TR2/3/3A TR3 - Gas odor and poor mileage Triumph 5
S TR2/3/3A Tr3 gas pedal Triumph 3
J TR2/3/3A tr3 and unleaded gas Triumph 9
S TR2/3/3A TR3 Gas Mileage Triumph 9
D TR2/3/3A TR3 gas gage Triumph 2
S TR2/3/3A Tr3 gas pedal shaft socket Triumph 7
