TR2/3/3A TR-3B carb question
Ken H
I'm rebuilding my TR-3B carbs and need to know if the needles should be SM or TW. I've seen both used in different sources and don't know which is correct for the engine.
NutmegCT
Ken - what carbs do you have on the engine? What type of driving do you do (road, rally, high speed, car shows only, etc.)
Tom M.
NutmegCT
NutmegCT
K
Ken H
Ken - you might also want to check out this SU guidance:
Thanks! I haven't seen that guide before. I have an SU carburetor manual published by Haynes as well as the Haynes TR-3 and TR-4 manual. There's some missing information regarding TR-3Bs. leading to my SM or TW needles. This link you sent covers a lot of useful information, but didn't cover 3Bs. Thanks anyway.
K
Ken H
Check this out:
Looks like SM would be your choice.
This is a very good illustration of the carb and says the SM is the correct needle (same as the Moss catalog) however it says its for the 1991 cc engine. I believe my engine is 2138 cc. I'm certain the carbs on my engine are original to the car and the engine is also original to the car. I've owned the car since 1975 when it had very low milage on the engine. The Haynes SU manual has all the needles listed with dimensions. I calculated the difference in flows between the two needles when the piston is raised about a quarter of an inch and get a difference of about 11 percent more flow from the SM needle than the TW. This is confusing because the manual says the TW is used on the larger cc engine. I have the SM needles in the carbs now but have to adjust the carbs to 18 to 20 flats open to get a good idle. My problem could be electrical, or mechanical but I'm making sure the carbs are in good shape before looking elsewhere. Thanks for your help. This manual is informative.
charleyf
Ken, The difference in your 3B and a 3A engine is very little. When you find a reference to a TR4 and 4A, they are looking at a difference in some air pollution equipment that required a leaner needle. I used SM needles on my 3B and use them on my 2 TR4s.
Charley
poolboy
Get them both...compare how they work with your driving style.
K
Ken H
Charley
Thanks Charlie. I calculated the open areas for fuel flow at various piston lifts to compare the two needles. For the first quarter inch of lift, the flow areas are the same. With more lift, the SM needle produces about 8 percent more fuel flow. This makes sense when you think the 2138 cc engine is that much larger. I'll stick with the SMs while I look elsewhere to solve my misfiring issues.
charleyf
The SM needle was designated for the TR3 for the 1991 engine and carried over into the TR4 2138 engine.
I am sure they were looking more for performance than economy.
Interesting that the difference is the 8% you found. I have a book that shows the needle measurements, if you are interested.
Charley
K
Ken H
Charley
I'm glad to learn the background of the SM needle and that eases my mind a little. I have an SU carb book published by Haynes that gives me all the dimensions of needles used in SUs. I used the dimensions of these needles to calculate area of the jet minus area of the needle at all positions of the needle as it's lifted by the piston. I plotted it on an Excel chart to make it more visual. It's interesting that the two needles are identical for the first .25 of travel after that, the SM needle produces eight to eleven percent more flow at equal piston lift.
A month ago, the engine was missing some, but I would drive it for a few miles and the plugs would indicate rich with the SM needles. That caused me to tear down the carbs thinking one of the cork gaskets on the jets was leaking causing too much fuel to the engine. The gaskets were in poor shape, but I can't confirm if they were leaking or not. I think the carbs are in good shape now, but I needed to know if the SM needles were correct for the engine. Your input gives me more confidence that they are correct. How did you learn the history of the SM needle?
charleyf
[/QUOTE]
I guess the answer would be experience and books. I had a TR3 in the 60's. Drove it for four plus years and never touched the carbs. Bought a TR3B in the late 90's and restored it. (My son now has that car.) That involved a lot of reading, at least for me with no computer help. I rebuilt those carbs with the help of books/ manuals. I now have restored 2 TR4's and another TR3A. I now use the HS6 SU carbs in all 3 of my cars. When converting the HS6 carbs I needed to do more research especially regarding which needle to use. Ultimately I stayed with the SM needle even in the different model SUs.
Charley
M New Member with an HD8 Carb Question Austin Healey 1
D TR2/3/3A Another Carb question. Triumph 22
D Tri carb: order of installation question. Austin Healey 5
tahoe healey Dumb carb question Austin Healey 23
Michael Oritt SU H6 carb question Austin Healey 5
R T-Series SU carb needle question MG 1
D 62 tri-carb tuning question Austin Healey 8
S TR2/3/3A Carb Idle Question Triumph 6
H General Tech SU HS4 Carb Question Triumph 5
bugedd Carb/intake question Spridgets 6
CessnaTPA Carb Spring Question Austin Healey 7
M_Pied_Lourd TR2/3/3A Weber Carb Installation Question Triumph 13
H TR2/3/3A SU Carb Float Question Triumph 18
davidb BT7 triple carb question Austin Healey 15
HealeyDave HD Carb Jet Adjusting Screw Question Austin Healey 2
sim 1970 H2 carb question Spridgets 2
bigbadbluetr6 TR6 TR6 carb question and running rough Triumph 13
Lukens TR2/3/3A TR3 SU carb question Triumph 10
W TR6 carb question tr6 Triumph 1
JPSmit Stromberg Carb Question Triumph 15
S Question on rebuilding Stromberg carb Triumph 24
glemon SU Carb question float level/leaner/richer Austin Healey 2
bighealeysource 100M carb question Austin Healey 2
B TR6 TR-6 carb question Triumph 9
SkinnedKnuckles Question about AH 3000 carb damper oil Austin Healey 21
G TR6 TR 6 Carb question Triumph 5
G HS4 carb question Spridgets 10
D Spitfire Spitfire carb question Triumph 8
SkinnedKnuckles Question for Our Carb Gurus Triumph 0
drooartz Carb mixture question Spridgets 9
Monark192 Carb Interchangeability Question MG 9
Jim_Gruber Quick Carb Question Spridgets 16
JodyFKerr Spifire 1500 Carb teardown question Triumph 10
livinginthepast Quick question on setting fast idle/balancing carb Spridgets 21
T Stromberg 150 CD carb question Triumph 4
F GT6 GT6 MK3 Carb to Manifold Gasket Question... Triumph 2
T TR2/3/3A TR3 carb question Triumph 3
T SU carb question Triumph 3
JPSmit Carb Adjustment question Spridgets 30
JPSmit gasket question - carb Spridgets 9
JPSmit SU carb question Spridgets 7
JPSmit Carb Conversion Question - new post Spridgets 7
T Carb Gasket Question Triumph 2
M 79 midget carb question Spridgets 11
Number_6 SU Carb Question Triumph 14
JPSmit Quick Carb Question Spridgets 2
JPSmit Just wondering - carb question Spridgets 10
T Newbie SU Carb Rebuild & Restoration Question Triumph 31
tony barnhill MkI Midget Carb Linkage Question Spridgets 27
walshja carb question Spridgets 10
