Fuel overflow pipe clips
Cutlass
I'm assembling the oil pan to block on my 66 BJ8. There are two small clips that are attached to the block by oil pan bolts, longer than the others, that protrude through the lip of the block long enough to secure the clips with washers and nuts on the protruding part of the bolt. My problem is that I don't know exactly which two oil pan bolts should be the longer ones used for the clips. Starting from the front, any idea on which ones are correct?
Thanks in advance.
cutlass,moss shows part # 57-bolt sump and manifold drain pipe clip "long bolt"as beeing the third one from the front depending on were you count from l/s check it out. /ubbthreads/images/graemlins/cheers.gif
Keoke
Well Cutlass, for once Moss is correct on the location of the drain pipe brackets on the sump.However, to interface with those locations, the drain pipes must take on a lazy "Z" configuration which minimizes the posibility for introducing a vacuum leak into the system. On the otherhand, I see no reasn for nuts and washers as the block is threaded. Thats OK if you have the flat type pipe clips.---Fwiw---Keoke
C
Cutlass
Thanks, Anthony and Keoke. I had seen the diagram in the Moss catalog, with part #57, showing the approximate location of one long bolt as you indicated. But there are two pipe clips, and two long bolts,with only one shown on the diagram. The Moss diagram, of course, is right out of the Mechanical Service Parts List, which likewise calls for two long bolts, but shows the location of only one. Because of that, I did not really trust the diagram on the one shown. The problem is that I did not disassemble the sump from the block and note the location of the clips. Thanks again, though, for your willingness to help. The Devil is in the details. (And in the body shop.)
John Loftus
I just checked on my spare "parts" motor. As you can see below, the clips are mounted on the 2nd and 7th bolt as seen from the side (or technically the 3rd and 8th if you count from the front row of bolts). Anyway .. a picture always helps...
bighly
Interesting John. Guess I have another correction to do. What I did was to use all slightly longer new bolts that came with a alloy sump from AH Spares (before the exchange rate hike) and put these as "washers" from the underside and added grommets to avoid rattle. Agree with Keoke about the lazy bend.
John Loftus
Hi Tracy, I don't think you could mount the clips on the underside with the stock pressed steel oil pan because the lip would get in the way. There are grommets that go in the holes to isolate the manifold drain pipes .. just missing on my photos.
Cheers,
John
Keoke
Hi John, It is easy enough to locate the stock pipe retainers under the pan lip by obtaining a spacer from most any hardware store that will allow it to just clear the lip when installed.---Keoke
G Fuel Overflow Austin Healey 10
tinman58 TR5/TR250 Front carb spitting fuel out overflow Triumph 11
britlover Rear SU float not seating -- fuel overflow Austin Healey 24
M Fuel Tank Overflow Spridgets 5
J Fuel Overflow at back float valve Spridgets 2
D fuel overflow actually spitting fuel? Spridgets 2
R Fuel overflow on XJR Jaguar 1
AndreL TR6 Conversion to electric fuel pump Triumph 10
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
BoyRacer Fuel Tank Sending Unit Austin Healey 3
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
G Best fuel option for a 72 Midget Spridgets 5
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
G TR6 Clogged fuel line Triumph 6
