Carb overflow
jaybird
I was cleaning up the engine bay in Binabox the other night for my trip to Kansas City this weekend. Was brought to my attention that my carbs don't have overflow tubes on them in case a float sticks and pukes gas. Gas will go right onto my purdy manifold and *POOF* Binabox is Crispy Critter.
Hmmm.
How can I fix that? Chuck has already left for Indianapolis for the NHRA drag races this weekend.
Also, I can't get the danged rear view mirror on. The 'original' that clamps to the center rod. It keeps slipping, like it's too loose.
maynard
If you don't have the original overflows, you can fabricate some from brake line. Use fuel hose to connect them to the carb bowls.
A couple of hoses dangled so they aren't touching the exhaust, and in the case of fuel puking, would let the fuel just come out onto the ground.
jaybird
jaybird
Brake line or fuel hose? I thought I could run to one of the auto parts stores and buy 3 or 4 feet of quarter inch fuel hose.
Just let it dump out onto the ground? That's not very environmentally correct, is it?
/ubbthreads/images/graemlins/grin.gif
Rubber fuel hose.
jlaird
But it works. Should not pass fuel anyway, is just for when a carb goes west.
/ubbthreads/images/graemlins/lol.gif I like the non-south analogy.
jaybird
jaybird
Hmmm, Binabox, me AND my carbs are heading west this weekend...
jaybird
jaybird
Half of TeamSpamalot is going, King Spam & Vonda. Bill & Judy can't make it!
tinman58 TR5/TR250 Front carb spitting fuel out overflow Triumph 11
Jim_Gruber SU Carb overflow tubes Spridgets 11
bighealeysource Overflow copper tube from carb manifold ? Austin Healey 2
P Manifold and Carb overflow tubes on a BJ7 Austin Healey 18
S Carb Overflow Problem Austin Healey 14
mperdue SU carb plumbing - overflow MG 11
P SU CARB Overflow tubes MG 6
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
S Carb Float Levers Austin Healey 9
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A Another Carb question. Triumph 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
jlaird MGB V6 carb help MG 14
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
E MGB SU CARB OIL 1965 mgb MG 3
Michael Oritt SU H6 carb for Le Mans--order of assembly of fuel bowl lid Austin Healey 2
D Tri carb: order of installation question. Austin Healey 5
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
E MGB SU carb air cleaners MG 10
Healey Nut Tri-Carb Project Austin Healey 213
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
tahoe healey Dumb carb question Austin Healey 23
jfarris TR2/3/3A Happy with my Paltech Carb rebuild Triumph 8
