Carburetors Overflow
Redgazelle1
A few weeks ago I replaced the original carburetors on my BJ7 with new ones from Moss Motors; however, since then I have experienced problems of petrol consistently pouring out of the overflow. Any suggestions with solving this problem?
Thanks.
/ubbthreads/images/graemlins/england.gif
ThomP
It seems funny that this should coencide with new carbs. My experience is that this is a "dirty fuel" problem causing the floats to stick open. Check the bottom of the new float bowls and see if there isn't some "crud" down there. Crud can come from fuel lines disintegrating, fuel tanks rusting, fuel lines decaying and outside contaminants, like the grand son placing a handful of dirt under the shiny thing on grandpaws car....
It could also be that the new carbs have defective needle valves or floats, but it seems unlikley that both carbs would be bad.
AndrewMawson
[ QUOTE ]
Thanks.
[/ QUOTE ]
Check that the fibre washer 'sealing' the overflow banjo to the top of the float chamber is not a plain one but the one with three cutouts. If the wrong washer is put in, as things warm up the pressure builds up from evaporating fuel and the only way out is by blowing fuel through the overflow. If the correct washer is fitted then pressure is releved by vapour escaping.
/ubbthreads/images/graemlins/england.gif /ubbthreads/images/graemlins/england.gif /ubbthreads/images/graemlins/england.gif /ubbthreads/images/graemlins/england.gif
nevets
Don't know if this is your problem but...I had a similar overflow problem with one of my carbs and it turned out the brass float inside the carb bowl was not floating due to a leak (the air leaked out and it filled up with gasoline). I replaced the float and the problem was solved. Leaky floats can be fixed (with solder) but I didn't go this route.
miranda
a little while ago we had this overflow problem, and it was the carb needle sticking(probably dirty fuel. Didn't take too long to fix
sjoerd
TomMull Weber Carburetors Lotus 18
G SU HS6 Carburetors Needle Jets Selection Austin Healey 3
steveg Mikuni HSR Carburetors Austin Healey 3
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
S TR2/3/3A Carburetors again, and again, and again Triumph 14
J Carburetors for a 1275cc Engine Spridgets 11
T TR4/4A TR4 Carburetors/Idling Triumph 3
F How to restore screws, springs and fixings on SU HD6 Carburetors? Austin Healey 7
KVH General Tech Carburetors Backfiring Triumph 6
P TR6 Caffeine & carburetors Triumph 4
Tom74TR6 Off Topic Caffeine and Carburetors - Sunday Oct 18 - New Canaan CT - Last one of the year Triumph 1
P Cobra with 8 carburetors? Spotted 4
P General TR Caffeine & carburetors Triumph 2
P BT7 Fuel pipe and carburetors Question Austin Healey 2
U Wedge Help Removing Carburetors Triumph 6
60TR3A Should My '63 BJ7's Carburetors Have Brass Caps or Black Plastic? Austin Healey 3
N BJ8 restoring carburetors Austin Healey 13
toysrrus "FISH CARBURETORS": Who needs a pair? Racing 3
S SU Carburetors Austin Healey 2
TomMull carburetors not pretty, cleaning suggestions neede Triumph 13
deadair Initial adjustments of SU H6 Carburetors Triumph 9
macey75 Set of 2 new SU HD8 carburetors, Healey 3000 mk3 Austin Healey 0
Luke_Healey Pros and cons of various carburetors? Spridgets 54
C TR6 Triumph TR6 Carburetors Triumph 31
A carburetors Austin Healey 6
OZ_BN1 More on SU Carburetors Austin Healey 13
Michael Oritt SU carburetors Austin Healey 5
M Gas, hot days, carburetors and emission control... Spridgets 19
M carburetors rebuilding Triumph 13
F TR6 Carburetors 1975 TR6 Triumph 33
P Synchronizing SU carburetors? British Motor Corp 2
R Setting up HD8 carburetors Austin Healey 6
Hegg Wedge I can't get my SU carburetors running right [TR7] Triumph 7
H Carburetors - Loose Screws Austin Healey 19
R Carburetors- Weber vs. Twin SU's MG 8
M SU Carburetors Austin Healey 3
Patrick67BJ8 Coolant Overflow Tank Austin Healey 21
K TR2/3/3A Hot day coolant overflow issue.... Triumph 1
nevets Radiator Overflow Tank Austin Healey 23
D TR2/3/3A radiator overflow restrictor Triumph 9
G Fuel Overflow Austin Healey 10
tinman58 TR5/TR250 Front carb spitting fuel out overflow Triumph 11
aero3113 Radiator overflow catch tank Austin Healey 15
M Coolant 'overflow' when not overheating.... what's up? Spridgets 34
D Overflow Bottle for BT7 Austin Healey 24
maxwedge5281 sxplash or overflow when filling healey gas tank Austin Healey 6
J New Radiator Cap - Foam overflow Austin Healey 7
britlover Rear SU float not seating -- fuel overflow Austin Healey 24
mgedit TR2/3/3A Coolant spit out of overflow Triumph 20
