Stirkle said:
The Haynes manual says the pressure relief radiator cap setting is 3.25-4.25 PSI. It has a 6-8 PSI cap on it now. I don't recall seeing a PSI cap that low.
That does seem very low. Your Spitifire, by comparison, would be 13 PSI.
At 3-4 psi the pressure cap would not be having much effect on raising the coolant boiling point, but I guess that's the way the TR was meant to work.
The pressure cap should have two valves in it. This was mentioned in a previous post by Darrell Walker. The centre valve opens inwards under partial vacuum to allow coolant to flow back into the rad. The outer valve is the one that has the key pressure rating.
I suppose if your rad was not full to begin with it may not overflow. Although one would think the vacuum created on cooling would still suck some coolant from the bottle back into the rad.
FWIW, mine doesn't seem to do much either,
