Have been having problems for a month with the engine not being able to idle when hot, low engine power and not taking revs like it should.
Looked over the ignition, didn't find anything. I knew the carburetors were a bit worn in the throttle body shafts, so I decided to repair them. It's too cold to drive now anyways.
Maybe I found the real problem after just taking off the rear airfilter, it was full of oil. Must be worn rocker shaft assembly. Better replace that with a renovated I guess.
Is that enough to cause these problems?
Rest of the pictures are here, dont think the carburetors look that bad. Feel free to comment if you see anything I have overlooked.
https://healey.850r.dk/albums/Picture%20Album/album/Restoring%20Carburetors/index.html#
