sxplash or overflow when filling healey gas tank
maxwedge5281
i am tired of having gasoline " feedback"" when filling my tank. i assume that due to the tank design the air cant escape as quickly as the gasoline is being pumped. and, suddenly an overflow event at the tank filler opening. any ideas on a suitable tank vent. would a suitable tube welded inside the filler tube work if it reached the top of the tank body? any ideas appreciated!
vette
Maxwedge, when i first bought my Healey I didn't have that problem. Then after I restored it I started to have the problem. i was wondering what was different. I tried a variety of things including changing the angle that the tank sat in the trunk floor opening. But what I discovered was the way i was holding the gas pump nozzle when filling the tank. If I let the hose and handle angle out over the rear fender then the gas always sloshed out of the filler pipe before or when the nozzle would shut off. But if I turned the handle so that the hose end draped a bit over the trunk lid and down over the bumper then the nozzle could shut the gas off automaticly with out the sloshing. I still don't fill the tank with the nozzle going full bore. i hold it about half speed with my hand. I also put a rag on the body work just behind the fill pipe just in case. But the change in position of the handle made a big difference.
Michael Oritt
The easiest solution is get a 100.
John Turney
Is the any restriction in the filler pipe?
When I got my Aston filler cap, I found it easier and less permanent to flip the fill pipe over and install the new cap on the end that normally goes in the tank and figured the slight obstruction from the cap lugs on the top wouldn't matter. WRONG!! It doesn't take much of an obstruction to cause gas to back up.
maxwedge5281
maxwedge5281
yes, i understand slower with the pump! but, being an impatient sort who drives his car often it is really a nuisance for me! thanks for the tips!
Patrick67BJ8 Coolant Overflow Tank Austin Healey 21
K TR2/3/3A Hot day coolant overflow issue.... Triumph 1
nevets Radiator Overflow Tank Austin Healey 23
D TR2/3/3A radiator overflow restrictor Triumph 9
G Fuel Overflow Austin Healey 10
tinman58 TR5/TR250 Front carb spitting fuel out overflow Triumph 11
aero3113 Radiator overflow catch tank Austin Healey 15
M Coolant 'overflow' when not overheating.... what's up? Spridgets 34
D Overflow Bottle for BT7 Austin Healey 24
J New Radiator Cap - Foam overflow Austin Healey 7
britlover Rear SU float not seating -- fuel overflow Austin Healey 24
mgedit TR2/3/3A Coolant spit out of overflow Triumph 20
J TR2/3/3A Found my overflow problem from the radiator , Triumph 9
steveg Radiator Cap & overflow system explained Austin Healey 1
K TR2/3/3A TR3A Coolant recovery or overflow setup? Triumph 2
lbc_newbie Float bowl overflow Spridgets 7
Zimmycobra Overflow bottle Triumph 13
H TR6 Filling up the TR6, overflow? Triumph 6
L Bugeye Coolant Overflow Spridgets 8
Jim_Newman Coolant overflow tank for e-type Jaguar 1
H Anti-Frezze expandtion thru overflow @ Shutdown Austin Healey 35
R SU HS6 Carbs overflow leaking........... MG 20
mrv8q TR2/3/3A TR3 Radiator overflow Q Triumph 4
T Radiator overflow tank? Austin Healey 12
Jim_Gruber SU Carb overflow tubes Spridgets 11
bighealeysource Overflow copper tube from carb manifold ? Austin Healey 2
CinneaghTR TR4/4A 4A Overflow Bottle Bracket Triumph 19
pjsmetana Spitfire Spitfire Radiator Overflow Bottle Triumph 6
pjsmetana 2 radiator overflow bottles? Triumph 2
Tinkerman TR2/3/3A Radiator overflow pipe clip TR 3A [pics added] Triumph 9
P Manifold and Carb overflow tubes on a BJ7 Austin Healey 18
N Gas from my header overflow Austin Healey 9
M Fuel Tank Overflow Spridgets 5
nevets radiator overflow Austin Healey 16
CCURTISS TR2/3/3A TR3 Coolant coming from overflow Triumph 7
G Overflow bottle a one way deal? Triumph 16
J Fuel Overflow at back float valve Spridgets 2
S Carb Overflow Problem Austin Healey 14
D fuel overflow actually spitting fuel? Spridgets 2
M Coolant Overflow Question... Spridgets 8
KVH Rear Differential Overflow Valve Triumph 3
rick_ingram Coolant loss - overflow only MG 4
jaybird Carb overflow MG 9
GB1 Overflow Catches Racing 27
R Fuel overflow on XJR Jaguar 1
KVH TR4/4A Odd Radiator Overflow Issue-TR4 Triumph 2
vping Overflow bottle MG 27
C Fuel overflow pipe clips Austin Healey 8
mperdue SU carb plumbing - overflow MG 11
R Carburetors Overflow Austin Healey 4
