TR6 Fuel return line
mondoslade
I have been working on my TR6 for the past year or so. Just getting around to running the fuel lines. I bought a new tank several years ago and it has two bungs in the top of the tank with a vent nipple. I will be using a Carter electric pump with a return line regulator to supply three Dellorto DHLA 40s. The two top bungs are different as one of them has a tube that runs to the bottom of the tank and the other is just open. Can anyone suggest which bung to use for the return line? Also curious if anyone has ran the fuel lines on the right hand side of the car. It would make it easier to plumb I think. Thanks!
Gliderman8
M
mondoslade
1973. There is a return from the regulator that will go back to the tank. Sorry I didn't make this clearer. I figure I'll try running these carbs at 3.5 psi with the excess pressure returning to the tank since I didn't want to deadhead it. I am not using a carbon cannister, or any original emissions devices. The vent will use a Alston Chassis vapor cannister to take care of fuel tank pressure relief. Thanks for taking a look at this!
Andy Blackley
On your new tank check if one of the bungs goes to the bottom of the tank, perhaps into a swirl pot; use that for the supply line and the other for the return. I think a return line even on cars without fuel injection is a good idea as it keeps relatively cooler fuel flowing through the lines to avoid vapor lock. Rover used it many years ago on the 3500 sedan for that reason.
malbaby
The one running to the bottom of the tank will be for the fuel return from an injected engine.
The top/open one for air/vapour release, and will need to run outside the car, or return to the canister in the engine bay.
M
mondoslade
Excellent! Though I think my pump is gravity fed. I might have to use one of the bottom bungs for the supply side.
M
mondoslade
The line running from the bottom of the tank is a return for an injected engine. Any problem using it for the return on a carbureted engine? The return pressure will be very low.
Sarastro
As I read through this thread, I was thinking the same thing. The Engineering Toolbox gives a density for gasoline of 45-49 lb/cubic foot. That means you have about 0.35 PSI at the bottom of the tank per foot of fuel. I don't think that should be a problem, as long as the regulator has reasonable range.
Returning the fuel to the top of the tank does not make this consideration go away; in fact, it makes it worse. You have even more back pressure, because you are raising the fuel to the top of the tank and the fuel level inside the tank will always be less than that.
Interesting idea, though, to use the return line.
AndreL TR6 Conversion to electric fuel pump Triumph 10
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
BoyRacer Fuel Tank Sending Unit Austin Healey 3
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
G Best fuel option for a 72 Midget Spridgets 5
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
G TR6 Clogged fuel line Triumph 6
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
M Fuel Filler Caps Austin Healey 2
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
Patrick67BJ8 Fuel Hose Decals Austin Healey 16
P XJ12 Fuel pump relay 85 Jaguar 4
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
