Carb Rebuild Necessity
wangdango
My '67 BJ8 has been sitting idle for about 6 years and I want to get her back up and running. The carbs were rebuilt prior to this.
My question is, since I am not sure if they are compatible with ethanol gas, should I rebuild them prior to trying to get her back running?
NutmegCT
Just to clarify - are you saying the carburetors were rebuilt about six years ago? or were they rebuilt long before that? professional rebuild with proper seals, jets, and adjustments? and hopefully the carbs, pump, and tank weren't sitting with fuel in them.
Are your carbs the original carbs on the car? If they were rebuilt about six years ago, and the car hasn't run for six years, they're likely in very good condition. I think ethanol-mix gasoline has been used in NY for at least 20 years, so if the car were mine, I give the mechanicals and electrical a good check over, and crank it up.
Tom M.
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
jfarris TR2/3/3A Happy with my Paltech Carb rebuild Triumph 8
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
2 carb rebuild Other British Cars 3
jsfbond GT6 Carb rebuild Triumph 17
drooartz Winter projects: carb and dizzy rebuild MG 26
Raymond SU carb Rebuild MG 7
T carb rebuild Triumph 1
T Carb Rebuild Triumph 0
J SU H6 Carb Rebuild driving me crazy! Triumph 19
Anthony_S Carb Rebuild Triumph 17
M SU Carb rebuild Spridgets 15
TulsaFred SU Carb rebuild kits $$$ Spridgets 8
B SU throttle shafts and carb rebuild Austin Healey 1
T 1500 ZS carb rebuild problem Spridgets 6
M weber carb rebuild HELP! Spridgets 50
livinginthepast Carb Rebuild Follies - Newbies take heed Spridgets 5
mountainman TR2/3/3A TR3 Carb Rebuild Help Triumph 1
T Newbie SU Carb Rebuild & Restoration Question Triumph 31
Dadandson SU Carb Rebuild Spridgets 24
S Spitfire Spitfire Z-S carb rebuild trouble Triumph 4
rick_ingram HS6 Carb Rebuild Results MG 9
Dudly Carb/Waterchoke rebuild Triumph 3
B SU Carb Rebuild Question Spridgets 6
B Carb Rebuild Kit? Spridgets 5
Walk New Fuel Pump & Rebuild Carb - No Gas in Between! MG 21
S SU carb rebuild reference Spridgets 6
Kirk_Fisher Carb rebuild Triumph 11
vping Carb Rebuild MG 4
JPSmit carb rebuild question Spridgets 7
T TR6 Recommendation on '71 TR6 Carb Rebuild Kit? Triumph 7
W carb rebuild kits Triumph 10
G Carb -- To Rebuild, or Not to Rebuild Spridgets 15
F Wedge 1980 TR7 ZS Carb rebuild advice [need some] Triumph 5
jaybird Carb rebuild kits MG 20
goloch SU Carb Rebuild and Identification MG 23
martyc T-Series Carb Rebuild on the TD...boy did they need it! MG 7
jsneddon SU carb rebuild jet corks and washers Triumph 8
AltaKnight TR6 TR6 ZS carb rebuild Triumph 4
L SU Carb rebuild question Spridgets 3
A ZS Carb Rebuild Spridgets 3
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
M New Member with an HD8 Carb Question Austin Healey 1
