MGB MGB ZS Carb 175CD
Eleven22
I just bought a 175CD carb for my 79 MGB. it was rebuilt. and when I went to pull mine off I noticed mine was a 175CD-2. it seems that 1 hose is different where it goes from the front to the back and there is a little port on the bottom that I was not using nor did I even know it was there. I contacted the seller and was told that the CD-2 was for triumphs and that MGBs never used it , so at sometime someone must have changed it. sure ok , i'll try this 175 CD and make the adjustments. I swapped it out car started right up sounded pretty good at first, then once warm it started to stumble so I took at my adjustment tool, and as I pushed it in it sounded like the car sounded better, without me even turning the Allen wrench part. I turned it just to see what difference it did so I can adjust it to what it needs to be. but every time I push down on the tool to hold it in place and then attempt to adjust the mixture it seemed that it would run better, as soon as I take pressure off the tool it starts stumbling a bit. my questions are :1. should this be expected? 2. when I do turn the allen wrench to either leaner or richer should there be a big difference? I did throw on a colortune to check it out and adjusting the needle seemed to do nothing for the color. It was running with a blue color so I figure it was ok , and I took it for a spin. It feels almost as if it is flooding. As it wouldn't die but it had no power, just going around the block I found myself having to baby the gas just to barely move the car. I'm starting to think this carb is bad. my other carb the 175CD-2 works it just needs a rebuild as it is time, but now I'm unsure if these cars ever came with a cd-2? any help would be great here.
E
Eleven22
I figured out my own stuff. Ha! sometimes you have to sit back have a beer and think it through. I turned the needle all the way clockwise til it stopped then backed it out a quarter turn til I got it smooth. Just drove to the store and back. I'll do a full test drive tomorrow.
JPSmit
Good news! sometimes a beer and a think is the best route. (In truth a beer and a think would have saved me from hours of launching in without a plan)
Platinum
First Rule: Stare at the problem sternly for a bit.
A CAB in-hand can help slow the impulse to jump in and "just DO it."
JPSmit
Big fan of staring sternly at the problem - for a very long time
P MGB 1980 MGB carb and oil questions MG 3
E MGB SU CARB OIL 1965 mgb MG 3
wkilleffer MGB Trouble with adjusting the front SU carb- 74 MGB, HS4 carbs [long] MG 5
E MGB quad carb mgb??? MG 17
T MGB 1979 MGB with Weber carb MG 7
G MGB MGB carb system for sale MG 2
kyreb1862 MGB 77 MGB Carb Conversion MG 2
K MGB British Columbia/MGB Carb Swap/Air Care? MG 4
K MGB 80 MGB carb conversion to twin SU's MG 16
martyc MGB Help: 73 MGB w/ Weber DGV Carb - Popping Downhill? MG 9
wkilleffer MGB HS4 carb question- 18GK engine, 1974 MGB [long] MG 6
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 0
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
VeeCee MGB 1974 MGB Roof Installation MG 0
J MGB Just bought a 1966 MGB MG 50
T MGB MGB hoses MG 6
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
