Gas from my header overflow
nates100
Hello. I'm a novice mechanic with a 1959 100-6 BN6. I've just got it running but obviously still alot of issues to continue working on. It seems to be running a little rich and I'm getting some gas on the ground from the head overflow tube after each start. Any suggestions where to start? It is as simple as turning the carb mixture adjustment? I have been reading some of the posts and really appreciate all the knowledge and interest I see. Thanks, Nates100
Keoke
Hi Nate were all a bunch of novices here. I want you to describe the overflow tube that you see leaking and where it is attached.--Keoke
N
nates100
Hey, thanks for the quick reply. The thin, long drainage tube is under the front of the head/or intake manifold. I have the Automatic enrichment carb that I think I have now made into a manual choke. This thing doesn't show up in many pictures and I understand was on Healeys for only a short production period. I have not had to use the choke to start it. It drains some gas after parking it. After a mile test run yesterday, it actually wouldn't start. I thought it might be flooded and it started after letting it sit for few minutes.
Keoke
OK Nate, that is the intake manifold drain. If you converted the choke it just may be that it is not set up correctly and it is flooding the engine. Your comment, you have not had to use the choke to start the engine suggests this may be the problem. ___Keoke
P.S Most LBC Mechanics swear by the auto choke unit. I would fix it or have it fixed.
N
nates100
Thanks Keoke. That's great advice. Finding someone who can set it up correctly maybe the most difficult. My local specialists want me to remove the whole unit and intake manifold. Thanks again.
Keoke
Well Nate, you are not the only NC Lister on the forum. Perhaps one of them knows of a LBC service facility in that area and will chime in.---Keoke
GregW
Platinum
Hi Nate,
Are you close to Greensboro and/or have you tried Hendrix Wire Wheel? If they don't do that kinda thing, I'm sure they'll know someone. Both Jerry and Allen are involved with Healeys.
bt7tricarb
I, personally, can't recommend Allen Hendrix enough. He's fantastic and a real straight shooter. You won't be overcharged. I'm not saying he's "cheap," but he's reasonable and you won't feel like your being raked over the coals.
The face of his shop has changed a bit. Jerry pretty much retired earlier this year and is rarely there. His son Chance is also rarely there any more because he's now flying choppers in the Army full time (thanks to him for his service). Allen does have a couple of "new" folks - but at this point even they've been there about two years.
Ben is a phenominal mechanic. He's one of those guys that people like me think he's a magician.
and
Tom is one of those guys with the attention to detail that you simply want to work on your car. If it aint right, he'll make it right.
Between them and Allen, Hendrix is more than just tires!
As a disclaimer - I've got no personal affiliation with HWW other than being a customer. Allen restored my car "ground up." I have taken it to a couple of other shops for some specialty work since then, but it ended up back at Allen's to fix what they messed up.
Celtic 77 MGB LeMans Gas filler MG 10
mctriumph General TR NEVER start a car with stale gas Triumph 0
TomMull GT6 Gas Tank Outlet Triumph 0
B TR6 Gas on spark plugs Triumph 7
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
edkap2002 TR6 gas tank sounds Triumph 8
MGTF1250Dave T-Series TF Gas Tank MG 6
B General MG 77 MIDGET Gas tank sending unit MG 1
G Wanted gas tank dip stick for mgtf 1555 MG Classifieds 1
Celtic 77 MGB Pessimistic Gas gague MG 10
B gas leak underneath the carburetor Restoration & Tools 2
T TR2/3/3A TR3 Gas Tank Grounding Triumph 9
P MGB Mgb gas tank cap MG 7
LAW75 Concours: Original Gas Hose Austin Healey 12
LAW75 Gas Odor Elimination Austin Healey 3
B TR4/4A GAS TANK FELT Triumph 14
Hamish Racing General Tech Petrol/Gas with high ethanol Triumph 3
edkap2002 TR6 gas smell Triumph 8
R TR2/3/3A Gas pedal pad for TR-2 Triumph 3
B Damaged threads in the gas tank Austin Healey 7
BierRunner TR6 TR6 Gas Pedal Triumph 4
Jim_Stevens Off Topic Ethanol-free gas link Triumph 1
J TR2/3/3A TR3 gas tank mystery Triumph 5
Rob Glasgow New Gas Tank Austin Healey 8
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
B TR4/4A Gas Tank color? Triumph 4
B BE vs. Later Model Gas tanks Spridgets 2
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
JPSmit Fuel line - gas tank question Restoration & Tools 5
Ripper01 SOLD-TR6 Gas Tank Triumph Classifieds 3
A Wanted Gas tank for TR6 Triumph Classifieds 5
J For Sale Triumph Tr 2/3 Gas Pedal Triumph Classifieds 1
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
D What's inside the gas tank?? Spridgets 13
C TR2/3/3A Gas Line Triumph 11
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
S TR2/3/3A TR3 gas filler cap Triumph 1
J TR2/3/3A TR3A gas tank repair Triumph 7
longbridgehealey Fuel pump racing, no gas Austin Healey 26
Rut MGB Running out of gas symptoms MG 21
T TR2/3/3A TR3A Gas Cap Triumph 15
D Gas Pedal Pad Jaguar 7
K For Sale TR3 Gas Cap Assembly Triumph Classifieds 0
T magnets and gas tanks, and other applications Austin Healey 3
Michael Oritt Gas cap parts now in tank Austin Healey 17
Rhodyspit75 Bonnet gas struts Spridgets 5
K TR2/3/3A Gas Gauge sending unit "float" orientation? Triumph 5
K TR2/3/3A Gas tanks...two different types? Triumph 5
ckeithjordan TR2/3/3A Gas Filler Cap Triumph 1
R TR2/3/3A Installing gas tank Triumph 6
